"Thread border router required" with Eve and Matter
I have a SkyConnect with multiprotocol enabled.
When I try to add an Eve Energy socket as a Matter device, I get this:
I get this when adding the socket directly to HomeAssistant, and I also get that after I’ve added it to HomeKit first.
Anyone has any idea what this is about?
Just to make sure that I don’t get any “You need a thread border router, you can install one like …”, my thread networks look like this:
…and I am also using the HomeKit-generated pairing code.
Does anyone maybe have any idea why this happens?
Same here with external Nordic based OTBR…
I have the same problem. I tried both on iphone and on android. The error on android is: Make sure you´re connected to your network and try again. If i disable thread on home assistant the error is slightly different: Make sure that the device is powered on and try again.
In my log i can find an error. I have a fresh home assistant installation with skyconnect and one (working) zigbee device.
2023-04-26 23:35:01.600 WARNING (MainThread) [bellows.zigbee.application] ControllerApplication reset unsuccessful: ConnectionRefusedError(111, "Connect call failed ('172.30.32.1', 9999)")
  File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 642, in _reset_controller_loop
    await self._reset_controller()
  File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 663, in _reset_controller
    await self.connect()
  File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 130, in connect
    self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 109, in initialize
    await ezsp.connect(use_thread=zigpy_config[conf.CONF_USE_THREAD])
  File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 126, in connect
    self._gw = await bellows.uart.connect(self._config, self, use_thread=use_thread)
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 414, in connect
    protocol, _ = await _connect(config, application)
  File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 385, in _connect
    transport, protocol = await zigpy.serial.create_serial_connection(
  File "/usr/local/lib/python3.10/site-packages/zigpy/serial.py", line 31, in create_serial_connection
    transport, protocol = await loop.create_connection(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1076, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1060, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 969, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 501, in sock_connect
    return await fut
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 541, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('172.30.32.1', 9999)
Homeassistant needs to have an ipv6 adress for matter to function.
After enabling ipv6 in the hassio network settings it started to work as expected.
And the homekit device must be added to hassio by the owner of the homekit home and not by a user.
I have ipv6 enabled but it is still not working for me.
Not only do I have IPv6 enabled, but it’s even a static address. So this is clearly not the case.
Now, after your post, and judging by how easy it was for you, I thought “What the heck, maybe my IPv6 settings are toast!” So I checked them all the way, and not only are they correct, but I can find nothing that would indicate as to why they wouldn’t work.
Log from Matter server add-on:
2023-05-02 00:41:55 core-matter-server chip.CTL[126] ERROR Commissioning discovery over BLE failed: ../src/platform/Linux/BLEManagerImpl.cpp:814: CHIP Error 0x00000032: Timeout
2023-05-02 00:41:55 core-matter-server chip.-[126] ERROR ../src/platform/Linux/BLEManagerImpl.cpp:814: CHIP Error 0x00000032: Timeout at ../src/controller/SetUpCodePairer.cpp:299
2023-05-02 00:41:55 core-matter-server chip.EM[126] ERROR Failed to Send CHIP MessageCounter:164879481 on exchange 42638i sendCount: 4 max retries: 4
2023-05-02 00:41:58 core-matter-server chip.SC[126] ERROR PASESession timed out while waiting for a response from the peer. Expected message type was 33
2023-05-02 00:42:08 core-matter-server chip.EM[126] ERROR Failed to Send CHIP MessageCounter:164879482 on exchange 42639i sendCount: 4 max retries: 4
2023-05-02 00:42:11 core-matter-server chip.SC[126] ERROR PASESession timed out while waiting for a response from the peer. Expected message type was 33
2023-05-02 00:42:15 core-matter-server chip.CTL[126] ERROR Discovery timed out
2023-05-02 00:42:22 core-matter-server chip.EM[126] ERROR Failed to Send CHIP MessageCounter:164879483 on exchange 42640i sendCount: 4 max retries: 4
2023-05-02 00:42:25 core-matter-server chip.SC[126] ERROR PASESession timed out while waiting for a response from the peer. Expected message type was 33
2023-05-02 00:42:35 core-matter-server chip.EM[126] ERROR Failed to Send CHIP MessageCounter:164879484 on exchange 42641i sendCount: 4 max retries: 4
2023-05-02 00:42:38 core-matter-server chip.SC[126] ERROR PASESession timed out while waiting for a response from the peer. Expected message type was 33
2023-05-02 00:42:38 core-matter-server matter_server.server.client_handler[126] ERROR [548289214736] Error handling message: CommandMessage(message_id='4c5007517ada4783b9801fb582da6329', command='commission_with_code', args={'code': '12435929517'})
  File "/usr/local/lib/python3.10/site-packages/matter_server/server/client_handler.py", line 188, in _run_handler
    result = await result
  File "/usr/local/lib/python3.10/site-packages/matter_server/server/device_controller.py", line 154, in commission_with_code
    raise NodeCommissionFailed(
matter_server.common.errors.NodeCommissionFailed: Commission with code failed for node 6
This happens no matter what device I try.
