one of the colors used in your theme is not opaque/transparent. Figure out which one it is and make it transparent. You may need card modder if you only want to make it transparent on that card.
And before you ask, there’s no easy way to figure out which color is causing the problem. You can use the dev tools in chrome to figure it out but if you don’t know CSS and inheritance well, you’ll struggle.
@petro so far I’ve figured out that ‘–paper-card-background-color’ is the one that fills the card. It is the way the gauge is created I think will cause this as unsolvable (unless you’re a developer) as long as I wan the card to be transparent. It works great as long as I use any color as card-color (white, black etc).
I don’t think anything can be done. It appears as if the object that covers the pie sections uses the background color. So when you make the background transparent, it makes the item that covers parts of the triangle transparent. You end up with that weird looking pi chart. Sorry bud.
@petro I kind of came to the same conclusion, it is not made for using transparent card background.
I switched to ‘simple-thermostat’ and of course bumped into a CSS issue also in this. I’ve seen two or three questions about the same thing, but they have not gotten any answer;
I can control all aspects of the card by CSS except the active chosen mode (with the frame). It seems to always be dark grey. I can change colors of all the other text and icons, and change themes, but the chosen mode always return this dark grey color.
The ‘disabled’ is causing this behavior. If you use Chrome dev and remove ‘disabled’ from the button style, it works as expected.
I would assume what he (the developer) wanted to achieve was the opposite - non-selected modes should be disabled and active mode should be with color…
Anything we can do to override this from theme/styling (card-modder) ?
@TheStigh could share your yaml and css information to make the card like you did? I cannot figure out how to get the modes along the bottom like you did.
This is what I have so far, but it does not put in any modes (I tried to put an icon next to humidity, but it didn’t let the page load so I commented it out):
You need to verify the state inside states page and use that verbiage as your modes. Do not use what you see in the UI as mode names. Also, yaml fields should always be lowercase. Lastly, you should study the documentation for that custom component. In the modes section, it describes that you cannot use ‘off’ without quotes as a mode.
Thanks for replying. I did confirm the hvac modes in the dev states page and I have them correct as they are listed there. I also tried wrapping off in both " (double quotes) and ’ (single quotes) as it shows in the card’s instructions. I also changed the names of the modes to all lowercase. Nothing worked. I was following another user that posted his yaml information and he had it set up like I did (even the capital letters). I am at a lose as to why this is not working and I am not sure how to troubleshoot at this point.
That was essentially how my code ended up, but I changed a couple things to match where you put them. It still does not work. I wonder if the issue is with me using the horizontal stack option. I will play around with it some more. Thank you for your assistance. I appreciate it.
