made the update to 2024.01 and it’s really great to see the fan speed been added to the Thermostat Card features. Issue is that I’m only having 1 icon for the automatic fan mode. The other modes are a simple dot. Any way to add icons there (or at least some text below)?
Thermostat Card 2024.01:
Example from Simple Thermostat Card:
Also, with Simple Thermostat Card, I’m able to select the swing mode as per shown on below pictures. Any way to add the same to the Thermostat Card?
Thank you if you can support and bring any help here.
No solution to date… still ysing the simple thermostat card.
I agrre with your analysis should be an issue with fan speeds names not recognised by the thermostat card and therefore simply showing a dot as icon.
