I’m using HA to control a couple of Z-Wave devices: a Leviton light switch and a GE dimmer. HA is working on my Raspberry Pi, and I can use the Web GUI to control the devices. I have also installed LIRC and am able to turn on and off the dimmer using an infrared remote. What I have been unable to do, and what I would like to do, is change the brightness of the dimmer using a button on the IR remote.
I’ve been trying to follow the instructions in this Community posting: https://community.home-assistant.io/t/incremental-increase-of-light-brightness/8932. However, I can’t get the template to work.
Here’s the relevant part of the configuration.yaml:
- alias: Raise Dimmer Brightness
platform: event
event_type: ir_command_received
event_data:
button_name: KEY_RIGHT
service: light.turn_on
entity_id: light.ge_12724_3way_dimmer_switch_level_3_0
data_template:
brightness: '{{states.light.ge_12724_3way_dimmer_switch_level_3_0.attributes.brightness + 10}}'
When I press the right arrow button on the IR remote, this message comes up:
17-02-23 22:09:03 ERROR (MainThread) [homeassistant.core] Invalid service data for light.turn_on: expected int for dictionary value @ data['brightness']. Got '58.93939393939394'
The IR command is being received, there’s just something wrong with the syntax in the template. Can you help set me to rights?
Thank you.
