I’m running HA and ESP on Docker.
I’m trying to set up the ESP32-S3-BOX-3. Installing ‘Voice’ seems to succeed but fails to return to WiFi setup.
I have tried the suggested remedies multiple times. I even downloaded the config and tried editing it with SSID and Password to no avail.
Any suggestions welcome.
TIA
John
Not sure to understand properly your issue
It never connects at Wifi ? if so what are logs of ESP after flashing it ?
Hi vincen,
We started at the beginning again. Same result though.
here’s the log:
[W][component:214]: Component esphome.coroutine took a long time for an operation (0.21 s).
[W][component:215]: Components should block for at most 20-30ms.
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xa (SPI_FAST_FLASH_BOOT)
Saved PC:0x4213763a
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x1658
load:0x403c9700,len:0xbc0
load:0x403cc700,len:0x2f3c
entry 0x403c9950
I (18) boot: ESP-IDF 4.4.6 2nd stage bootloader
I (18) boot: compile time 22:17:44
I (18) boot: Multicore bootloader
I (18) boot: chip revision: v0.2
I (19) boot.esp32s3: Boot SPI Speed : 80MHz
I (19) boot.esp32s3: SPI Mode : DIO
I (19) boot.esp32s3: SPI Flash Size : 16MB
I (19) boot: Enabling RNG early entropy source…
I (20) boot: Partition Table:
I (20) boot: ## Label Usage Type ST Offset Length
I (20) boot: 0 otadata OTA data 01 00 00009000 00002000
I (21) boot: 1 phy_init RF data 01 01 0000b000 00001000
I (21) boot: 2 app0 OTA app 00 10 00010000 007c0000
I (21) boot: 3 app1 OTA app 00 11 007d0000 007c0000
I (22) boot: 4 nvs WiFi data 01 02 00f90000 0006d000
I (22) boot: End of partition table
I (22) esp_image: segment 0: paddr=00010020 vaddr=3c140020 size=22dfd8h (2285528) map
I (433) esp_image: segment 1: paddr=0023e000 vaddr=3fc9c740 size=02018h ( 8216) load
I (435) esp_image: segment 2: paddr=00240020 vaddr=42000020 size=13d30ch (1299212) map
I (668) esp_image: segment 3: paddr=0037d334 vaddr=3fc9e758 size=028b4h ( 10420) load
I (671) esp_image: segment 4: paddr=0037fbf0 vaddr=40374000 size=18734h (100148) load
I (703) boot: Loaded app from partition at offset 0x10000
I (703) boot: Disabling RNG early entropy source…
I (703) cpu_start: Multicore app
I (704) opi psram: vendor id : 0x0d (AP)
I (704) opi psram: dev id : 0x03 (generation 4)
I (704) opi psram: density : 0x05 (128 Mbit)
I (704) opi psram: good-die : 0x01 (Pass)
I (704) opi psram: Latency : 0x01 (Fixed)
I (705) opi psram: VCC : 0x00 (1.8V)
I (705) opi psram: SRF : 0x01 (Fast Refresh)
I (705) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (705) opi psram: BurstLen : 0x01 (32 Byte)
I (706) opi psram: Readlatency : 0x02 (10 cycles@Fixed)
I (706) opi psram: DriveStrength: 0x00 (1/1)
W (707) MSPI Timing: tuning fail, best point is fallen back to index 5
I (707) MSPI Timing: PSRAM timing tuning index: 5
I (707) spiram: Found 128MBit SPI RAM device
I (708) spiram: SPI RAM mode: sram 80m
I (708) spiram: PSRAM initialized, cache is in normal (1-core) mode.
I (708) cpu_start: Pro cpu up.
I (708) cpu_start: Starting app cpu, entry point is 0x4037700c
I (0) cpu_start: App cpu up.
I (1299) spiram: SPI SRAM memory test OK
I (1308) cpu_start: Pro cpu start user code
I (1308) cpu_start: cpu freq: 240000000
I (1308) cpu_start: Application information:
I (1308) cpu_start: Project name: esp32-s3-box-3
I (1308) cpu_start: App version: 2024.2.0
I (1308) cpu_start: Compile time: Feb 22 2024 22:12:51
I (1309) cpu_start: ELF file SHA256: 7d533501968c77b6…
I (1309) cpu_start: ESP-IDF: 4.4.6
I (1309) cpu_start: Min chip rev: v0.0
I (1309) cpu_start: Max chip rev: v0.99
I (1309) cpu_start: Chip rev: v0.2
I (1310) heap_init: Initializing. RAM available for dynamic allocation:
I (1310) heap_init: At 3FCAA2C0 len 0003F450 (253 KiB): D/IRAM
I (1310) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DIRAM
I (1310) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM
I (1311) spiram: Adding pool of 16384K of external SPI memory to heap allocator
I (1312) spi_flash: detected chip: gd
I (1312) spi_flash: flash io: dio
I (1313) sleep: Configure to isolate all GPIO pins in sleep state
I (1313) sleep: Enable automatic switching of GPIO sleep configuration
I (1314) coexist: coexist rom version e7ae62f
I (1314) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
[I][logger:359]: Log initialized
[C][ota:483]: There have been 1 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash…
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[D][ili9xxx:036]: Command EF, length 3, bits 03
[D][ili9xxx:036]: Command CF, length 3, bits 00
[D][ili9xxx:036]: Command ED, length 4, bits 64
[D][ili9xxx:036]: Command E8, length 3, bits 85