Does BLE in BLEManagerImpl stands for Bluetooth Low Energy? Is this the Server or the Iphone App? Is Bluetooth working on your iPhone?
Bluetooth is working on my iPhone(s), especially since it is otherwise able to do pairing in the Home app and devices are otherwise accessible via all means of communication (for example, I have a Yale Linus which is only accessible via Bluetooth, and that one works just fine).
Also, like I specified right at the beginning, that was the log from the Matter Server add-on.
I am still at a loss as to why the HA team has chosen to not utilize the Bluetooth radio on the device it’s running on to do the pairing, and have decided to not even offer the option. There are quite a few quirks with mobile devices (the iPhone only being able to add devices to HA if you’re the owner of the home, which is stupid, but I guess it’s probably a “we didn’t think of this before, but yeah but we’ll probably fix sometime” kind of issue with Apple - I’m curious, what happens if you don’t have a home set up at all? Or maybe… what happens if you don’t have a mobile device at all? Like, say, you’re in an industrial or commercial setup and don’t want anything tied to any mobile device, or the corporate policy doesn’t allow that?).
Anyone have any idea how else to diagnose, or what other logs should I pull?
Also, an interesting thing that I noticed: I have a Samsung Android tablet lying around, which I thought would probably make a great way to add devices, while bypassing any possible issues that might arise due to Apple devices - but surprise! When I try to add a Matter device, I get the “You must do this using a mobile device”-something prompt, as if I was using a browser. What is going on?
I just found the reason why they require Bluetooth on the Phone.
Maybe the Samsung Android tablet is too old? For Android you need Matter Support. Do you have the https://play.google.com/store/apps/details?id=com.google.android.apps.chromecast.app app? See also: "Add matter device" unavailable - #18 by omriasta
This is my matter server log
s6-rc: info: service legacy-cont-init successfully started
 Add-on: Matter Server
 Matter WebSocket Server for Home Assistant Matter support.
 Add-on version: 4.3.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.1  (amd64 / qemux86-64)
 Home Assistant Core: 2023.4.6
 Home Assistant Supervisor: 2023.04.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
s6-rc: info: service legacy-services: starting
[14:44:35] INFO: Starting Matter Server...
s6-rc: info: service legacy-services successfully started
[14:44:35] INFO: Successfully send discovery information to Home Assistant.
2023-05-02 14:44:37 core-matter-server matter_server.server.stack[126] INFO Initializing CHIP/Matter Controller Stack...
