Thanks for responding
and for letting me know which info I should share
Did a re-interview, here’s the log:
Subscribed to Z-Wave JS Log Messages…
2022-10-24T19:51:49.605Z CNTRLR « [Node 024] Received updated node info
2022-10-24T19:51:49.610Z CNTRLR [Node 024] Node does not send unsolicited updates; refreshing actuator and sen
sor values...
2022-10-24T19:51:51.069Z CNTRLR [Node 024] Beginning interview - last completed stage: None
2022-10-24T19:51:51.071Z CNTRLR [Node 024] new node, doing a full interview...
2022-10-24T19:51:51.074Z CNTRLR » [Node 024] querying protocol info...
2022-10-24T19:51:51.103Z CNTRLR « [Node 024] received response for protocol info:
basic device class: Routing Slave
generic device class: Thermostat
specific device class: Setpoint Thermostat
node type: End Node
is always listening: false
is frequent listening: false
can route messages: true
supports security: false
supports beaming: false
maximum data rate: 40000 kbps
protocol version: 1
2022-10-24T19:51:51.105Z CNTRLR [Node 024] The node is now asleep.
2022-10-24T19:51:51.109Z CNTRLR [Node 024] Interview stage completed: ProtocolInfo
2022-10-24T19:51:51.110Z CNTRLR » [Node 024] querying node info...
2022-10-24T19:53:00.574Z CNTRLR « [Node 024] Received updated node info
2022-10-24T19:53:00.577Z CNTRLR [Node 024] The node is now awake.
2022-10-24T19:53:00.758Z CNTRLR « [Node 024] node info received
supported CCs:
· Manufacturer Proprietary
· Manufacturer Specific
2022-10-24T19:53:00.761Z CNTRLR [Node 024] Interview stage completed: NodeInfo
2022-10-24T19:53:00.762Z CNTRLR [Node 024] Interviewing Manufacturer Specific...
2022-10-24T19:53:00.763Z CNTRLR » [Node 024] querying manufacturer information...
2022-10-24T19:53:00.973Z CNTRLR « [Node 024] received response for manufacturer information:
manufacturer: Danfoss (0x02)
product type: 0x8005
product id: 0x02
2022-10-24T19:53:00.975Z CNTRLR [Node 024] Interviewing Version...
2022-10-24T19:53:00.976Z CNTRLR » [Node 024] querying the CC version for Version...
2022-10-24T19:53:02.190Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:02.196Z CNTRLR [Node 024] CC version query for Version timed out - assuming the node supports
version 1...
2022-10-24T19:53:02.199Z CNTRLR » [Node 024] querying node versions...
2022-10-24T19:53:03.332Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:03.333Z CNTRLR » [Node 024] querying CC versions...
2022-10-24T19:53:03.335Z CNTRLR » [Node 024] querying the CC version for Manufacturer Specific...
2022-10-24T19:53:04.489Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:04.491Z CNTRLR [Node 024] CC version query for Manufacturer Specific timed out - assuming the
node supports version 1...
2022-10-24T19:53:04.495Z CNTRLR [Node 024] skipping query for Multi Command (0x8f) because max implemented v
ersion is 1
2022-10-24T19:53:04.497Z CNTRLR » [Node 024] querying the CC version for Thermostat Setpoint...
2022-10-24T19:53:05.633Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:05.635Z CNTRLR [Node 024] CC version query for Thermostat Setpoint timed out - assuming the n
2022-10-24T19:53:05.636Z CNTRLR [Node 024] skipping query for Manufacturer Proprietary (0x91) because max im
plemented version is 1
2022-10-24T19:53:05.638Z CNTRLR » [Node 024] querying if Z-Wave Software Get is supported...
2022-10-24T19:53:06.862Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:06.872Z CNTRLR [Node 024] Embedded device config loaded
2022-10-24T19:53:06.875Z CNTRLR [Node 024] Interviewing Thermostat Setpoint...
2022-10-24T19:53:06.876Z CNTRLR » [Node 024] retrieving supported setpoint types...
2022-10-24T19:53:08.003Z CNTRLR [Node 024] Timed out while waiting for a response from the node (ZW0201)
2022-10-24T19:53:08.006Z CNTRLR [Node 024] Querying supported setpoint types timed out, skipping interview...
2022-10-24T19:53:08.009Z CNTRLR [Node 024] ManufacturerProprietaryCC: skipping interview refresh because the m
atching proprietary CC is not implemented...
