unfortunately without success
Reloading did seem to help with me. But after some the time price again is unavailable.
There seems to be a problem:
Github for Tibber
Has anyone ever made this sensor work?
What I don’t understand is:
- service: tibber.get_prices < What is behind it? YAML?
How did Ingo create the two?
input_number.tibber_cheap_energy_prices_hours
input_number.tibber_cheap_energy_min_price_difference
binary_sensor:
- unique_id: tibber_next_good_grid_charging_time < How is the YAML for this?
4.) a trigger-binary_sensor that catches the prices for a specific amount of hours and decides if and when there is a good time to charge from grid. The decission is based on:
- the price-difference between the cheapest and the most expensive price in the time-span
- if the price-difference is above a specific value (input_number → for me 0.1 = 10 Cents)
template:
- trigger:
- platform: time_pattern
hours: "/1"
- platform: homeassistant
event: start
start: "{{ (now()).strftime('%Y-%m-%d %H:') + '00:00' }}"
end: "{{ (now() + timedelta(hours=states('input_number.tibber_cheap_energy_prices_hours') | int(default=24))).strftime('%Y-%m-%d %H:%M:%S') }}"
response_variable: action_response
binary_sensor:
# replace "Zuhause" with the name of your "home" in the tibber-integration
state: >
{% set min_price = action_response["prices"]["Zuhause"] |map(attribute='price') | list | min | float(default=0) %}
{% set max_price = action_response["prices"]["Zuhause"] |map(attribute='price') | list | max | float(default=0) %}
{% set lowest_price_entry = action_response["prices"]["Zuhause"] | min(attribute='price') %}
{% set start_time_lowest_price = lowest_price_entry["start_time"] %}
{% set end_time_lowest_price = as_datetime(start_time_lowest_price) + timedelta(hours=1) %}
{{as_datetime(now()) > as_datetime(start_time_lowest_price) and as_datetime(now()) < as_datetime(end_time_lowest_price) and (max_price - min_price) > states('input_number.tibber_cheap_energy_min_price_difference') | float(default=0) }}
attributes:
min_price: >
{{min_price}}
max_price: >
{{max_price}}
price_range: >
{{max_price - min_price}}
start_time: >
{{start_time_lowest_price}}
end_time: >
{{end_time_lowest_price}}
prices: >
{{action_response["prices"]["Zuhause"] | list}}
That binary_sensor has a few attributes that i need for my dashboard:
* min_price => the minimum price in the fetched time-span (in €, so 0,32 means 32 Cents)
* max_price => the maximum price in the fetched time-span (in €, so 0,40 means 40 Cents)
* price_range => the difference between the min_price and the max_price (in €, so 0,08 means 8 Cents)
* start_time => the start-time of the cheapest energy-hour
* end_time => the end-time of the cheapest energy-hour
* prices => just for information: the start_times, prices and price_levels in the time-span Blockquote
Install this: https://github.com/TheFes/cheapest-energy-hours
Add Helpers named like this
put this code in configuration.yaml
@ingo.niehues
I think there is still a problem with the logic here,
because the min price should always be before the max price, right? ![]()
Hi, I get the same error message.
Also with your code.
How did you solve it?
Hi everyone! I’m following this topic now for a few weeks. First of all, I like to give a shout-out @ingo.niehues and everyone else who worked and is still working for this! Really appreciate your effort!
I used Ingo’s code from post nr. 69 and also included most of the followed improvements. When my tibber integration suddenly stopped working a few days ago, I came back to this topic. Luckily I saw the new solution by Ingo (post nr. 250) and I wanted to get this working for me as well.
Unfortunately, I am stuck (like so others) with this binary sensor that decides if and when to charge from the grid. Here’s what I did so far:
- Created template binary-sensor
sensor.tibber_kein_uberschussstrom_vorhandenaccording Ingo’s code - Created template binary-sensor
sensor.tibber_speicher_ist_nicht_vollaccording Ingo’s code - Created template binary-sensor
sensor.tibber_heute_ist_mit_wenig_solarertrag_zu_rechnenaccording Ingo’s code - Created input-number
input_number.tibber_laden_bei_restproduktion_unter - Created input-number
input_number.tibber_cheap_energy_prices_hours - Created input-number
With this being done, I used Ingo’s code for this binary-sensor tibber_next_good_grid_charging_time and included it in my configuration.yaml. The entity appears after a reboot, but with the value unknown. If I use the developer tools and paste the code, it gives me an error message that ‘action’ key is not defined: Keine Aktion definiert. Bitte definiere einen ‘action:’ Schlüssel.
If I try only the ‘action’ part (tibber.get_prices) manually in the developer tools, it works for me and I get a list of prices depending on the value of input_number.tibber_cheap_energy_prices_hours.
For me it looks like there is a problem with “action_response” but I’m not sure why it works for some people but not for everyone.
So, this is where my knowledge ends and I really hope someone can help me and the other guys who share this problem.