[1683031477.364762][126:126] CHIP:CTL: Setting attestation nonce to random value
[1683031477.365765][126:126] CHIP:CTL: Setting CSR nonce to random value
[1683031477.375883][126:126] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1683031477.376086][126:126] CHIP:DL: writing settings to file (/tmp/chip_kvs-4tL4WJ)
[1683031477.376170][126:126] CHIP:DL: renamed tmp file to file (/tmp/chip_kvs)
[1683031477.376616][126:126] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_factory.ini
[1683031477.377188][126:126] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_config.ini
[1683031477.377588][126:126] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_counters.ini
[1683031477.378436][126:126] CHIP:DL: writing settings to file (/data/chip_counters.ini-QLrvdL)
[1683031477.378638][126:126] CHIP:DL: renamed tmp file to file (/data/chip_counters.ini)
[1683031477.378660][126:126] CHIP:DL: NVS set: chip-counters/reboot-count = 4 (0x4)
[1683031477.378958][126:126] CHIP:DL: Got Ethernet interface: enp0s18
[1683031477.379113][126:126] CHIP:DL: Found the primary Ethernet interface:enp0s18
[1683031477.379484][126:126] CHIP:DL: Failed to get WiFi interface
[1683031477.379498][126:126] CHIP:DL: Failed to reset WiFi statistic counts
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] WARNING Initializing persistent storage from file: /data/chip.json
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] WARNING Loading configuration from /data/chip.json...
2023-05-02 14:44:37 core-matter-server chip.TS[126] INFO Last Known Good Time: 2023-04-18T07:39:42
2023-05-02 14:44:37 core-matter-server chip.FP[126] INFO Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x36A2AFEC539A2BC7, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0x134B
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] INFO SetSdkKey: g/gcc = b'\xa0\x0f\x00\x00'
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] INFO Committing...
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] INFO SetSdkKey: g/gdc = b'\xa0\x0f\x00\x00'
2023-05-02 14:44:37 core-matter-server chip.ZCL[126] INFO Using ZAP configuration...
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on vethf79ea38 for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on vethc1301c2 for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on veth403db3b for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on vethfc3728d for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on vethd25bd6d for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server chip.DL[126] ERROR MDNS failed to join multicast group on veth0d7d78a for address type IPv4: ../src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
2023-05-02 14:44:37 core-matter-server CertificateAuthorityManager[126] WARNING Loading certificate authorities from storage...
2023-05-02 14:44:37 core-matter-server CertificateAuthority[126] WARNING New CertificateAuthority at index 1
2023-05-02 14:44:37 core-matter-server CertificateAuthority[126] WARNING Loading fabric admins from storage...
2023-05-02 14:44:37 core-matter-server FabricAdmin[126] WARNING New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2023-05-02 14:44:37 core-matter-server PersistentStorage[126] INFO SetReplKey: caList = {'1': [{'fabricId': 2, 'vendorId': 4939}]}
2023-05-02 14:44:37 core-matter-server matter_server.server.stack[126] INFO CHIP Controller Stack initialized.
2023-05-02 14:44:37 core-matter-server matter_server.server.server[126] INFO Starting the Matter Server...
2023-05-02 14:44:37 core-matter-server matter_server.server.helpers.paa_certificates[126] INFO Fetching the latest PAA root certificates from DCL.
2023-05-02 14:44:44 core-matter-server matter_server.server.helpers.paa_certificates[126] INFO Fetched 79 PAA root certificates from DCL.
2023-05-02 14:44:44 core-matter-server matter_server.server.helpers.paa_certificates[126] INFO Fetching the latest PAA root certificates from Git.
2023-05-02 14:44:44 core-matter-server matter_server.server.helpers.paa_certificates[126] INFO Fetched 2 PAA root certificates from Git.
2023-05-02 14:44:44 core-matter-server FabricAdmin[126] WARNING Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2023-05-02 14:44:44 core-matter-server chip.CTL[126] INFO Setting attestation nonce to random value
2023-05-02 14:44:44 core-matter-server chip.CTL[126] INFO Setting CSR nonce to random value
2023-05-02 14:44:44 core-matter-server chip.SPT[126] INFO Using device attestation PAA trust store path /usr/local/lib/python3.10/site-packages/credentials/development/paa-root-certs.
2023-05-02 14:44:44 core-matter-server chip.CTL[126] INFO Generating NOC
2023-05-02 14:44:44 core-matter-server chip.FP[126] INFO Validating NOC chain
2023-05-02 14:44:44 core-matter-server chip.FP[126] INFO NOC chain validation successful
2023-05-02 14:44:44 core-matter-server chip.FP[126] INFO Updated fabric at index: 0x1, Node ID: 0x000000000001B669
2023-05-02 14:44:44 core-matter-server chip.TS[126] INFO Last Known Good Time: 2023-04-18T07:39:42
2023-05-02 14:44:44 core-matter-server chip.TS[126] INFO New proposed Last Known Good Time: 2021-01-01T00:00:00
2023-05-02 14:44:44 core-matter-server chip.TS[126] INFO Retaining current Last Known Good Time
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: g/fs/c = b'\x15$\x00\x01(\x01\x18'
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO Committing...
