Tibber Pulse P1 energy meter is now available in Sweden: https://tibber.com/se/store/produkt/pulse-p1
Already integrated in Home Assistant and is supported by the new energy view.
If you are not a Tibber customer yet: Tibber invitations
Any chance of local support or only by Tibber cloud?
It is possible to configure Tibber Pulse to use a local mqtt server: https://www.hjemmeautomasjon.no/forums/topic/4255-tibber-pulse-mqtt/?do=findComment&comment=49771
About to order a Tibber Pulse P1 , but can’t find any info anywhere in regards to max-cable length, i found below, for other device/meter, and the “Cable” type specifications in common.
… i guess this is a good “guide-line-length” … but would like to hear others solution ( beside the non-optional) useless 1m cable, always included in all products
Edit: And below for another “meter” ( in swedish ) … but specifying Max 50M