2022-10-24T19:53:08.011Z CNTRLR [Node 024] Interview stage completed: CommandClasses
2022-10-24T19:53:08.012Z CNTRLR [Node 024] Interview stage completed: OverwriteConfig
2022-10-24T19:53:08.014Z CNTRLR [Node 024] Interview completed
2022-10-24T19:53:08.015Z CNTRLR [Node 024] The node is ready to be used
Here’s a freshly downloaded diagnostics file:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.10.5",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Copenhagen",
"os_name": "Linux",
"os_version": "5.15.61-v8",
"supervisor": "2022.10.0",
"host_os": "Home Assistant OS 9.2",
"docker_version": "20.10.17",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zwave_js",
"name": "Z-Wave",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zwave_js",
"requirements": [
"pyserial==3.5",
"zwave-js-server-python==0.43.0"
"codeowners": [
"@home-assistant/z-wave"
"dependencies": [
"usb",
"http",
"websocket_api"
"iot_class": "local_push",
"usb": [
"vid": "0658",
"pid": "0200",
"known_devices": [
"Aeotec Z-Stick Gen5+",
"Z-WaveMe UZB"
"vid": "10C4",
"pid": "8A2A",
"description": "*z-wave*",
"known_devices": [
"Nortek HUSBZB-1"
"zeroconf": [
"_zwave-js-server._tcp.local."
"loggers": [
"zwave_js_server"
"is_built_in": true
"data": {
"versionInfo": {
"driverVersion": "10.3.0",
"serverVersion": "1.24.0",
"minSchemaVersion": 0,
"maxSchemaVersion": 24
"entities": [],
"state": {
"nodeId": 24,
"index": 0,
"status": 1,
"ready": false,
"isListening": false,
"isRouting": true,
"isSecure": false,
"manufacturerId": 2,
"productId": 2,
"productType": 32773,
"deviceConfig": {
"filename": "/data/db/devices/0x0002/lc-13.json",
"isEmbedded": true,
"manufacturer": "Danfoss",
"label": "LC-13",
"description": "Living Connect Z Thermostat",
"devices": [
"productType": 5,
"productId": 4
"productId": 1
"productId": 2
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"associations": {},
"compat": {
"queryOnWakeup": [
"Battery",
"get"
"Thermostat Setpoint",
"get",
1
"label": "LC-13",
"interviewAttempts": 1,
"endpoints": [
"nodeId": 24,
"index": 0,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 8,
"label": "Thermostat"
"specific": {
"key": 4,
"label": "Setpoint Thermostat"
"mandatorySupportedCCs": [
114,
143,
67,
134
"mandatoryControlledCCs": []
"commandClasses": [
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 143,
"name": "Multi Command",
"version": 1,
"isSecure": false
"id": 67,
"name": "Thermostat Setpoint",
"version": 3,
"isSecure": false
"id": 134,
"name": "Version",
"version": 3,
"isSecure": false
"id": 145,
"name": "Manufacturer Proprietary",
"version": 1,
"isSecure": false
"values": [
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535
"value": 2
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535
"value": 32773
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535
"value": 2
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 0,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions"
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version"
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 0,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version"
"endpoint": 0,
"property": "sdkVersion",
"propertyName": "sdkVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "SDK version"
"endpoint": 0,
"property": "applicationFrameworkAPIVersion",
"propertyName": "applicationFrameworkAPIVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave application framework API version"
"endpoint": 0,
"property": "applicationFrameworkBuildNumber",
"propertyName": "applicationFrameworkBuildNumber",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave application framework API build number"
"endpoint": 0,
"property": "hostInterfaceVersion",
"propertyName": "hostInterfaceVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Serial API version"
"endpoint": 0,
"property": "hostInterfaceBuildNumber",
"propertyName": "hostInterfaceBuildNumber",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Serial API build number"
"endpoint": 0,
"property": "zWaveProtocolVersion",
"propertyName": "zWaveProtocolVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"endpoint": 0,
"property": "zWaveProtocolBuildNumber",
"propertyName": "zWaveProtocolBuildNumber",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol build number"
"endpoint": 0,
"property": "applicationVersion",
"propertyName": "applicationVersion",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Application version"
"endpoint": 0,
"property": "applicationBuildNumber",
"propertyName": "applicationBuildNumber",
"ccVersion": 0,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Application build number"
"isFrequentListening": false,
"maxDataRate": 40000,
"supportedDataRates": [
40000
"protocolVersion": 1,
"supportsBeaming": false,
"supportsSecurity": false,
"nodeType": 1,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 8,
"specific": {
"key": 4,
114,
143,
67,
134
"interviewStage": "ProtocolInfo",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0002:0x8005:0x0002:0.0",
"statistics": {
"commandsTX": 8,
"commandsRX": 1,
"commandsDroppedRX": 0,
"commandsDroppedTX": 1,
"timeoutResponse": 6,
"rtt": 122.6
"highestSecurityClass": -1,
"isControllerNode": false,
"keepAwake": false
