dna88
(Matteo Danese)
August 13, 2020, 3:11pm
1
Hello world!
I control AC Toshiba with App “Toshiba ac control”. But I cannot find a method to control with home assistant without implement IR control… Someone have success with it? Without IR control
My idea is to put on AC when room became too hot or with high humidity %. For this work i have aqara sensors in all rooms.
Model AC: Toshiba Shorai Edge
External unit:
RAS-4M27U2AVG-E
Internal unit:
RAS-B13N4KVSG-E
RAS-B07N4KVSG-E
All with wifi.
h4de5
(Andi)
December 30, 2020, 1:40pm
2
see here:
I just installed new AC system from Toshiba. It’s connected to local network by wi-fi adapter RB-N101S-G.
Are there any plans for integrating it into home-assistant?
Thanks in advance
Tibor
Hi all!
I’m having a couple of issues with using an a couple of IR bulbs attached to an ESP8266 (running ESPHome) to control my Toshiba AC unit.
I’ve managed to fumble my way into getting the coolix climate integration to work but as this integration controls the HVAC unit like the remote, it isn’t very useful for maintaining the room temp; as it will send an IR signal for the temperature you want the room to be (i.e 28C), instead of something cooler, followed by turning the AC off once it rea…
Hello! I have not found this anywhere. I noticed ESPhome contains some libraries to control A/C with IR transmitter. Does anyone have experience with Toshiba A/C? Controlling Toshiba with IR is quite complicated, it uses multi-byte commands. I have ESP library that works, but it is not part of ESPhome library. Thank you.
at that time, there is no ready made integration for toshiba AC
Makis
(Makis)
July 18, 2021, 9:57am
3
Hi
I am expecting tomorrow my new ac Shorai Edge. Have you manage to integrate it to HA? What is your best solution?
Has anyone managed to integrate inverter air conditioners and Toshiba splits?
flyerdp
(David)
June 5, 2024, 11:44pm
8
Use the MIDEA AC app in HACS. works great
