2 of 3 To-do lists have become unavailable upon Home Assistant Restart.
It’s happened twice over the past 3 days. Two of the three to-do lists have become unavailable. I recreated the lists manually, and again two of three became unavailable again. One of the to-do lists seems to be persistent and it was the first list I’d created. Also noticed that the to-do list entity seems to still exist when I try to recreate with the same name e.g. “Smart home ideas”. I’m using 2024.3, HASSOS on RPi4. See dashboard photo showing unavailable to-do lists.
Hi Tom. Here’s a snippet from the logs. I’m not exactly sure what the error is. Any ideas?
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xd3 in position 0: invalid continuation byte
2024-03-11 11:29:42.409 ERROR (MainThread) [homeassistant.components.todo] Error while setting up local_todo platform for todo
File “/usr/local/lib/python3.12/site-packages/ical/component.py”, line 139, in init
super().init(**data)
File “/usr/local/lib/python3.12/site-packages/pydantic/main.py”, line 341, in init
raise validation_error
pydantic.error_wrappers.ValidationError: 1 validation error for Todo root
Failed to validate: 20240309T041627, errors: ([“Expected DATE-TIME TZID value ‘AEST’ to be valid timezone”, “Expected value to match DATE pattern: ‘20240309T041627’”]) (type=value_error)
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 350, in _async_setup_platform
await asyncio.shield(awaitable)
File “/usr/src/homeassistant/homeassistant/components/local_todo/todo.py”, line 71, in async_setup_entry
calendar = IcsCalendarStream.calendar_from_ics(ics)
I faced the same, ToDo list unavailable issue today one only one of my six lists. The logs point to an inability to parse a timestamp, and since I don’t use due dates on this particular list, the error would have been in the creation of a line item.
File "/usr/local/lib/python3.12/site-packages/ical/component.py", line 139, in __init__
super().__init__(**data)
File "/usr/local/lib/python3.12/site-packages/pydantic/main.py", line 341, in __init__
__root__
Failed to validate: 20240311T235415, errors: (["Expected DATE-TIME TZID value 'PDT' to be valid timezone", "Expected value to match DATE pattern: '20240311T235415'"]) (type=value_error)
I’ve lost my “local” ToDo list as well.
Sort of looks like a TimeZone problem (we shifted from CST to CDT on 3/10/2024.
Failed to validate: 20240313T085927, errors: ([“Expected DATE-TIME TZID value ‘CDT’ to be valid timezone”, “Expected value to match DATE pattern: ‘20240313T085927’”]) (type=value_error)
