Eheheh, good point. My HA is not exposed to the internet
On a different note, I started experimenting and using a sensor_icon tile for a cover and even if te state mapping is correct (checked by switching to sensor tile) and I follow your template, the icon does not show up. Any suggestion?
@resoai - Thanks, I would agree on the use for it, as my tileboard is up and running well, it’s more as a project - Thanks
It would be helpful to see the config and state dump for your cover entity. I’m sorry that my telepathic abilities have weakened greatly during lockdown
thanks for helping, here is the piece of config:
position: [1, 0],
type: TYPES.SENSOR_ICON,
title: 'Small garage',
states: {
on: "open",
off: "closed"
icons: {
on: "mdi-garage-open",
off: "mdi-garage"
and here is the status of the cover:
As you can see that n the state dump, states for your cover are open and closed rather than on and off what you specified in the tile.
ok, now I understood the logic.
Thank you for the help.
Missed that relay - sorry - Thanks a Mill - cant wait to get at it -
I have an iPad gen3 and use Kiosk Pro as my browser. Works a treat. I put it in guided access by triple clicking the home button.
Starting to get into it! This is a great interface!!!
How do I resize the header? On my Ipad3 even if I am using the compact theme, the group title overlaps with the header elements.
So very new to JavaScript, and I’ve tried to piece it together off example i’ve seen but haven’t gotten it to work. Is there anyway to have a WiFi icon, and when you click on it it opens popup with an image (QR code)?
I know I could just put the QR code right one the page but I have design OCD on how it will blend in.
Thanks.
So noticed an interesting quark. I have a blind that is set to 0. However the slider will show 50% when refreshed. If I set the blind to anything else, everything works fine. I can refresh the page and the slider is accurate. Just not when it sits at 0. Also, randomly the tileboard page will refresh and the blind will jump to 49% (if it was previously at 0). The wife thinks I am messing with her.
position: [0, 0],
title: 'Front Blind',
type: TYPES.SLIDER,
unit: '%',
state: false,
field: 'position',
bottom: false, // puts slider on bottom
slider: {
max: 100,
min: 0,
step: 1,
title: "Position",
field: "current_position",
value: '@attributes.current_position',
request: {
type: "call_service",
domain: "cover",
service: "set_cover_position",
field: "position"
By using the id of the cover you are essentially binding the state the the cover (which is open/closed) to the slider value. Why not use COVER tile which was designed for it?
Hi folks, I could not find any reference in the thread, maybe I missed it. How can one change color of the icons? I looked at the css files, but being not an expert, I could not see teh right spot.
C
That makes sense. We liked the idea of a slider more at the time. However we could switch to COVER.
So COVER works well. One advantage of a slider though is that we could set limits and open the blind to the percentage we want.
For example, I can set a limit of 75% on some of the blinds. (we have some large blinds that I would prefer not be opened fully)
Another plus is that the touchscreen is not in the same room as the blinds. So if we want to open the blinds 50% it becomes a bit of guesswork.
Perhaps this could be implemented in the future.
Thanks!
You can create input_number in HA with relevant automation .
I could. But I have lots of blinds.
I took a look at the code and I think I know why it is doing what it is doing. I guess in Javascript 0’s are treated as false and when doing comparisons it was skipping over them.
I changed getSliderConf to the following and it now functions as I would expect it to. 0’s are reflected on the slider. I am not a JS person so maybe there is a better way. But this works for me.
//var value = +attrs[def.field] || 0;
var value = +attrs[def.field] || +entity.state || 0;
//value: value || +entity.state || def.value || 0,
value: (value === 0) ? (0) : (value || +entity.state || def.value || 0),