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: f/1/m = b'\x15%\x00K\x13,\x01\x00\x18'
2023-05-02 14:44:44 core-matter-server chip.FP[126] INFO Metadata for Fabric 0x1 persisted to storage.
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: f/1/n = b'\x150\x01\x01\x01$\x02\x017\x03$\x13\x02\x18&\x04\x80"\x81\'&\x05\x80%M:7\x06$\x15\x02&\x11i\xb6\x01\x00\x18$\x07\x01$\x08\x010\tA\x04\xce\x9a@wK}\xcbR\x16\xb9\x82\x10\xf5c\xbb\xad]\xc0\x15L\xdb#k\x19\xa2K\xb7\x147;\xcaO)\x1b\x83q\x10\xb5\x9a\xb6J\x96cty(\x13\xbaBk\xf5;\xe2\x06\'\xa9[i\xe8v$y\x07\xa47\n5\x01(\x01\x18$\x02\x016\x03\x04\x02\x04\x01\x180\x04\x14f#\x83\x8b.\x16\xe1\xde)\xe0}Lb\x9aT\xe7\xb1{\xe7\xe30\x05\x14n\x84z,ab\x8c)zX!\x01q\xef\x90\x8c7\xff+,\x180\x0b@Y\xf8\xaa\x0c$\xaf\xa2&\xe7)\xb1S\x1c2F\xe3\xa0\x1ae\xf95\xe6\xb83\xfb$XR\x10\xad\xf7\xdd5d\x98\xb2\xf2^\x12\x9a\xe8\xf7\x81\x11!l`\x88\x0c\xcf\xfd\xf7\xe4\x80\xe9 w\x94\xca\x94cv)\xda\x18'
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: f/1/i = b'\x150\x01\x01\x01$\x02\x017\x03$\x14\x01\x18&\x04\x80"\x81\'&\x05\x80%M:7\x06$\x13\x02\x18$\x07\x01$\x08\x010\tA\x04Ct\xb9\xaa\xcc\x83\x8d\xe0\x92Z\x03\xa7!\xa7&\xd8\xeb\xf7\x85?}\xf5&\xb3\xdc|\x1b\x9e\xbcu84\x0en\x83BC6\'\x95\xc9T.@\xa2\xb5C\xe2bP\x80\xbe.z\xea,\xf9[\xa9JJ\xf7\x94\x8f7\n5\x01)\x01\x18$\x02`0\x04\x14n\x84z,ab\x8c)zX!\x01q\xef\x90\x8c7\xff+,0\x05\x14B\xac.-\x18R!5f\xf5\xdb\xe6q\xdd5\x04hd\xab\xd2\x180\x0b@\xc9u\xad\xc6\xa2\xc1\x1e11\x17\x02\xbfA\xaa%?Q1\xf8\xce;\x19>\xb1Ls\xbf\xbcZ,\x18\xf6\x07U\x8c\xdc\xba\x85\x93&3Px\x84\xde\xbe\xec\xd6\x08D\x83\xac\xacc`\x8c+]\x9d\x8d\x9a),\x9d\x18'
2023-05-02 14:44:44 core-matter-server chip.TS[126] INFO Committing Last Known Good Time to storage: 2023-04-18T07:39:42
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: g/lkgt = b'\x15&\x00\xbe\x05\xd1+\x18'
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO DeleteSdkKey: g/fs/c
2023-05-02 14:44:44 core-matter-server chip.CTL[126] INFO Joined the fabric at index 1. Fabric ID is 0x0000000000000002 (Compressed Fabric ID: 36A2AFEC539A2BC7)
2023-05-02 14:44:44 core-matter-server chip.CTL[126] INFO *** Missing DeviceAttestationVerifier configuration at DeviceCommissioner init: using global default, consider passing one in CommissionerInitParams.