I agree too. As a quick fix, I have added following code in the trigger-binary sensor:
state: >
{% set min_price = action_response["prices"]["xxx"] |map(attribute='price') | list | min | float(default=0) %}
{% set max_price = action_response["prices"]["xxx"] |map(attribute='price') | list | max | float(default=0) %}
{% set lowest_price_entry = action_response["prices"]["xxx"] | min(attribute='price') %}
{% set highest_price_entry = action_response["prices"]["xxx"] | max(attribute='price') %}
{% set start_time_highest_price = highest_price_entry["start_time"] %}
{{as_datetime(now()) > as_datetime(start_time_lowest_price) and as_datetime(now()) < as_datetime(end_time_lowest_price) and as_datetime(start_time_highest_price) > as_datetime(start_time_lowest_price) and (max_price - min_price) > states('input_number.tibber_cheap_energy_min_price_difference') | float(default=0) }}
I don’t know if it works, I couldn’t test it now ![]()
Thanks for fast response, let us try and see what happened with this new code ![]()
Does anyone have an idea how to calculate the current price of the energy stored in the battery? So zero or any other value for solar power and the respective Tibber price for charged grid power?
And here the code:
Note: Replace ‘REPLACE’ with your tibber electricity_price sensor!
type: custom:config-template-card
variables:
((((states['sensor.electricity_price_REPLACE'].attributes.max_price -
states['sensor.electricity_price_REPLACE'].attributes.min_price) / 4) *
0) + states['sensor.electricity_price_REPLACE'].attributes.min_price) *
100
1) + states['sensor.electricity_price_REPLACE'].attributes.min_price) *
100
2) + states['sensor.electricity_price_REPLACE'].attributes.min_price) *
100
3) + states['sensor.electricity_price_REPLACE'].attributes.min_price) *
100
entities: ${vars[0]}
card:
type: custom:apexcharts-card
experimental:
color_threshold: true
graph_span: 48h
yaxis:
- id: costsKWH
opposite: false
align_to: 1
apex_config:
tickAmount: 10
decimalsInFloat: 0
all_series_config:
unit: Cent
apex_config:
grid:
show: true
borderColor: "#E0E0E0"
tooltip:
enabled: true
followCursor: false
x:
show: true
fixed:
enabled: false
header:
show: true
show_states: true
colorize_states: true
standard_format: false
now:
show: true
color: 9E9E9E
label: now
span:
start: day
series:
- entity: sensor.tibber_prices
show:
in_header: before_now
name_in_header: true
header_color_threshold: true
extremas: true
color_threshold:
- value: ${vars[0]}
color: green
- value: ${vars[1]}
color: yellow
- value: ${vars[2]}
color: orange
- value: ${vars[3]}
color: red
type: column
float_precision: 0
data_generator: >
const noon = new Date();
noon.setHours(0, 0, 0, 0);
const prices =
entity.attributes.today.concat(entity.attributes.tomorrow);
const data = [];
for(let i = 0; i < prices.length; i++) {
data.push([noon.getTime() + i * 1000 * 3600, prices[i].total * 100])
return data;
I’m afraid that doesn’t work like that. Shouldn’t it calculate the start time accordingly?
How do I create this sensor?
Why is the sensor called sensor.tibber_prices?
is that not the unique id from above:
unique_id: tibber_prices_level
homeassistant tells me:
Althoug I completely restarted the docker container.
Hi, here ist the code ( from ingo.niehues) for the sensor…
configuration.yaml
# Tibber Vorschaupreise
- platform: rest
resource: https://api.tibber.com/v1-beta/gql
method: POST
payload: '{ "query": "{ viewer { homes { currentSubscription { status priceInfo { current { total level startsAt } today { total level startsAt } tomorrow { total level startsAt } } } } } }" }'
json_attributes_path: "$.data.viewer.homes[0].currentSubscription.priceInfo"
json_attributes:
- today
- tomorrow
value_template: "{{ value_json.data.viewer.homes[0].currentSubscription.priceInfo.current.total | float }}"
scan_interval: 300
headers:
Authorization: !secret tibber_token
Content-Type: application/json
User-Agent: REST
unit_of_measurement: EUR/kWh
state_class: total
I am a little lost in the thread ![]()
Added an automation with:
alias: Update Tibber Prices
description: ""
triggers:
- hours: /1
trigger: time_pattern
actions:
- data:
start: "{{ (now()).strftime('%Y-%m-%d %H:00:00') }}"
end: >-
{{ (now() +
entity_id: binary_sensor.tibber_next_good_grid_charging_time
action: sensor.tibber_prices
Fetching the prices via REST API
- platform: rest
method: POST
scan_interval: 60
payload: '{ "query": "{ viewer { homes { currentSubscription { priceInfo { today { total startsAt } tomorrow { total startsAt }}}}}}" }'
json_attributes:
- today
- tomorrow
value_template: Ok
headers:
Authorization: "XXXXXXXXXXXXXXXXX"
User-Agent: REST
but my binary sensor thorws an error
binary_sensor:
name: Tibber Next Good Grid Charging Time
state: >
{% set min_price = action_response["prices"]["Zuhause"] | map(attribute='price') | list | min | float(default=0) %}
{% set max_price = action_response["prices"]["Zuhause"] | map(attribute='price') | list | max | float(default=0) %}
{{ as_datetime(now()) > as_datetime(start_time_lowest_price) and as_datetime(now()) < as_datetime(end_time_lowest_price) and (max_price - min_price) > states('input_number.tibber_cheap_energy_min_price_difference') | float(default=0) }}
attributes:
min_price: >
{{ min_price }}
max_price: >
{{ max_price }}
price_range: >
{{ max_price - min_price }}
start_time: >
{{ start_time_lowest_price }}
end_time: >
{{ end_time_lowest_price }}
prices: >
{{ action_response["prices"]["Zuhause"] | list }}
