TileBoard - New dashboard for Homeassistant
Here the config i tried for the page:
         title: 'Main page',
         bg: 'images/bg2.jpg',
         icon: 'mdi-home-outline', // home icon
         groups: [
               title: 'Gang',
               width: 1,
               height: 1,
			   groupMarginCss: '10px 20px',
               row: 0,  // optional; index of the row used for the GRID layout. If not specified, the default is 0
               items: [
				  position: [0, 0],
				  type: TYPES.INPUT_BOOLEAN,
				  title: 'Inngangsdør',
				  states: {
				    off: "Låst",
					on: "Ulåst"
				  icons: {
					off: "mdi-door-closed",
					on: "mdi-door-open",
               title: 'Soverom',
               width: 6,
               height: 1,
               row: 1,  // optional; index of the row used for the GRID layout. If not specified, the default is 0
               items: [
                     position: [0, 0],
                     width: 1,
                     type: TYPES.LIGHT,
                     title: 'Nattbord André',
                     subtitle: 'Soverom',
					 states: {
					   on: "På",
                       off: "Av"
                     icons: {
                       on: "mdi-lamp",
                       off: "mdi-lamp",
                     position: [1, 0],
                     width: 1,
                     type: TYPES.LIGHT,
                     title: 'Nattbord Martine',
					 states: {
					   on: "På",
                       off: "Av"
                     icons: {
                       on: "mdi-lamp",
                       off: "mdi-lamp",
				  position: [2, 0],
				  title: 'Taklampe',
				  states: {
				    off: "Av",
					on: "På"
				  icons: {
					off: "mdi-ceiling-light",
					on: "mdi-ceiling-light",
                     position: [3, 0],
                     width: 1,
                     type: TYPES.LIGHT,
                     title: 'Kleskap',
					 states: {
					   on: "På",
                       off: "Av"
                     icons: {
                       on: "mdi-wall-sconce-flat",
                       off: "mdi-wall-sconce-flat",
                     position: [4, 0],
                     width: 1,
                     type: TYPES.SWITCH,
                     title: 'Rullegardin',
					 states: {
					   on: "Åpen",
                       off: "Lukket"
                     icons: {
                       on: "mdi-blinds-open",
                       off: "mdi-blinds",
Have you set groupsAlign: GROUP_ALIGNS.GRID and what is your theme?
Ahh,
Did not see that config. Set it to grid and it worked :slight_smile:
Thank you!
Revisited it now and probably easiest/better solution for dim/bright the dashboard:
            command: 'dim',
            action: function(e) {
                document.getElementsByTagName("BODY")[0].style.filter = "brightness(0.5)";
            command: 'bright',
                document.getElementsByTagName("BODY")[0].style.filter = "brightness(1)";
Hya,
installed it on my bare metal, and when i access FQDN/local/tileboard/index.html i receive the following screen:
ACCESS TOKEN
Error while receiving access token
by config.js, i have:
   tileMargin: 6,
   serverUrl: 'http://' + location.hostname + ':8123',
   wsUrl: 'ws://' + location.hostname + ':8123/api/websocket',
   authToken: null, // optional long-lived token (CAUTION: only if TileBoard is not exposed to the internet)
   //googleApiKey: "XXXXXXXXXX", // Required if you are using Google Maps for device tracker
   //mapboxToken: "XXXXXXXXXX", // Required if you are using Mapbox for device tracker
   debug: false, // Prints entities and state change info to the console.
how to use the authentication scheme used by HA?
thx in advance!
Create Longlived token in HA and copy it to the authToken setting.
@Romkabouter, yes, but as it’t exposed on the internet, i would prefer the traditional authentication.
There is no login system available for tileboard.
If you use HA on the same machine, I suggest using the HA Addon, fill in a port (8090 for instance).
If you do not open that port for the internet, you do not have to worry.
@Romkabouter not the same machine and Addon seams not being available for my HA version - bare metal.
Ok, so don’t expose that machine to the internet :slight_smile:
In general: Tileboard has no login system so do not expose it to the net
i have HA and tileboard on the same machine now. And tileboard home directory no longer under www (FQDN/local/tileboard). Any suggestion?
I tried via apache:
        Alias /tileboard/ /var/homeassistant/.homeassistant/tileboard/
        <location /tileboard/>
             AuthType Basic
             AuthName "Tileboard access"
             AuthUserFile /etc/apache2/.htpasswd
             DirectoryIndex index.html
             Require valid-user
             Order deny,allow
             Allow from all
       </location>
but it’s not working…
@resoai regarding not deploying under the www directory (fqdn/local/tileboard), could you explain how to have it under other directory being accessed under a different port, like 8133?