2023-05-02 14:44:44 core-matter-server chip.SPT[126] INFO Setting up group data for Fabric Index 1 with Compressed Fabric ID:
2023-05-02 14:44:44 core-matter-server PersistentStorage[126] INFO SetSdkKey: f/1/k/0 = b'\x15$\x01\x00$\x02\x016\x03\x15$\x04\x00%\x05{\xf90\x06\x10i=/\x19 \x074\x1d\r\xc0\xb8t\xb3\x88\x82;\x18\x15$\x04\x00$\x05\x000\x06\x10\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x18\x15$\x04\x00$\x05\x000\x06\x10\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x18\x18%\x07\xff\xff\x18'
2023-05-02 14:44:44 core-matter-server matter_server.server.vendor_info[126] INFO Loading vendor info from storage.
2023-05-02 14:44:44 core-matter-server matter_server.server.vendor_info[126] INFO Loaded 62 vendors from storage.
2023-05-02 14:44:44 core-matter-server matter_server.server.vendor_info[126] INFO Fetching the latest vendor info from DCL.
2023-05-02 14:44:44 core-matter-server matter_server.server.vendor_info[126] INFO Fetched 62 vendors from DCL.
2023-05-02 14:44:44 core-matter-server matter_server.server.vendor_info[126] INFO Saving vendor info to storage.
From what I see in your log, mDNS does not properly work, so maybe check into that?
As for why they require the phone, I read that as well, and I would still like to have the option because: 1. I’m not using the “built-in Bluetooth integration” for anything useful and 2. the device is well within BT range.
As for my tablet being too old… too old for what, exactly? I don’t have the “Google Home” app, I don’t have any Google Home-related products… which is all the more reason I find that using the phone’s built-in ecosystem apps is a stupid idea. I guess until the team can work out a way (or have time) to do it without hooking into the current implementations, it is OK, but still this is completely unusable.
I dont know how to fix this problem. I reinstalled HA on my server and it did not fixed it. Also i found other people with this DNS error: Matter Server - Pairing with Eve Energy fails: Error handling message: CommandMessage · Issue #89056 · home-assistant/core · GitHub
But no fix there.
Can you give me your full log under http://your ip:8123/hassio/addon/core_matter_server/logs ? I just want to know, whether you dont have my dns error.
Old Tablets maybe have only Android 4.0 or an unsupported Bluetooth generation. I think Bluetooth 4.2 or higher are good, because they support ipv6.
Ok, so I looked at the Matter server log, and as it turns out I have the same mDNS errors, I just didn’t see them because they were waaaaaaay before when the Matter server first started up.
Those errors, however, seem to have nothing to do about Matter in general, as I do have Matter devices (an Aqara hub) which do work fine (well, fine might be overstating it, but they do work). They were discovered correctly, and they worked correctly. But those, it seems, do not need to do BLE pairing.
Please confirm me some things:
  1. You connect HA to the network via Ethernet
  2. Your Thread device works in the Home app or otherwise
As for the Android tablet, I’m quite sure that’s not the case. BT before 4.2 would make it not old, but ancient.
OK, is anyone, I mean ANYONE able to help with information on this? I can find no fault with my configuration, to the extent of the information I have, and I still cannot add things.
I am running into similar problems, but I have a different setup, as I explained here.
Also, I am connected via ethernet and wifi. Both of them have ipv6 turned on, but it doesnt help
I dont get it to work. But i found an extra menu for thread.
  1. Add port 8080 to the configuration of Silicon Labs Multiprotocol
  2. Visit [your ip]:8080
Now i will show my Openthread Border Router, maybe yours looks similar or different
  1. Join
  2. Form: Channel 15, but my zigbee is running on channel 11?? They need the same channel, or?
  3. Status
  4. Settings
  5. Commission
  6. Topology
I am aware of the web interface. There is nothing in there that I can figure out to be of any help. I am still unable to add any Thread-based matter devices.
