Is this : https://github.com/home-assistant/home-assistant/issues/10252 … the reason why my tradfri isnt working anymore ? I had to reboot my gateway (power lose ) and it updated automaticly , now I cant get it to work anymore. I am on 0.56.2 . I am away of the issue with aiocoap. That didnt work eiher ( it did work before)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 191, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tradfri.py", line 111, in async_setup
allow_tradfri_groups))
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tradfri.py", line 125, in _setup_gateway
api = yield from api_factory(host, key, loop=hass.loop)
File "/srv/homeassistant/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py", line 152, in api_factory
yield from request(Command('get', ['status']))
File "/srv/homeassistant/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py", line 117, in request
result = yield from _execute(api_commands)
File "/srv/homeassistant/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py", line 109, in _execute
api_command.result = _process_output(res, parse_json)
File "/srv/homeassistant/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py", line 176, in _process_output
return json.loads(output)
File "/usr/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)```
Add a URL filter for fw.ota.homesmart.ikea.net into your router
Or even better: block all internet traffic from gw device in your firewall. This way the update will not be applied.
Missed the opportunity to block the GW, Only just noticed the issue when my wife tried to turn on the lights as it’s getting dark here in the UK… I am not going to be popular when I get home lol…
… from the security point of view, let this be a wakeup call for the ones not FULLY cautious with “automatic updates” , as me in this case …
will there be a fix in the next days ? …
i missed blocking the update, too. but according to this tip by @hanpal i managed to revert the update:
This should work if your gateway has been accidentally updated before a new pytradfri version has been released:
Block internet access to the gateway
Perform factory reset. The gateway then reverts to a pre-stored version (the one available when it was manufactured). The gateway will try to update to the latest version after factory reset but this will be prohibited according to 1.
Just like lutron did a few weeks ago - looks like there is a close fix for caseta coming, but an auto update to the hub bricked everything that wasn’t officially official.