I’m really not finding out hw to deploy it.
and how:
  • TileBoard will be available at http://HASS_IP:8123/local/tileboard/index.html and will prompt you for your login credentials after restarting Home Assistant.
does it works?
Thx in advance.
maybe someone has some idea how it works and can help me?
You can install TileBoared as an add-on.
i’m on bare metal. no supervisor, so, no addons store.
Install Nginx and serve it as any other webpage on the port you want.
i’m using apache2.
Used:
<VirtualHost *:8124>
        ServerName FQDN
        ServerAdmin webmaster@FDQN
        DocumentRoot /var/homeassistant/homeassistant/tileboard
        LogLevel debug
        ErrorLog ${APACHE_LOG_DIR}/ssl_engine.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        SSLEngine on
        SSLCACertificateFile   myprivateCA
        SSLCertificateKeyFile  myserverprivatekey
        SSLCertificateFile     myserverprivatepem
        SSLProtocol -all +TLSv1.2
        #SSLProtocol all -SSLv3 -TLSv1.3
        #SSLProtocol all -TLSv1.3
        # require certificate
        SSLVerifyClient none
        SSLVerifyDepth 1
        <IfModule maxminddb_module>
                MaxMindDBEnable On
                MaxMindDBFile CITY_DB /usr/share/GeoIP/GeoLite2-City.mmdb
                MaxMindDBFile COUNTRY_DB /usr/share/GeoIP/GeoLite2-Country.mmdb
                MaxMindDBEnv MM_CONTINENT_CODE          COUNTRY_DB/continent/code
                MaxMindDBEnv MM_CONTINENT_NAME          COUNTRY_DB/continent/names/en
                MaxMindDBEnv MM_COUNTRY_CODE            COUNTRY_DB/country/iso_code
                MaxMindDBEnv MM_COUNTRY_NAME            COUNTRY_DB/country/names/en
                SetEnvIf MM_COUNTRY_CODE ^(CN|RU|UA|AL) BlockCountry
                <Location />
                        <RequireAll>
                        Require all granted
                        Require not env BlockCountry
                        Require ip 192.168.80.0/24
                        </RequireAll>
                </Location>
        </IfModule>
        <IfModule mod_headers.c>
                Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; nosniff; SAMEORIGIN"
        </IfModule>
       <location />
             AuthName "TileBoard"
             AuthType Basic
             Require valid-user
             Order deny,allow
             Allow from all
       </location>
</VirtualHost>
worked.
@resoai
do you have some time? maybe you can help me here:
Hi, I haven’t found a solution to my problem, so please help me. As MEDIA_PLAYER add the ability to select playlist from disk? I mean lullabies for children :slight_smile: Or is it possible to stream from music apple? I miss the source button and don’t know how to do it. And thanks for the great dashboard!
I’m trying to use the script tile:
         position: [0, 2],
         type: TYPES.SCRIPT,
         title: 'Skip 30',
         icons: {
            on: "mdi-gate",
            off: "mdi-gate"
         state: false,
         variables: { entity_id: 'media_player.morning_news', interval: '30' },
I can’t get the tile to pass variables to the script. My script needs ‘entity_id’ and ‘interval’. This is my script:
skip:
    alias: skip
    sequence:
      - service: media_player.media_seek
        data_template:
          entity_id: "{{ entity_id }}"
       #  seek_position: "{{ state_attr(entity, 'media_position') | float + interval }}"
          seek_position: "{{ ( as_timestamp(now()) - as_timestamp(state_attr(entity_id, 'media_position_updated_at')) + state_attr(entity_id, 'media_position') ) | float + interval }}"
The log shows the 'entity_id' is undefined' error when I tap the tile:
2021-09-03 09:35:20 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'entity_id' is undefined when rendering '{{ ( as_timestamp(now()) - as_timestamp(state_attr(entity_id, 'media_position_updated_at')) + state_attr(entity_id, 'media_position') ) | float + interval }}'
2021-09-03 09:35:20 ERROR (MainThread) [homeassistant.components.script.skip] skip: Error executing script. Error for call_service at pos 1: Error rendering data template: UndefinedError: 'entity_id' is undefined
2021-09-03 09:35:20 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
What am I doing wrong here? How do I pass variables from a tile to a script? I feel like I’m missing something simple.
Thanks.
Edit:
I’m not seeing how the code block in main.js passes variables to the script:
$scope.callScript = function (item, entity) {
      sendItemData(item, {
         type: "call_service",
         domain: "script",
         service: "turn_on",
         service_data: {
            entity_id: item.id
