For Tibber users.
Trigger actions (e.g. toggle HVAC) depending on temperature and electricity price. Actions are triggered intelligently when price, temperature or thermostat setting change.
blueprint:
name: Tibber price and thermostat control
description: >
Trigger actions (e.g. toggle HVAC) depending on temperature and electricity price. Actions are triggered *intelligently* when price, temperature or thermostat setting change.
First create a numeric helper as a thermostat control to set the temperature threshold.
domain: automation
input:
tibber_price_sensor:
name: Tibber price sensor
selector:
entity:
domain: sensor
temperature_sensor:
description: Temperature sensor.
selector:
entity:
domain: sensor
device_class: temperature
thermostat:
description: Numeric helper entity.
selector:
entity:
domain: input_number
price_threshold:
name: Electricity price threshold
description: When to consider prices low. (Tibber price level)
default: "CHEAP"
selector:
select:
options:
- label: Very expensive
value: VERY_EXPENSIVE
- label: Expensive
value: EXPENSIVE
- label: Normal
value: NORMAL
- label: Cheap
value: CHEAP
- label: Very cheap
value: VERY_CHEAP
below_actions:
name: Low prices and temperature below thermostat setting
description: Actions to perform.
default: []
selector:
action: {}
above_actions:
name: High prices or temperature above thermostat setting
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: state
alias: price
entity_id: !input tibber_price_sensor
attribute: price_level
- platform: state
alias: thermostat
entity_id: !input thermostat
- platform: state
alias: temperature
entity_id: !input temperature_sensor
- variables:
levels: "{{ ['VERY_CHEAP','CHEAP','NORMAL','EXPENSIVE','VERY_EXPENSIVE'] }}"
price: !input tibber_price_sensor
price_threshold: !input price_threshold
price_changed: "{{ trigger.alias == 'price' }}"
price_level: "{{ state_attr(price,'price_level') }}"
price_is_low: "{{ price_level in levels and levels.index(price_level) <= levels.index(price_threshold) }}"
thermostat: !input thermostat
thermostat_changed: "{{ trigger.alias == 'thermostat' }}"
temperature: !input temperature_sensor
temperature_changed: "{{ trigger.alias == 'temperature' }}"
temperature_is_low: "{{ states(temperature)|float < states(thermostat)|float }}"
- choose:
- conditions:
- condition: or
conditions:
- condition: and
conditions:
- "{{ price_changed }}"
- "{{ levels.index(trigger.to_state.attributes.price_level) <= levels.index(price_threshold) }}"
- "{{ levels.index(trigger.from_state.attributes.price_level) > levels.index(price_threshold) }}"
- "{{ temperature_is_low }}"
- condition: and
conditions:
- "{{ temperature_changed }}"
- "{{ trigger.to_state.state|float < states(thermostat)|float }}"
- "{{ trigger.from_state.state|float >= states(thermostat)|float }}"
- "{{ price_is_low }}"
- condition: and
conditions:
- "{{ thermostat_changed }}"
- "{{ trigger.to_state.state|float > states(temperature)|float }}"
- "{{ trigger.from_state.state|float <= states(temperature)|float }}"
sequence: !input below_actions
- conditions:
- condition: or
conditions:
- condition: and
conditions:
- "{{ levels.index(trigger.to_state.attributes.price_level) > levels.index(price_threshold) }}"
- "{{ levels.index(trigger.from_state.attributes.price_level) <= levels.index(price_threshold) }}"
- condition: and
conditions:
- "{{ trigger.to_state.state|float >= states(thermostat)|float }}"
- "{{ trigger.from_state.state|float < states(thermostat)|float }}"
- condition: and
conditions:
- "{{ trigger.to_state.state|float <= states(temperature)|float }}"
- "{{ trigger.from_state.state|float > states(temperature) |float}}"
sequence: !input above_actions
