Sorry, I think the notification ended up in spam.
Yes I am using local Tuya
I currently have 3 of these: Fr-fan-15h-484
I just had to set these up again since I changed WiFi and when you reset you need the local key again.
Thanks for this! I was able to get my fan working correctly using this, but I can’t get the light to be DP9. When I choose what type of entity to add, I get the following list:
binary sensor
climate
cover
fan
light
number
select
sensor
switch
vacuum
Choosing ‘fan’ gives me the ability to configure that entity but it defaults to DP 1. I can’t change it. Entering your configs seems to work great.
However when choosing the ‘light’ option, it doesn’t show a DP number. For the ID, the options are:
3 (value: 1)
6 (value: 100)
101 (value: False)
105 (value: 100)
106 (value: mode1)
108 (value: 1)
I’m not sure how to specify the DP in this case, or if maybe I should be choosing a different type of entity to force the DP9 you’re talking about?
Thank you!
As I recall you explicitly set DP9 to be type light.
Thank you, thank you, thank you. That was the answer
