I have Home Assistant OS running on a Dell Optiplex 7040 PC with an i5 processor. I’ve starting using Frigate and like it, so I purchased a Coral. The Coral is PCIe, so I installed it using a PCIe to PCI adapter card. I tried setting up frigate.yml to point to the Coral, but its not detected. On my PC’s BIOS, it is showing that a device is recognized in the PCI port, and is calling it “unclassified”.
Based on the below link, it appears I need to install the drivers for Linux:
I’m following the procedure, which involves interfacing with the Linux PC via command line interface, which I am accomplishing using the SSH addon in HA. Based on the instructions, I need to perform the “workaround to disable Apex and Gasket”, which are explained here:
This is the step where I’m having trouble. As instructed, I made a file blacklist-apex.conf with Notepad on my Windows PC, and copied it to the config folder on the HA PC using the Samba addon. Then I copied it from there to the proper folder /etc/modprobe.d using Linux commands via SSH. After copying, I can confirm the file got copied into the folder using the Linux command “ls” to list out the files. However, when I reboot, the file disappears, and the workaround is not accomplished. This is where I’m stuck at the moment. I’m thinking that I’m doing something wrong regarding copying the file in Linux, mainly because I know very little about Linux. I suspect I’m make a novice error on the command line. Here is the commands I am entering to copy the file from /config to /etc/modprobe.d:
cd …
cd config
cp blacklist-apex.conf /etc/modprobe.d
cd …
cd etc
cd modprobe.d
ls
The last command lists the files in the /etc/modprobe.d folder and it shows that the new file is indeed there. However after a reboot, it disappears.
You only need to do the blacklist if you have apex installed before step 1. It is normal to have it, once you followed after step one, cause it will install apex and gasket.
What do you get when you run lspci -nn | grep 089a
Step 2 said I needed to do the workaround to disable Apex and Gasket. I did not try proceeding with the rest of the steps yet. Since I can’t get the Apex and Gasket disabled.
I am stuck at step 2 also. it does seem that modprobe.d directory is being reset before HA is starting. this is why blacklisting apex is not working
But what to do next any ideas?
Just to bring closure to this thread, I did get my Coral working. What I found out is that with Frigate, you don’t have to follow the steps on the link I posted above (with the Linux command-line stuff). All you have to do is create the configuration yaml file in HA and it should work.
What I did to get mine working, was I changed to a different “version” of Frigate. When you install Frigate you have to choose between “Frigate NVR” and “Frigate NVR (Full Access)”. I don’t recall which one I started with, but I uninstalled it and switched to the other one and the Coral was detected. I think I started with “full access”, but I’m not sure. Hopefully this helps someone struggling with the same issue.
Hello everyone, I am also having difficulties bypassing step 2, I am using the new dual HAT of pineberry (1 NVME and 1 M.2 coral). I have a rpi 5, the nvme is correctly detected but not the dual TPU. My instance is not supervised, I have home assistant OS running on the pi.
Does anyone know how to correctly detect the dual edge tpu on the PI?
My understanding is that I should detect the tpu in apex_0 ?
Hi there, I’m having similar issues. I got the new Dual Hat Pineberry to try it on a RPI 5 with Home Assistant OS and Frigate Addon.
LED on the board is lit and I have apex_0 showing so the PCIe driver is installed, but no the TPU. And frigate won;t start when I add the Coral to frigate.yaml
What am I missing, how do I get the TPU to work. Are there any other drivers to install?
I understand the model is optional, but yes I tried that too. I wonder, the Pineberry uses a PCIe switch does that affect the slot number. I tried 0, 1 and 2 but no success
