Automation of toilet or bathroom ventilation
Original article : https://community.home-assistant.io/t/toilet-fan-automotion-blueprint/503723
Korean to English translation
(Use Google Translate)
fan, light, humidity sensor * 2
blueprint:
name: "Toilet fan Automation 2"
description: "v2.2.1"
domain: automation
# source_url: ""
input:
toilet_fan:
description: ""
selector:
entity:
domain: fan
toilet_light:
description: ""
selector:
entity:
domain: light
humidity_in:
name: "Toilet humidity sensor"
description: "sensor inside the toilet"
selector:
entity:
domain: sensor
device_class: humidity
humidity_out:
name: "comparative humidity sensor"
description: "sensor outside the toilet"
selector:
entity:
domain: sensor
trigger_over_humidity:
name: "fan Auto On Off Reference Humidity"
description:
"When the humidity in the toilet is higher than the set humidity, the ventilation fan is automatically turned on. (and when the humidity difference is satisfied)\n
When the humidity in the toilet is below the set humidity, the ventilation fan is automatically turned off. (and off when the humidity difference is satisfied)\n
If the fan's maximum operation time is set to 1 or more, automatic turn-on is disabled."
default: 70
selector:
number:
min: 50
max: 90
unit_of_measurement: "%"
fan_on_humidity:
name: "Turn on fan if the humidity difference"
description: "Turn on the fan if the humidity difference between the two sensors is greater than the setting."
default: 30
selector:
number:
min: 5
max: 50
fan_off_humidity:
name: "Turn off fan if the humidity difference"
description: "Turn off the fan when the humidity difference between the two sensors is less than the setting."
default: 20
selector:
number:
min: 5
max: 50
fan_off_time_max:
name: "fan maximum run time"
description:
"Set the maximum fan operation time after turning off the lights.\n
Disable when set to 0.\n
Disable auto turn on when set to 1 or higher"
default: 0
selector:
number:
min: 0
max: 120
unit_of_measurement: "minute"
fan_off_time_min:
name: "fan minimum run time"
description:
"Set the minimum fan operation time after turning off the lights.\n
Disable when set to 0"
default: 0
selector:
number:
min: 0
max: 60
fan_off_time_min_if:
name: "fan minimum run time conditions"
description:
"If more than the set time elapses after the light is turned on, the minimum operation time is used.\n
default: 0
selector:
number:
min: 0
max: 60
- platform: state
entity_id: !input toilet_light
to: "on"
- platform: state
to: "off"
- platform: state
to: "off"
for:
minutes: !input fan_off_time_min
- platform: state
to: "off"
for:
minutes: !input fan_off_time_max
- platform: state
entity_id: !input humidity_in
- platform: state
entity_id: !input humidity_out
- platform: time_pattern
minutes: /1
variables:
toilet_fan: !input toilet_fan
toilet_light: !input toilet_light
humidity_in: !input humidity_in
humidity_out: !input humidity_out
fan_on_humidity: !input fan_on_humidity
fan_off_humidity: !input fan_off_humidity
trigger_over_humidity: !input trigger_over_humidity
fan_off_time_max: !input fan_off_time_max
fan_off_time_min: !input fan_off_time_min
fan_off_time_min_if: !input fan_off_time_min_if
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: !input toilet_fan
state: "off"
sequence:
- service: fan.turn_on
- conditions:
- condition: state
state: "on"
- condition: template
value_template: "{{ float(states[humidity_in].state) < trigger_over_humidity or float(states[humidity_in].state) - float(states[humidity_out].state) <= fan_off_humidity }}"
value_template: "{{ fan_off_time_min == 0 or ( now().timestamp() - trigger.from_state.last_changed.timestamp() ) / 60 < fan_off_time_min_if }}"
sequence:
- service: fan.turn_off
- conditions:
- condition: state
state: "on"
value_template: "{{ fan_off_time_min > 0 }}"
sequence:
- conditions:
- condition: state
state: "on"
value_template: "{{ fan_off_time_max > 0 }}"
sequence:
- conditions:
id:
- timePattern
- changHumidtyIn
- changHumidtyOut
sequence:
- choose:
- conditions:
- condition: state
state: "off"
value_template: "{{ float(states[humidity_in].state) >= trigger_over_humidity }}"
value_template: "{{ float(states[humidity_in].state) - float(states[humidity_out].state) >= fan_on_humidity }}"
value_template: "{{ fan_off_time_max == 0 }}"
sequence:
- conditions:
- condition: state
state: "on"
- condition: state
state: "off"
value_template: "{{ fan_off_time_max > 0 and ( now().timestamp() - states[toilet_fan].last_changed.timestamp() ) / 60 >= fan_off_time_max }}"
sequence:
- conditions:
- condition: state
state: "on"
- condition: state
state: "off"
value_template: "{{ float(states[humidity_in].state) - float(states[humidity_out].state) <= fan_off_humidity }}"
value_template: "{{ fan_off_time_min == 0 or ( states[toilet_light].last_changed.timestamp() - states[toilet_fan].last_changed.timestamp() ) / 60 <= fan_off_time_min_if }}"
sequence:
- conditions:
- condition: state
state: "on"
- condition: state
state: "off"
value_template: "{{ ( now().timestamp() - states[toilet_light].last_changed.timestamp() ) / 60 >= fan_off_time_min }}"
sequence:
default: []
default: []
mode: single
