FAQ - How to link the Toilet Exhaust Fan Blueprint With Bathroom Humidity Exhaust Fan Blueprint
First you must create a toggle helper. Go to Settings / Devices & Services / click on the Helpers tab / click Create Helper / and select Toggle
Then input the name you would like to call the toggle helper and select an icon if you like and click create.
Now you have a toggle helper that we can use in both automations. Once you created both automations using the blueprints we then can add the link between the two.
Go into the Bathroom Humidity Exhaust Fan automation. In the “Fan Switch” we will add the toggle helper we just created. Then click save.
Go into the Toilet Exhaust Fan automation. In the by-pass section we will enable option 3 and add the toggle helper into “By-pass Switch - Keep The Fan Current State”. When using this option we can’t enable the auto OFF feature as the Bathroom Humidity Exhaust Fan automation will be controlling it.
Then down the bottom make sure the HA Restart Option is disabled as the Bathroom Humidity Exhaust Fan automation already has a built in HA restart option and is why this one is optional so we can disable it when linking the two. Once done click save.
Your automations will now be linked giving priority to the Bathroom Humidity Exhaust Fan automation.
Enjoy
Blacky ![]()
Back to the FAQ Click Here
