Hello, I have started to do some cleanup in HA configuration. I had a problem with the OTA update in Zigbee2MQTT for some time, so I removed the add-on, deleted the configuration files. I reinstalled ZIGbee2MQTT and started adding radiator heads again. The head was added and I finally managed to update it. Everything seemingly ok, but now when I started adding the temperature control interface, the ability to set the temperature from the main tab disappeared, i.e. setting the temperature after the ring, when I want to change the temperature I have to go into the tab and then I have the Up/down arrow. Does anyone know how to fix this?
If you’re talking about the setpoint missing on the thermostat card after installing 2023.3.0 - it’s a known issue and should be resolved in the next release.
Ok, thank god it’s a bug , because I thought I was going crazy looking for a solution.
