Thermostat Card min and max temp display
I am using the thermostat card with the temperature displayed in Celcius. The circular display shows values from 1 to 99 degrees and it is almost impossible to make changes on my mobile because the range is so wide. Is it possible to change the range to something more realistic like 10 to 30?
Any assistance is greatly appreciated.
Greg
how do you use in in Lovelace? insert your thermostat in entity card and it won’t be radial:
cards:
  - entities:
      - entity: climate.thermostat
      - entity: switch.combi_boiler
      - entity: input_boolean.heating_controlled_by_alarm
      - entity: input_boolean.central_heating_enable_night_automation
    type: entities
state_color: true
title: Central heating
type: vertical-stack
Thanks. I’ll give it a try when I get home. I also don’t mind the radial view, it just needs a reduced scale.
Cheers,
Greg
I think it gets bigger when alone, that’s the difference.
This one gives you compact (non-radial) view:
type: entities
entities:
Hey there, new to Home Assistant and was experiencing the same issue. I put this on a similar thread but I thought I would respond here too since this is more recent.
There is a init .py file in the core/components/climate folder that defines the max temp for the device. I found mine here:
/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/climate/__init__.py
Find the appropriate line:
DEFAULT_MIN_TEMP = 7
DEFAULT_MAX_TEMP = 35
Define it as you wish (in Celsius, obviously), restart, and the thermostat card should now use the defined min and max.
UPDATE: Also can be done on an entity basis through the UI, much easier:
Configuration > Customization > Select Entity and change min and/or max temp value.
I’m sure there’s a way to do this through YAML too but these both work for me.
You can set a maximum/minimum temperature on the climate entity using YAML in the following way. The lovelace thermostat card of that entity displays these limits.
/config/configuration.yaml
homeassistant:
  customize: !include customize.yaml
/config/customize.yaml
climate.entity_id:
    max_temp: 28
    min_temp: 8
Restart the Home Assistant Server for the changes to take effect. :slightly_smiling_face:
Screenshot_20210127_203121
Just come across this.
How did you remove the ‘mode’ buttons at the bottom of the thermostat?
Does the customise solution still work for 2022.5+ (I think I read that customize.yaml is being depreciated??)
[edit] I got customize to work (in my heating package) - thanks!
I’m still interested to know how you hid the heating modes in the thermostat card though.
Maybe I am dense or haven’t found it but where do these changes get made? I tried editing the code on the card itself and got an error. Can someone take a dummy like me by the hand and show me what to do? I have version 2022.7.7
Raising an old thread here. This method doesn’t seem to work anymore. It gives a yaml error.
Anyone know how to apply these max and min limits permanently these days?
@StuC Still works.
My mistake. I had structured the YAML incorrectly. All good now.
Cannot seem to get this to work for my Nexia integrated thermostats. Getting the following issue:
Configuration errors
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/customize.yaml”, line 6, column 13
Using this, have tried many variations:
climate.west
    min_temp: 60
    max_temp: 80
There is a colon missing after the entity.
