Hi As a work around I implemented a simple Node-RED flow and use apex card to visualize.
NodeRED requests the data from tibber (you have to use your credentials) and updates a sensor with state and attributes.
The apex chard has the following code:
type: custom:apexcharts-card
header:
show: true
title: Tibber Price Today & Tomorrow(€-cent)
show_states: false
graph_span: 36h
span:
start: hour
yaxis:
- decimals: 1
experimental:
color_threshold: true
series:
- entity: sensor.tibber_price_series
transform: return x * 100;
type: line
curve: stepline
extend_to: false
stroke_width: 5
data_generator: |
return entity.attributes.timeseries.map((value, index) => {
return [new Date(value).getTime(), 100 * entity.attributes.priceseries[index]];
color_threshold:
- value: 30
color: red
- value: 25
color: yellow
- value: 20
color: darkgreen
and the flow is here (scheduled every day at 13:15 as in Germany the update is on 13:00):
[{"id":"ac89eec644b66b2e","type":"ha-sensor","z":"7b21a369cedefa85","name":"Tibber Prices Time Series","entityConfig":"815231582d01f1bb","version":0,"state":"payload.status","stateType":"msg","attributes":[],"inputOverride":"allow","outputProperties":[],"x":1090,"y":158,"wires":[[]]},{"id":"82dd34b7e63dd046","type":"json","z":"7b21a369cedefa85","name":"","property":"payload.attributes","action":"obj","pretty":false,"x":904,"y":158,"wires":[["ac89eec644b66b2e"]]},{"id":"ff5842d205ad0e39","type":"inject","z":"7b21a369cedefa85","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"15 13 * * *","once":true,"onceDelay":"300","topic":"","payload":"","payloadType":"date","x":104,"y":86,"wires":[["05e9b1460206b41b"]]},{"id":"55a48a0776be8d1f","type":"http request","z":"7b21a369cedefa85","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://api.tibber.com/v1-beta/gql","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[{"keyType":"other","keyValue":"Content-Type","valueType":"other","valueValue":"application/json; charset=utf-8"}],"credentials":{},"x":444,"y":86,"wires":[["f318d09f3f936614"]]},{"id":"f318d09f3f936614","type":"change","z":"7b21a369cedefa85","name":"Select price arrays","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.viewer.homes[0].currentSubscription.priceInfo","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":624,"y":86,"wires":[["f598e25f6df9363a","0c740a237787e3e9"]]},{"id":"f598e25f6df9363a","type":"change","z":"7b21a369cedefa85","name":"merge today, tomorrow","rules":[{"t":"set","p":"merged","pt":"msg","to":" $append($.payload.today, $.payload.tomorrow)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":852,"y":86,"wires":[["5a6f2365c28a9d85","2c9ec11c453528df"]]},{"id":"5a6f2365c28a9d85","type":"change","z":"7b21a369cedefa85","name":"reset payload status and attributes","rules":[{"t":"set","p":"attributes","pt":"msg","to":"{ \"timeseries\": $.merged.startsAt, \"priceseries\": $.merged.total } ","tot":"jsonata"},{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.status","pt":"msg","to":"$min($.merged.total)","tot":"jsonata"},{"t":"move","p":"attributes","pt":"msg","to":"payload.attributes","tot":"msg"},{"t":"set","p":"tibber_data","pt":"flow","to":"payload.attributes","tot":"msg","dc":true}],"action":"","property":"","from":"","to":"","reg":false,"x":674,"y":158,"wires":[["82dd34b7e63dd046","09a3af0f0dce6909"]]},{"id":"c320d7b8ecf23ea0","type":"comment","z":"7b21a369cedefa85","name":"Read Me: Get tibber prices and prepare to be send to sensor","info":"# Result\nSensor with: \n- status: minimum price today, tomorrow\nand 2 attributes\n- timeseries: array of time points as text\n- priceseries: array of prices as dobule\n\n# Customization\nin http request you have to enter your token\n\n# trigger\ninject at 13:15 every day as at that time the price\nfor next day are available.\n\n# error handling\nnone\n\n","x":230,"y":40,"wires":[]},{"id":"e1d268a9ce9e454a","type":"comment","z":"7b21a369cedefa85","name":"! Modify","info":"Use your token from tibber developer portal","x":424,"y":117,"wires":[],"icon":"font-awesome/fa-arrow-up"},{"id":"0c740a237787e3e9","type":"debug","z":"7b21a369cedefa85","name":"original","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":634,"y":40,"wires":[]},{"id":"2c9ec11c453528df","type":"debug","z":"7b21a369cedefa85","name":"merged","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":854,"y":40,"wires":[]},{"id":"09a3af0f0dce6909","type":"debug","z":"7b21a369cedefa85","name":"split x array / y array","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":691,"y":199,"wires":[]},{"id":"05e9b1460206b41b","type":"change","z":"7b21a369cedefa85","name":"set query","rules":[{"t":"set","p":"payload","pt":"msg","to":"{ \"query\": \"{ viewer { homes { currentSubscription{ priceInfo{ today { total startsAt } tomorrow { total startsAt } } } } } }\" }","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":291,"y":86,"wires":[["55a48a0776be8d1f"]]},{"id":"815231582d01f1bb","type":"ha-entity-config","server":"32e490af.a728b","deviceConfig":"12b46ce419b8d466","name":"tibber_price_series","version":"6","entityType":"sensor","haConfig":[{"property":"name","value":"Tibber Price Series"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"entity_picture","value":""},{"property":"device_class","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":"measurement"}],"resend":false,"debugEnabled":false},{"id":"32e490af.a728b","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30},{"id":"12b46ce419b8d466","type":"ha-device-config","name":"Tibber Prices","hwVersion":"","manufacturer":"Node-RED","model":"","swVersion":""}]
