TileBoard - New dashboard for Homeassistant
What are you trying to achieve? What is the use case?
When myself or my wife are home, I want to show all the pages (including each other’s locations, cameras etc)
When the cat sitter comes in (or any other guest), I want to hide all that stuff and not give them control of the house, but just give them an alarm control panel to disarm the alarm
Why not create two separate dashboard which would be independent?
That could work - what and use Fully Kiosk to move between the two based on presence?
Yes, you could inject different JS via Fully (path to different config)
We have also added an attribute hidden to group definition which can be a function:
This way you could return true/false depending on the sensor value or anything else you wish :slight_smile:
hidden: function() { return this.parseFieldValue("&alarm.home.state") === "off" }
Has anyone successfully implemented the weather forecast tile with the weather.yweather (yahoo weather) entity?
The forecast data in HA JSON comes through as:
  "temperature": 64,
  "humidity": 66,
  "wind_speed": 4.35,
  "forecast": [
      "datetime": "19 Jul 2018",
      "temperature": 82,
      "templow": 57,
      "condition": "sunny"
      "datetime": "20 Jul 2018",
      "temperature": 81,
      "templow": 60,
      "condition": "cloudy"
I can’t seem to get the tiles config.js to read the forecast correctly. I’ve tried to use
var forecast = "&weather.yweather.attributes.forecast[" + id + "].temperature";
but it doesn’t parse correctly and it returns with
[object Object], [object Object], [object Object],...
Thanks in advance if anyone could offer suggestions!
Ah okay perfect - I’ll try that and see how I go - thanks…
Quick other question - is there a file for displaying a HA timer?
Just use a sensor tile.
Is anyone using this on a 7" fire tablet? Just wondering what tile size and margins work best for it
Is there a tile to display a plain text box? I’m trying to display a Dark Sky weather summary but only option i see is through the text list tile that doesn’t wrap text. Have to make it Width 10 to get it to display a short sentence.
I also run tileboard on apache (yet only accessible locally).
Redirecting based on browser or width might be working. For now I’m using the /?configuration provided.
You can decrease fontSize. Also, why not to consider putting it into header (top right)?
I have an old Nexus 7 which could have the same resolution. Here is the config that I’m using for it:
tileSize: 136,
tileMargin: 6,
groupMarginCss: '10px',
customTheme: CUSTOM_THEMES.COMPACT,
entitySize: ENTITY_SIZES.SMALL,
Sorry, I meant for Dark Sky ‘daily_summary’ and ‘hour_summary’ which is an entire sentence, for e.g. “No precipitation throughout the week, with high temperatures falling to 16°C on Sunday.”. But i have started using the header for the weather summary and loving it! Only thing i missed when i switched over from Home Assistant Control Panel.
Currently looks like this
I have been drooling over this since the thread started.
@resoai do you think you will put out a Docker container for the project?
I honestly see absolutely no reason for it. This is simply an HTML page.
My use-case was to get it going on my Synology. Ill have a go over the weekend and see if i can get it going without.
If you’re using Docker, you should be mapping a directory so HASS config files persist. The tile board files go in a sub directory in the www directory. If you don’t have a www directory, create one where your configuration.yaml file lives.
I use HASS in Docker in my qnap.
Here is a special tile for those who have screensaver configured:
    position: [0, 0],
    type: TYPES.CUSTOM,
    state: false,
    title: 'Screensaver',
    icon: 'mdi-image',
    action: function (item, entity) {
        if (CONFIG.screensaver) {
            var cam = ['_qNhxxo9rVU', 'ZqnraG3SsjM', 'ZqnraG3SsjM', 'ECQ0PM8Iqq4', 'DuTc5SOKE98', 'lYRf2jFX6e8', '4EH7ex-MzeE', 'XZT-MenNSLs'];
            var url = 'https://youtube.com/embed/' + cam[Math.floor((Math.random() * cam.length))] + '?autoplay=1&controls=0&rel=0&mute=1';
            CONFIG.screensaver.leftTop = [{
                type: SCREENSAVER_ITEMS.CUSTOM_HTML,
                html: '<iframe style="position: absolute; width: 108%; height: 112%; pointer-events: none;" src="' + url + '" frameborder="0" allow="autoplay *; fullscreen *" allowfullscreen="true"></iframe>',
                styles: {position: 'fixed', zIndex: -99, top: 0, left: 0, right: 0, bottom: 0, margin: '-6% -4%'}
            window.showScreensaver();
This will start a screensaver with a random YouTube video (I have a list of webcams from Odessa, the city I was born in) as a background.
