For me it still works.
Tibber Bills Card
This Card display the consumption, the values from the bills and the cents per kwh for each monthly bill for tibber-customers.
Needed components
RESTful-Sensor in Configuration.yaml:
# Tibber Monthly Consumption Sensor
- platform: rest
unique_id: tibber_monthly_consumption
name: Tibber Monthly Consumption
resource: https://api.tibber.com/v1-beta/gql
method: POST
payload: '{ "query": "{ viewer { homes { consumption(resolution: MONTHLY, last: 12) { nodes { consumption cost unitPrice unitPriceVAT from to } } } } }" }'
json_attributes_path: "$.data.viewer.homes[0].consumption"
json_attributes:
- nodes
value_template: "{{ value_json.data.viewer.homes[0].consumption.nodes[0].consumption | float }}"
scan_interval: 30
headers:
Authorization: !secret tibber_token
Content-Type: application/json
unit_of_measurement: kWh
state_class: total
# Tibber Monthly Cost Sensor
- platform: rest
unique_id: tibber_monthly_cost
name: Tibber Monthly Cost
method: POST
json_attributes:
- nodes
value_template: "{{ value_json.data.viewer.homes[0].consumption.nodes[0].cost | float }}"
scan_interval: 30
headers:
unit_of_measurement: EUR
state_class: total
YAML-Code for the Card
type: vertical-stack
cards:
- type: custom:apexcharts-card
card_mod:
style: |
ha-card {
padding: 0px !important;
border: none;
box-shadow: none;
margin-bottom: -3rem;
yaxis:
- min: 0
apex_config:
tickAmount: 5
forceNiceScale: true
decimalsInFloat: 0
title:
text: kWh
rotate: -90
style:
color: var(--energy-grid-consumption-color)
labels:
style:
colors: var(--energy-grid-consumption-color)
- min: 0
opposite: false
apex_config:
tickAmount: 5
decimalsInFloat: 0
title:
text: €
rotate: 0
style:
color: var(--google-red)
labels:
style:
colors: var(--google-red)
apex_config:
grid:
show: true
borderColor: '#E0E0E0'
chart:
height: 300px
offsetY: -20
tooltip:
enabled: true
followCursor: true
x:
show: true
fixed:
enabled: false
header:
show: true
show_states: true
colorize_states: true
standard_format: false
graph_span: 1y
span:
end: month
series:
- entity: sensor.tibber_monthly_consumption
type: column
yaxis_id: Verbrauch
data_generator: |
return entity.attributes.nodes.map((start, index) => {
return [new Date(start["from"]).getTime(), entity.attributes.nodes[index]["consumption"]];
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
yaxis:
- min: 0
opposite: true
apex_config:
tickAmount: 5
decimalsInFloat: 0
title:
text: C
rotate: 0
style:
color: var(--google-yellow)
labels:
style:
colors: var(--google-yellow)
- min: 0
opposite: false
apex_config:
tickAmount: 5
decimalsInFloat: 0
offsetX: -20
title:
text: €
rotate: 0
style:
labels:
style:
apex_config:
xaxis:
tickAmount: 12
labels:
show: true
rotate: 90
position: top
grid:
show: true
chart:
height: 300px
offsetY: -20
tooltip:
enabled: true
shared: true
followCursor: true
x:
show: true
header:
show: true
show_states: true
graph_span: 1y
span:
end: month
series:
- entity: sensor.tibber_monthly_cost
type: column
yaxis_id: Kosten
float_precision: 2
data_generator: |
const tibber_gp = 5.03
const tibber_nng = 0.1967
const tibber_msg = 0.0459
const tibber_mwst = 0.19
return [new Date(start["from"]).getTime(), (((start["unitPrice"]-start["unitPriceVAT"])*start["consumption"])+tibber_gp+(((new Date(start["to"]).getTime() - new Date(start["from"]).getTime()) / (1000 * 60 * 60 * 24))*(tibber_nng+tibber_msg)))*(1+tibber_mwst) ];
type: column
yaxis_id: KostenKWH
float_precision: 2
name: Kosten / kWh
unit: C
data_generator: |
return [new Date(start["from"]).getTime(), ((((start["unitPrice"]-start["unitPriceVAT"])*start["consumption"])+tibber_gp+(((new Date(start["to"]).getTime() - new Date(start["from"]).getTime()) / (1000 * 60 * 60 * 24))*(tibber_nng+tibber_msg)))*(1+tibber_mwst))/start["consumption"]*100 ];
Love it too, what is for a sensor ? May i missed it, but i couldn´t find a description for:
sensor.electricity_price_wester_esch_26b
unfortunaltely, your street address is encoded in the sensor name, like:
sensor.electricity_price_STREET_NUMBER
so you have to manually adjust all example code!
