Trouble setting static external DNS for my HASSIO machine
Hi all.
I’m trying to use the AdGuard addon for Hassio:
Right now I’m struggling to set a static external DNS for my HASSIO machine.
I have host SSH access via port 22222 and I went to login, got the # prompt . I echo’d out:
echo '{"dns": ["8.8.8.8", "8.8.4.4"]}' > /etc/docker/daemon.json
On enter, I just got another #. When I restarted HA with AdGaurd set to start on boot, I’m still unable to connect to external services - DarkSky, Ecobee, Skybell, etc.
When I start HA without AdGuard running on boot, the external components work.
Any ideas about what I’m missing or what else I can do to set a static external DNS for my HASSIO machine?
Thanks.
Did you check what daemon.json now says?
I was successful in doing it with a different method.
You can try it and just add the DNS to an existing connection instead of the VLAN.
