Time gets somehow converted to numeric
Unsure if this goes here or in a different category, happy to move it.
I do have this entity from a Google Fit integration that appears to be time (as I want it to be)
But when I check the history (or I try to use it in a card) then it shows as numeric
I would obviously like to use 08:48h instead of 8h because 8h its just not an accurate measurement. Any idea of what is going wrong?
The sensor has a unit_of_measurement and it’s set to hours. The moment a sensor is assigned a unit_of_measurement the UI will present its history graph as a line chart (as opposed to the default bar chart). The unit is “hours” and, so, there you have it.
okay, and what should be the unit_of_measurement instead ?
Unless you have control over unit_of_measurement there’s not much you can do. If you do have control over it, remove it entirely and then you will get a bar chart. If a bar chart is not what you want then you’ve reached an impasse; none of the default history charts suit your needs. In that case, you may wish to explore using a custom graph card such as ApexCharts.
