EDIT: Is this such a freak occurrence that I should just give up? No responses here, and I’m googling my fingers off finding nothing… not complaining, I’m new to HA and would just really like to know if this is in the realm of “possibly fixable”, or if I need to make other IoT decisions.
OK, so… in the ongoing saga of devices which register, but contain no entities, I seem to have found the problem, see: the header of this topic
The only change I can see after acquiring a USB extension cable & improving connectivity is that, in stead of a single “Timed out while waiting for a response” message, there’s several (oh, and also, under “Z-Wave Info”, the device is listed as “Ready: Yes” instead of “No”).
Searching the forums, the most similar, reasonably recent situation I’ve found is this one, in which the poster mentions the network key. This is well above my skill level, but is it something that might be relevant to my issue?
Inclusion debug log below, the result is the same when re-interviewing. Healing also doesn’t help, and I’ve reloaded Z-Wave, restarted HASS, and even rebooted the Pi, also to no avail.
Thanks in advance for any help!!
(If bumping my issue in this way is frowned upon, just let me know; I am simply trying to narrow my questions & make them as accurate as I can )
Subscribed to Z-Wave JS Log Messages…
2022-10-29T06:40:05.025Z CNTRLR » [Node 021] pinging the node...
2022-10-29T06:40:05.040Z SERIAL » 0x01080013150100254693 (10 bytes)
2022-10-29T06:40:05.042Z DRIVER » [Node 021] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 70
└─[NoOperationCC]
2022-10-29T06:40:05.045Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:05.050Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:05.051Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:05.053Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:06.116Z SERIAL « 0x010700134601006bc7 (9 bytes)
2022-10-29T06:40:06.119Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:06.121Z DRIVER « [REQ] [SendData]
callback id: 70
transmit status: NoAck
2022-10-29T06:40:06.134Z CNTRLR [Node 021] The node did not respond after 1 attempts. It is probably asleep, m
oving its messages to the wakeup queue.
2022-10-29T06:40:06.135Z CNTRLR [Node 021] The node is now asleep.
2022-10-29T06:40:06.145Z CNTRLR [Node 021] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-10-29T06:40:06.153Z SERIAL » 0x010500611547c9 (7 bytes)
2022-10-29T06:40:06.154Z DRIVER » [REQ] [RemoveFailedNode]
payload: 0x1547
2022-10-29T06:40:06.157Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:06.163Z SERIAL « 0x01040161009b (6 bytes)
2022-10-29T06:40:06.165Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:06.166Z DRIVER « [RES] [RemoveFailedNode]
payload: 0x00
2022-10-29T06:40:07.084Z SERIAL « 0x010500614701dd (7 bytes)
2022-10-29T06:40:07.088Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:07.090Z DRIVER « [REQ] [RemoveFailedNode]
payload: 0x4701
2022-10-29T06:40:07.101Z CNTRLR [Node 021] [-] [Manufacturer Specific] manufacturerId (was 2) [Endpoint 0]
2022-10-29T06:40:07.103Z CNTRLR [Node 021] [Manufacturer Specific] manufacturerId: metadata updat [Endpoint 0]
ed
2022-10-29T06:40:07.105Z CNTRLR [Node 021] [-] [Manufacturer Specific] productType (was 32773) [Endpoint 0]
2022-10-29T06:40:07.107Z CNTRLR [Node 021] [Manufacturer Specific] productType: metadata updated [Endpoint 0]
2022-10-29T06:40:07.109Z CNTRLR [Node 021] [-] [Manufacturer Specific] productId (was 2) [Endpoint 0]
2022-10-29T06:40:07.110Z CNTRLR [Node 021] [Manufacturer Specific] productId: metadata updated [Endpoint 0]
2022-10-29T06:40:07.112Z CNTRLR [Node 021] [-] [Manufacturer Specific] interviewComple [Endpoint 0] [internal]
te (was true)
2022-10-29T06:40:07.113Z CNTRLR [Node 021] [-] [Version] interviewComplete (was true) [Endpoint 0] [internal]
2022-10-29T06:40:07.115Z CNTRLR [Node 021] [-] [Manufacturer Proprietary] interviewCom [Endpoint 0] [internal]
plete (was true)
2022-10-29T06:40:08.821Z CNTRLR Starting inclusion process with strategy Default...
