Tretakt smart plug as a zigbee router
Long time first time - thanks to all contributors on here, you’ve being a big help over the last couple of years.
Has anybody had success in using the new(ish) Ikea Tretakt smart plug as a zigbee router. I bought x4 of the them at the weekend and spread them out in my home.
I have the Aqara contact sensors on doors that are too far away from my zigbee coordinator and saw these plugs as a cheap solution to build a better network.
The plugs have just created there own mesh linked together (and weirdly just one motion sensor connected to the smart plug as a route back to the coordinator,), none of the contact sensors have connected to the plugs, despite the plug being between the sensor and the coordinator.
Is there a special technique required to get these setup?
The facts.
  • The plugs are appearing in zigbee2mqtt but configured as “unsupported”.
  • The plugs state can be controlled via zigbee2mqtt.
  • The sensors read as normal when close to the coordinator.
  • When the sensors are positioned in their final location, their state does not report.
  • The plugs appear on the zigbee2mqtt map but only as linked routes to themselves and back to the coordinator.
  • I tried re-pairing the sensors in their final location, but they do not connect via neither the coordinator or the plug routers.
Any help would be much appreciated.
I don’t see anything in the specs that the device is a router/repeater.
You might look here to see if a definition file is available or requested.
Support new devices | Zigbee2MQTT.
They should already be supported in the latest version. What version of Zigbee2MQTT are you using ?
While I also didn’t see any reference within the specs, they appear on zigbee2mqtt as a router so the assumption is they should act like one. I’m also under the impression that any mains powered zigbee device acts as a repeater/router on the network?
My Zigbee2MQTT version is: 1.35.1 commit: 9eaaa0f.
So I see I am a couple versions back. c. Jan-24 is my current which predates the Tretakt plugs (I think) so that may be something to work on!
Updated to the latest version of Z2M (1.36.1), re-paired the sensors in their final location and they connected via the Tretakt plugs. Phew - that was a reasonably straightforward troubleshoot. Thanks @francisp
Most, not all.
Generally Singled bulbs do not route, for instance.
And most non-neutral switches
Which coordinator are you using?
I’m using a Conbee 2 with ZHA and the plugs get recognized, are functional and they form a mesh, but none of the Aqara contact sensors will connect to them.
Same with the Sonoff ZBDongle-P (firmware 20240710)… :frowning:
I was considering buying some. Have you managed to get this fixed in ZHA?
They do show up in ZHA, but the Aqara door sensors cannot connect to them.
I think it’s a hardware incompatibility of the Aqara sensors, because in Z2M it doesn’t work well either.
See my other post: Ikea TRETAKT plugs as Zigbee routers for Aqara sensors
