Trigger ID when merging triggers in blueprints
I really like the option to merge triggers in blueprints as proposed by @karwosts (Add a syntax for merging lists of triggers by karwosts · Pull Request #117698 · home-assistant/core · GitHub), documented here: Automation Trigger - Home Assistant.
However, I’m struggling implementing it with trigger IDs. I try to create an automation that fires based on both groups of pre-defined triggers and variable blueprint triggers. To distinguish between the different trigger groups I want to use the trigger ID.
The below config works perfectly until I start adding trigger IDs to the blueprint-based triggers. Is there a different syntax to add it? Do I have to add the ID already in the blueprint input definition?
Thank you very much in advance for your help!
blueprint:
  input:
    presence_trigger:
      default: []
      selector:
    no_presence_trigger:
      name: "No Presence Trigger"
      default: []
      selector:
triggers:
  - trigger: event
    event_type:
      - automation_reloaded
      - homeassistant_started
  - triggers: !input presence_trigger
    id: presence_trigger  # Does not work
  - triggers: !input no_presence_trigger
    id: no_presence_trigger  # Does not work
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - update
Unfortunately there’s not a way to do that right now.
https://community.home-assistant.io/t/wth-trigger-id-blueprint-selector-and-or-during-flattening/806144
The only way I have come up with to differentiate between triggers produced by selectors is to also stuff them into variables so that a template can count how many there are, then use that count to compare against the trigger index.
trigger.idx | int(-1) (value is a string, so needs the type conversion)
I’ve started an architectural discussion to propose a solution to this.
Please leave any feedback here: Allow trigger groups to have an ID · home-assistant/architecture · Discussion #1187 · GitHub
