[Tile Card] - Use state as Name or allow Name to be Empty
This FR will probably be a benefit in some very specific cases, but it would provide a lot of configuration options for dashboards…
I would like to have a feature, with which I could:
a) disable the entity Name on the TileCard, so only the state / value would be visible
or
b) use the state itself in the place of the entity name.
For example, this Dashboard:
Would then allow me to have the “Batterie” TileCard only showing the percentage (which could be used for ALL battery related tiles - as well as for the bottom tile card showing the lock_status.
In the case of the lock_status (Cat Flap Eingang Treppenhaus…) - the Image does indicate the lock state - and in addition to this, I would also like to have only the state visible - but not the name of the entity / sensor itself.
Hi, you can hide the entity name by setting a space as the name in the tile card.
Below is a screenshot how it looks like in my setup
type: tile
entity: sensor.moon_phase
PS: Works in most cards !
None of the proposed options (space, empty list) allow the tile card to be only a single column wide, which should then also be possible.
If you go to vertical setting, you can be 1x column wide !
But… It will be two lines height…
I made the same request in another FR: Tile Card Improvements (display, template, controls, etc...)