2022-10-29T06:40:08.833Z SERIAL » 0x0105004ac14839 (7 bytes)
2022-10-29T06:40:08.835Z DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 72
2022-10-29T06:40:08.838Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:08.840Z SERIAL « 0x0107004a48010000fb (9 bytes)
2022-10-29T06:40:08.842Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:08.845Z DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 72
2022-10-29T06:40:08.851Z CNTRLR The controller is now ready to add nodes
2022-10-29T06:40:11.246Z SERIAL « 0x010c004a48021505040804917208 (14 bytes)
2022-10-29T06:40:11.250Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:11.252Z DRIVER « [REQ] [AddNodeToNetwork]
status: NodeFound
callback id: 72
2022-10-29T06:40:11.258Z DRIVER handling request AddNodeToNetwork (74)
2022-10-29T06:40:11.258Z DRIVER 1 handler registered!
2022-10-29T06:40:11.259Z DRIVER invoking handler #0
2022-10-29T06:40:11.260Z CNTRLR handling add node request (status = NodeFound)
2022-10-29T06:40:11.262Z SERIAL « 0x010c004a48031505040804917209 (14 bytes)
2022-10-29T06:40:11.263Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:11.265Z DRIVER « [REQ] [AddNodeToNetwork]
status: AddingSlave
callback id: 72
2022-10-29T06:40:11.267Z DRIVER handling request AddNodeToNetwork (74)
2022-10-29T06:40:11.268Z DRIVER 1 handler registered!
2022-10-29T06:40:11.269Z DRIVER invoking handler #0
2022-10-29T06:40:11.270Z CNTRLR handling add node request (status = AddingSlave)
2022-10-29T06:40:11.274Z DRIVER the message was handled
2022-10-29T06:40:11.718Z SERIAL « 0x0107004a48051500ea (9 bytes)
2022-10-29T06:40:11.720Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:11.723Z DRIVER « [REQ] [AddNodeToNetwork]
status: ProtocolDone
callback id: 72
2022-10-29T06:40:11.728Z DRIVER handling request AddNodeToNetwork (74)
2022-10-29T06:40:11.729Z DRIVER 1 handler registered!
2022-10-29T06:40:11.731Z DRIVER invoking handler #0
2022-10-29T06:40:11.732Z CNTRLR handling add node request (status = ProtocolDone)
2022-10-29T06:40:11.733Z CNTRLR finishing inclusion process...
2022-10-29T06:40:11.745Z SERIAL » 0x0105004ac5493c (7 bytes)
2022-10-29T06:40:11.746Z DRIVER » [REQ] [AddNodeToNetwork]
action: Stop
high power: true
network wide: true
callback id: 73
2022-10-29T06:40:11.749Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:11.798Z SERIAL « 0x0107004a49061500e8 (9 bytes)
2022-10-29T06:40:11.799Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:11.802Z DRIVER « [REQ] [AddNodeToNetwork]
status: Done
callback id: 73
2022-10-29T06:40:11.821Z SERIAL » 0x0105004ac50075 (7 bytes)
2022-10-29T06:40:11.822Z DRIVER » [REQ] [AddNodeToNetwork]
action: Stop
high power: true
network wide: true
callback id: 0
2022-10-29T06:40:11.825Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:11.842Z CNTRLR The inclusion process was stopped
2022-10-29T06:40:11.845Z CNTRLR finished adding node 21:
basic device class: Routing Slave
generic device class: Thermostat
specific device class: Setpoint Thermostat
supported CCs:
· Manufacturer Specific (0x72)
· Multi Command (0x8f)
· Thermostat Setpoint (0x43)
· Version (0x86)
· Manufacturer Proprietary (0x91)
controlled CCs:
2022-10-29T06:40:11.850Z CNTRLR » [Node 021] Assigning SUC return route...
