Transparent Blue is a theme designed for Home Assistant, offering a sleek and transparent blue aesthetic. It’s my first custom theme for Home Assistant and my first ever GitHub/HACS repository.
Really incredible, i have searched for months a theme like this. A big thank you from my colleagues too, since I installed hass in the office and applied your theme everyone has fallen in love. Now everyone wants it. I was also able to customize the background with the base64 converter.
I installed your very beautiful theme a lot of time ago and always worked fine, but about since the last month it stopped to work properly and the changed state icons (configured on) stands in white
When I change from dashboard to dashboard, just for half second, the icons with changed state, switch correctly to yellow, then turn back to white
I’m on windows 10, chrome Version 89.0.4389.82 (tried edge too), but on android app on my smartphone, it continues to work really fine
I tried also others themes (not so nice like yours) and everything works fine
What I’m doing wrong?? Any idea??
Thank in advance for your kind help
Regards
Few things,
What version of the theme are you running and how do you have it installed?
I just released an update today, can you see if you have the same issue with that version?
If you’re still having issues can you open an issue on the repo with details and screenshots?
Tried the latest version and also previouses, always from HACS: same issue
Changed browser settings, delete cache, restart HA, also the host, to be sure starting from initialization: still the same
Removed one extra toolbar addon and all the other themes repository: still the same
Screenshots may not help, just imagine icons still white instead of yellow when active, never blue
(on the android app stay blue for inactive, yellow for active, like it has to be!)
I’ve been having the same issue since a couple of HA releases ago.
My profile theme is backend selected which changes between Google Light Theme at sunrise and Google Dark Theme at sunset and I have transparentblue applied to some views. I’ve tried using it as profile theme, view theme and card theme but experience the momentary flash of blue for active icons, then white. HA is fully up to date and I’m using https://github.com/Mariusthvdb/custom-ui
System Health
version: core-2021.3.3
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.9.16
arch: aarch64
timezone: America/Vancouver
GitHub API: ok
Github API Calls Remaining: 4501
Installed Version: 1.11.3
Stage: running
Available Repositories: 826
Installed Repositories: 82
can_reach_server: ok
remaining_requests: 41
logged_in: true
subscription_expiration: April 3, 2021, 5:00 PM
relayer_connected: true
remote_enabled: false
remote_connected: false
alexa_enabled: true
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 5.12
update_channel: stable
supervisor_version: supervisor-2021.03.4
docker_version: 19.03.13
disk_total: 113.9 GB
disk_used: 15.1 GB
healthy: true
supported: true
board: odroid-n2
supervisor_api: ok
version_api: ok
installed_addons: motionEye (0.11.1), File editor (5.2.0), UniFi Controller (0.20.3), Mosquitto broker (5.1.1), TasmoAdmin (0.14.0), Samba share (9.3.1), Home Assistant Google Drive Backup (0.103.1), Log Viewer (0.9.1), Node-RED (8.1.3), Duck DNS (1.12.5), Glances (0.11.1), InfluxDB (4.0.3), SSH & Web Terminal (8.0.3), NGINX Home Assistant SSL proxy (3.0.1), AdGuard Home (3.0.0), Portainer (1.4.0), Z-Wave JS to MQTT (0.6.2), ESPHome (1.16.2), MariaDB (2.2.2), ADB - Android Debug Bridge (0.7.0), Visual Studio Code (3.1.1), WireGuard (0.5.0)
dashboards: 2
resources: 45
mode: storage