Thats my Sensor from the tibber Integration
Thanks for your help! I got this finally working. How do you align the cards ? What happen if you click on tibber (chips on mushroom card) do you link back to source card, or did you link the tibber card from an other entity (like details price forecast)?
sensor.tibber_strompreisentwicklung_fazit is
in my case unknown, following config:
- unique_id: tibber_strompreisentwicklung_fazit
select: "#app-root > div.jsx-850a60188453b536.app-container > div > section > div > div:nth-child(2) > div > div > div > div.Blocks.py-xl > div > div > div > p:nth-child(6)"
why is the fazit unknown?
Thanks for this cool card!
Your Sensors shows “unknown” becase “name:” and “select:” must be on same level as “unique_id:”.
like so:
The Tibber-Chip has no click-action. I use a sub-view-Tab in Home Assistant. This has its own “back-Button”.
This is the full code of my current version of these cards:
Tibber-Card
Tibber Price Preview Card
The problem
Is that the sensor could only hold 255 characters an the text is 298 long.
Is there a possibility to split the txt?
## {{ states("sensor.tibber_strompreisentwicklung_kw") }}
<ha-alert alert-type="info">{{ states("sensor.tibber_strompreisentwicklung_short") }}</ha-alert>
### {{ states("sensor.tibber_strompreisentwicklung_preise") }}
### {{ state_attr("sensor.tibber_strompreisentwicklung_preise","text_eins") }}
{{ state_attr("sensor.tibber_strompreisentwicklung_preise","text_zwei") }}
{{ state_attr("sensor.tibber_strompreisentwicklung_preise","text_drei") }}
{{ state_attr("sensor.tibber_strompreisentwicklung_preise","text_vier") }}
### {{ state_attr("sensor.tibber_strompreisentwicklung_preise","fazit") }}
[Quelle](https://tibber.com/de/strompreisentwicklung)
This is my solution, an additional attribute in the price sensor.
Could you share your configs here without auth, since there are behind an auth on google drive?
THX a lot!!
Sorry, i updated the links. They should now work.
Hallo Ingo,
wie hast du den denn Sensor Wöchentlicher Verbrauch ersteht?
Und die für die Rechnung mwst etc.
chapeau Ingo!! Nice Nice Nice!
how do you set the values for the input numbers? Only manualy or is there a place in tibber api where we could get this infomation?
const tibber_gp =
parseFloat(hass.states['input_number.tibber_grundpreis_je_monat'].state);
const tibber_nng =
parseFloat(hass.states['input_number.tibber_netznutzungsgebuhr_je_tag'].state);
const tibber_msg =
parseFloat(hass.states['input_number.tibber_messtellengebuhr_je_tag'].state);
const tibber_mwst =
parseFloat(hass.states['input_number.tibber_mehrwertsteuersatz'].state);
Du must die Sensoren noch selbst erstellen:
daily, weekly, monthly and yearly costs per kwh (replace “daily” with “weekly”, “monthly” or “yearly”)
Thank you! Only manual. I took the values from my last tibber bill. Don´t know if there is a place to get this values. Interesting idea.
Hallo Ingo, ich habe die Code im meiner configuration.yaml eigetragen, leider zeigen die Sensoren mir “Unbekannt” an. Woran könnte das liegen?
Dazu hab ich 2 Anmerkungen:
- Hast du “sensor:” über dem “- platform: rest”? Ich vermute ja
- Hast du deinen Tibber Token unter “secrets” angelegt? Mein Code geht davon aus dass du in der secrets.yaml einen Eintrag “tibber_token: <Token_von_tibber>” hast.
Schau mal unter Tibber Developer
zu 1.: Ja.
Die Einträge mit den Spiegelstrichen müssen unterhalb von einem Eintrag “sensor:” stehen. Steht das ggfs. weiter oben?