2022-10-29T06:40:11.861Z SERIAL » 0x01050051154af4 (7 bytes)
2022-10-29T06:40:11.864Z DRIVER » [Node 021] [REQ] [AssignSUCReturnRoute]
payload: 0x154a
2022-10-29T06:40:11.868Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:11.877Z SERIAL « 0x0104015101aa (6 bytes)
2022-10-29T06:40:11.879Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:11.881Z DRIVER « [RES] [AssignSUCReturnRoute]
was executed: true
2022-10-29T06:40:12.579Z SERIAL « 0x010500514a00e1 (7 bytes)
2022-10-29T06:40:12.582Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.585Z DRIVER « [REQ] [AssignSUCReturnRoute]
callback id: 74
transmit status: OK
2022-10-29T06:40:12.596Z CNTRLR [Node 021] Beginning interview - last completed stage: None
2022-10-29T06:40:12.597Z CNTRLR [Node 021] new node, doing a full interview...
2022-10-29T06:40:12.599Z CNTRLR » [Node 021] querying protocol info...
2022-10-29T06:40:12.606Z DRIVER the message was handled
2022-10-29T06:40:12.610Z SERIAL » 0x0104004115af (6 bytes)
2022-10-29T06:40:12.611Z DRIVER » [REQ] [GetNodeProtocolInfo]
payload: 0x15
2022-10-29T06:40:12.616Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:12.618Z SERIAL « 0x01090141518c0004080463 (11 bytes)
2022-10-29T06:40:12.619Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.621Z DRIVER « [RES] [GetNodeProtocolInfo]
payload: 0x518c00040804
2022-10-29T06:40:12.626Z CNTRLR « [Node 021] received response for protocol info:
node type: End Node
is always listening: false
is frequent listening: false
can route messages: true
supports security: false
supports beaming: false
maximum data rate: 40000 kbps
protocol version: 1
2022-10-29T06:40:12.627Z CNTRLR [Node 021] The node is now awake.
2022-10-29T06:40:12.629Z CNTRLR [Node 021] Interview stage completed: ProtocolInfo
2022-10-29T06:40:12.630Z CNTRLR » [Node 021] querying node info...
2022-10-29T06:40:12.640Z SERIAL » 0x01040060158e (6 bytes)
2022-10-29T06:40:12.641Z DRIVER » [Node 021] [REQ] [RequestNodeInfo]
payload: 0x15
2022-10-29T06:40:12.644Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:12.648Z SERIAL « 0x01040160019b (6 bytes)
2022-10-29T06:40:12.650Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.652Z DRIVER « [RES] [RequestNodeInfo]
payload: 0x01
2022-10-29T06:40:12.678Z SERIAL « 0x010b00498415050408049172c2 (13 bytes)
2022-10-29T06:40:12.681Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.683Z DRIVER « [Node 021] [REQ] [ApplicationUpdateRequest]
payload: 0x15050408049172
2022-10-29T06:40:12.693Z CNTRLR « [Node 021] node info received
supported CCs:
2022-10-29T06:40:12.694Z CNTRLR [Node 021] Interview stage completed: NodeInfo
2022-10-29T06:40:12.696Z CNTRLR [Node 021] Interviewing Manufacturer Specific...
2022-10-29T06:40:12.696Z CNTRLR » [Node 021] querying manufacturer information...
