nodered 1(1 palette i used before to show cameras on homekit doesn’t esist anymore, for this reason i would copy the palette folder from old node red to the new one)
nodered 2 (always in node red i want save some video files temporaly in a folder so i want see node red folder structure to know where to save it)
mariadb (if i restart the minipc hassio start before than mariadb and this give problem to see the recorder, than i need to restart hassio after mariadb has started)
I ran the script for Adguard in my Proxmox setup, it installed and is working fine (I believe) however when I try to integrate it in HA it tells me it failed to connect. Is there some additional setup within Proxmox that needs to happen for HA to recognize the integration?
about nodered i’m have problem to capture a video from an rtsp camera with exec code. If i do the same in nodered included in hassio it works. do you know why?
Before to install Portainer as a LXC , I just run your Webmin install script and it went smoothly ( thanks for your work).
I can connect to webmin IP ( https://ip:10000 ) but i have basic questions ( excuse my ignorance on this ) :
I have a unique proxmox console , no LXC Console .
Webmin is a application that runs on top of the OS, in your case, it’s administrating Proxmox.
It was my intention for Webmin to help administrate LXC’s as the instructions says “run the following in a LXC console.”
The wording helps to differentiate from the Proxmox Shell and the LXC console.
i have changed my dongle with sonoff dongle to check if it works better. i have unistelled lxc and than done all again. Now i get this error with old dongle configured and with sonoff too
