Thermostat Replacement for ThermoSphere Dual Control in UK
Hi everyone,
I currently own a ThermoSphere Dual Control thermostat that controls both electric underfloor heating and an electric towel rail in my bathroom. Here’s the product page: Dual Control - Electric Underfloor Heating Thermostat - ThermoSphere
After some research, it seems there isn’t a straightforward way to integrate this thermostat with Home Assistant, so I’m looking to replace it with a smart thermostat that offers easy integration.
I don’t use the heated towel rail much, so if the replacement thermostat only supports the underfloor heating, that’s okay with me. However, the ideal solution would support both heating systems.
I’ve come across the Sinope TH1300ZB Zigbee 3600 W in some threads here, and it seems like a great option. Unfortunately, it’s primarily sold in America, and since I’m based in the UK, it’s quite expensive to get it shipped here. Product page: Smart floor heating thermostat 3600 W – Zigbee | Sinope Technologies
Does anyone have recommendations for smart thermostats that are available in the UK and can be easily integrated into Home Assistant? I would really appreciate your insights and suggestions!
Thanks in advance!
I bought a Moes thermostat and managed to pair it with Home Assistant, see Pairing Moes ZHT-006-GB Zigbee Thermostat with Home Assistant Yellow
The Moes thermostat controls the underfloor heating only, so it’s not a perfect replacement for the dual control thermostat. However, I found I rarely used the heated towel rail so I don’t mind not being able to control it anymore.
Hi @matware
Apologies for digging out this old thread, I can’t seem to send you a PM.
I’m thinking about getting the same Moes thermostat as you, but I was wondering if the Thermosphere sensors are compatible with the Moes thermostat. As the thermostat is outside the bathroom it would be problematic if it can’t sense the temperature.
Thanks!
Hi @HansGeering, I think they should be compatible. However, I can’t confirm for sure as I’m using the ambient temperature sensor, not the floor sensor.
Also, you might find this thread interesting: Pairing Moes ZHT-006-GB Zigbee Thermostat with Home Assistant Yellow