2022-10-29T06:40:12.704Z SERIAL » 0x0109001315027204254bea (11 bytes)
2022-10-29T06:40:12.705Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 75
└─[ManufacturerSpecificCCGet]
2022-10-29T06:40:12.707Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:12.712Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:12.713Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.714Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:12.729Z SERIAL « 0x010700134b000002a2 (9 bytes)
2022-10-29T06:40:12.730Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.732Z DRIVER « [REQ] [SendData]
callback id: 75
transmit status: OK
2022-10-29T06:40:12.740Z SERIAL « 0x010e000400150872050002800500021a (16 bytes)
2022-10-29T06:40:12.741Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.744Z CNTRLR [Node 021] [Manufacturer Specific] manufacturerId: metadata updat [Endpoint 0]
ed
2022-10-29T06:40:12.746Z CNTRLR [Node 021] [+] [Manufacturer Specific] manufacturerId: 2 [Endpoint 0]
2022-10-29T06:40:12.747Z CNTRLR [Node 021] [Manufacturer Specific] productType: metadata updated [Endpoint 0]
2022-10-29T06:40:12.748Z CNTRLR [Node 021] [+] [Manufacturer Specific] productType: 32773 [Endpoint 0]
2022-10-29T06:40:12.750Z CNTRLR [Node 021] [Manufacturer Specific] productId: metadata updated [Endpoint 0]
2022-10-29T06:40:12.751Z CNTRLR [Node 021] [+] [Manufacturer Specific] productId: 2 [Endpoint 0]
2022-10-29T06:40:12.752Z DRIVER « [Node 021] [REQ] [ApplicationCommand]
└─[ManufacturerSpecificCCReport]
manufacturer id: 0x02
product type: 0x8005
product id: 0x02
2022-10-29T06:40:12.758Z CNTRLR « [Node 021] received response for manufacturer information:
manufacturer: Danfoss (0x02)
product id: 0x02
2022-10-29T06:40:12.759Z CNTRLR [Node 021] [+] [Manufacturer Specific] interviewComple [Endpoint 0] [internal]
te: true
2022-10-29T06:40:12.761Z CNTRLR [Node 021] Interviewing Version...
2022-10-29T06:40:12.761Z CNTRLR » [Node 021] querying the CC version for Version...
2022-10-29T06:40:12.769Z SERIAL » 0x010a00131503861386254c8a (12 bytes)
2022-10-29T06:40:12.771Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 76
└─[VersionCCCommandClassGet]
CC: Version
2022-10-29T06:40:12.773Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:12.778Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:12.778Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.780Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:12.795Z SERIAL « 0x010700134c000002a5 (9 bytes)
2022-10-29T06:40:12.796Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:12.798Z DRIVER « [REQ] [SendData]
callback id: 76
transmit status: OK
2022-10-29T06:40:13.849Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:13.850Z CNTRLR [Node 021] CC version query for Version timed out - assuming the node supports
version 1...
2022-10-29T06:40:13.852Z CNTRLR » [Node 021] querying node versions...
2022-10-29T06:40:13.860Z SERIAL » 0x0109001315028611254d0d (11 bytes)
2022-10-29T06:40:13.861Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 77
└─[VersionCCGet]
2022-10-29T06:40:13.863Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:13.868Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:13.869Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:13.871Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:13.885Z SERIAL « 0x010700134d000002a4 (9 bytes)
2022-10-29T06:40:13.886Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:13.888Z DRIVER « [REQ] [SendData]
callback id: 77
transmit status: OK
2022-10-29T06:40:14.933Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:14.935Z CNTRLR » [Node 021] querying CC versions...
2022-10-29T06:40:14.936Z CNTRLR » [Node 021] querying the CC version for Manufacturer Specific...
2022-10-29T06:40:14.950Z SERIAL » 0x010a00131503861372254e7c (12 bytes)
2022-10-29T06:40:14.952Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 78
CC: Manufacturer Specific
2022-10-29T06:40:14.954Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:14.958Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:14.960Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:14.961Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:14.975Z SERIAL « 0x010700134e000002a7 (9 bytes)
2022-10-29T06:40:14.977Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:14.979Z DRIVER « [REQ] [SendData]
callback id: 78
transmit status: OK
2022-10-29T06:40:16.022Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:16.024Z CNTRLR [Node 021] CC version query for Manufacturer Specific timed out - assuming the
node supports version 1...
