I have Nexa 433 remote (NEYCT-705) with four switches that works just fine. The fifth one is a “group on” switch that acts as a switch for the whole group.
My problem is the the RFXtrx component ignores this fifth button since the command is “Group on” instead of “On”. It is only logged as received. My question is, is there a way of triggering on this without official support from the RFXtrx component?
The logs from the group on button:
homeassistant.components.rfxtrx:Receive RFXCOM event from (Device_id: 0a7d9921 Class: LightingDevice Sub: 0, Pkt_id: 0b11000000a7d99201040f80)
homeassistant.components.rfxtrx:Device_id: 0a7d9921 device_update. Command: Group on
It actually works! Almost, I have a problem that the group on button changes “Pkt_id” (0b11000000a7d99201040f70) frequently, and the constant Device_id (0a7d9921) is not possible to have as a switch.
I do not understand how this works, in my example above no events were fired, although switch was configured with fire_event=true? But when creating the trigger, then an event is fired, the the trigger catches?
homeassistant.components.rfxtrx:Receive RFXCOM event from (Device_id: 0a7d9921 Class: LightingDevice Sub: 0, Pkt_id: 0b11000000a7d99201040f70)
homeassistant.components.rfxtrx:Rfxtrx fired event: (event_type: button_pressed, entity_id: switch.alla1, state: group on)
homeassistant.core:Bus:Handling <Event button_pressed[L]: entity_id=switch.alla1, state=group on>
The last two lines only appeared after I declared the trigger in the automation, not before when only declaring the switch…
Ah now I understand. Events are always fired when fire_event = true. My problem was that I though the fifth “group on” button had its own id and I had not configured fire_event on the four others.
However, the Pkt_id (which ends up being entity_id) jumped around being (according to RFXtrx) one of the other four, although it differed slightly in the hex in the Pkt_id. Must be some magic in the bit-byte xor-hex world.
I expanded the Json data to this and got it to work. I could limit it down to the four buttons, but then I needed four triggers and I only have one case for my “group on” now,
- platform: event
event_data:
state: group on