2022-10-29T06:40:16.025Z CNTRLR [Node 021] skipping query for Multi Command (0x8f) because max implemented v
ersion is 1
2022-10-29T06:40:16.027Z CNTRLR » [Node 021] querying the CC version for Thermostat Setpoint...
2022-10-29T06:40:16.039Z SERIAL » 0x010a00131503861343254f4c (12 bytes)
2022-10-29T06:40:16.040Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 79
CC: Thermostat Setpoint
2022-10-29T06:40:16.043Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:16.047Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:16.049Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:16.050Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:16.065Z SERIAL « 0x010700134f000002a6 (9 bytes)
2022-10-29T06:40:16.066Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:16.068Z DRIVER « [REQ] [SendData]
callback id: 79
transmit status: OK
2022-10-29T06:40:17.110Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:17.111Z CNTRLR [Node 021] CC version query for Thermostat Setpoint timed out - assuming the n
2022-10-29T06:40:17.113Z CNTRLR [Node 021] skipping query for Manufacturer Proprietary (0x91) because max im
plemented version is 1
2022-10-29T06:40:17.115Z CNTRLR » [Node 021] querying if Z-Wave Software Get is supported...
2022-10-29T06:40:17.127Z SERIAL » 0x0109001315028615255014 (11 bytes)
2022-10-29T06:40:17.128Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 80
└─[VersionCCCapabilitiesGet]
2022-10-29T06:40:17.131Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:17.135Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:17.136Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:17.138Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:17.152Z SERIAL « 0x0107001350000003b8 (9 bytes)
2022-10-29T06:40:17.153Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:17.155Z DRIVER « [REQ] [SendData]
callback id: 80
transmit status: OK
2022-10-29T06:40:18.198Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:18.200Z CNTRLR [Node 021] [+] [Version] interviewComplete: true [Endpoint 0] [internal]
2022-10-29T06:40:18.210Z CNTRLR [Node 021] Embedded device config loaded
2022-10-29T06:40:18.212Z CNTRLR [Node 021] Interviewing Thermostat Setpoint...
2022-10-29T06:40:18.213Z CNTRLR » [Node 021] retrieving supported setpoint types...
2022-10-29T06:40:18.220Z SERIAL » 0x01090013150243042551c1 (11 bytes)
2022-10-29T06:40:18.221Z DRIVER » [Node 021] [REQ] [SendData]
│ callback id: 81
└─[ThermostatSetpointCCSupportedGet]
2022-10-29T06:40:18.226Z SERIAL « [ACK] (0x06)
2022-10-29T06:40:18.229Z SERIAL « 0x0104011301e8 (6 bytes)
2022-10-29T06:40:18.230Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:18.232Z DRIVER « [RES] [SendData]
was sent: true
2022-10-29T06:40:18.244Z SERIAL « 0x0107001351000002b8 (9 bytes)
2022-10-29T06:40:18.245Z SERIAL » [ACK] (0x06)
2022-10-29T06:40:18.247Z DRIVER « [REQ] [SendData]
callback id: 81
transmit status: OK
2022-10-29T06:40:19.288Z CNTRLR [Node 021] Timed out while waiting for a response from the node (ZW0201)
2022-10-29T06:40:19.290Z CNTRLR [Node 021] Querying supported setpoint types timed out, skipping interview...
2022-10-29T06:40:19.292Z CNTRLR [Node 021] ManufacturerProprietaryCC: skipping interview refresh because the m
atching proprietary CC is not implemented...
2022-10-29T06:40:19.294Z CNTRLR [Node 021] [+] [Manufacturer Proprietary] interviewCom [Endpoint 0] [internal]
plete: true
2022-10-29T06:40:19.297Z CNTRLR [Node 021] Interview stage completed: CommandClasses
2022-10-29T06:40:19.299Z CNTRLR [Node 021] Interview stage completed: OverwriteConfig
2022-10-29T06:40:19.300Z CNTRLR [Node 021] Interview completed
2022-10-29T06:40:19.301Z CNTRLR [Node 021] The node is ready to be used