[D][ili9xxx:036]: Command CB, length 5, bits 39
[D][ili9xxx:036]: Command F7, length 1, bits 20
[D][ili9xxx:036]: Command EA, length 2, bits 00
[D][ili9xxx:036]: Command C0, length 1, bits 23
[D][ili9xxx:036]: Command C1, length 1, bits 10
[D][ili9xxx:036]: Command C5, length 2, bits 3E
[D][ili9xxx:036]: Command C7, length 1, bits 86
[D][ili9xxx:036]: Command 36, length 1, bits C8
[D][ili9xxx:036]: Command 37, length 1, bits 00
[D][ili9xxx:036]: Command 3A, length 1, bits 55
[D][ili9xxx:036]: Command B1, length 2, bits 00
[D][ili9xxx:036]: Command B6, length 3, bits 08
[D][ili9xxx:036]: Command F2, length 1, bits 00
[D][ili9xxx:036]: Command 26, length 1, bits 01
[D][ili9xxx:036]: Command E0, length 15, bits 0F
[D][ili9xxx:036]: Command E1, length 15, bits 00
[D][ili9xxx:036]: Command 11, length 0, bits 29
[D][ili9xxx:036]: Command 29, length 0, bits 00
[I][app:029]: Running through setup()…
[D][spi:039]: Setting up SPI bus…
[D][esp-idf:000]: I (151) gpio: GPIO[1]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][binary_sensor:034]: ‘Mute’: Sending initial state OFF
[D][esp-idf:000]: I (153) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
[D][binary_sensor:034]: ‘Top Left Button’: Sending initial state OFF
[D][ledc.output:055]: Calculating resolution bit-depth for frequency 1000.000000
[D][ledc.output:060]: Resolution calculated as 14
[I][esp_adf:019]: Start codec chip
[D][esp-idf:000]: I (163) DRV8311: ES8311 in Slave mode
[D][esp-idf:000]: I (175) gpio: GPIO[46]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][esp-idf:000]: W (181) I2C_BUS: i2c_bus_create:58: I2C bus has been already created, [port:0]
[D][esp-idf:000]: I (185) ES7210: ES7210 in Slave mode
[D][esp-idf:000]: I (196) ES7210: Enable ES7210_INPUT_MIC1
[D][esp-idf:000]: I (199) ES7210: Enable ES7210_INPUT_MIC2
[D][esp-idf:000]: W (204) ES7210: Disable TDM mode. ES7210_SDP_INTERFACE2_REG12: 0
[D][esp-idf:000]: I (209) ES7210: config fmt 60
[D][esp-idf:000]: I (214) AUDIO_HAL: Codec mode is 3, Ctrl:1
[D][template.select:014]: Setting up Template Select
[D][template.select:023]: State from initial (could not load stored index): On device
[D][select:015]: ‘Wake word engine location’: Sending state On device (index 1)
[D][ili9xxx:034]: Setting up ILI9xxx
[D][esp-idf:000]: I (224) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][esp-idf:000]: I (225) gpio: GPIO[48]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][spi_device:379]: mode 0, data_rate 40000kHz
[D][esp-idf:000]: I (226) gpio: GPIO[5]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][ili9xxx:030]: Wrote MADCTL 0xC8
[C][light:035]: Setting up light ‘LCD Backlight’…
[D][light:036]: ‘LCD Backlight’ Setting:
[D][light:041]: Color mode:
[D][light:047]: State: ON
[D][light:051]: Brightness: 100%
[D][template.switch:046]: Restored state OFF
[D][switch:016]: ‘Mute’ Turning OFF.
[D][switch:055]: ‘Mute’: Sending state OFF
[C][esp_adf.microphone:027]: Setting up ESP ADF Microphone…
[D][ring_buffer:024]: Created ring buffer with size 16000
[C][esp_adf.microphone:047]: Successfully set up ESP ADF Microphone
[C][esp32_ble:027]: Setting up BLE…
[C][wifi:038]: Setting up WiFi…
[D][esp-idf:000]: I (793) pp: pp rom version: e7ae62f
[D][esp-idf:000]: I (794) net80211: net80211 rom version: e7ae62f
[D][esp-idf:000]: I (796) wifi:
[D][esp-idf:000]: wifi driver task: 3fcb6948, prio:23, stack:6656, core=0
[D][esp-idf:000]:
[D][esp-idf:000]: I (2910) system_api: Base MAC address is not set0m
[D][esp-idf:000]: I (2910) system_api: read default base MAC address from EFUSE
[D][esp-idf:000]: I (2913) wifi:
[D][esp-idf:000]: wifi firmware version: 1ba8b6a
[D][esp-idf:000]:
[D][esp-idf:000]: I (2914) wifi:
[D][esp-idf:000]: wifi certification version: v7.0
[D][esp-idf:000]:
[D][esp-idf:000]: I (2915) wifi:
[D][esp-idf:000]: config NVS flash: enabled
[D][esp-idf:000]:
[D][esp-idf:000]: I (2916) wifi:
[D][esp-idf:000]: config nano formating: disabled
[D][esp-idf:000]: I (2917) wifi:
[D][esp-idf:000]: Init data frame dynamic rx buffer num: 32
[D][esp-idf:000]:
[D][esp-idf:000]: I (2918) wifi:
[D][esp-idf:000]: Init management frame dynamic rx buffer num: 32
[D][esp-idf:000]:
[D][esp-idf:000]: I (2919) wifi:
[D][esp-idf:000]: Init management short buffer num: 32
[D][esp-idf:000]:
[D][esp-idf:000]: I (2920) wifi:
[D][esp-idf:000]: Init dynamic tx buffer num:[D][esp-idf:000]:
[D][esp-idf:000]: I (2921) wifi:
[D][esp-idf:000]: Init tx cache buffer num: 32
[D][esp-idf:000]:
[D][esp-idf:000]: I (2922) wifi:
[D][esp-idf:000]: Init static tx FG buffer num: 2
[D][esp-idf:000]:
[D][esp-idf:000]: I (2923) wifi:
[D][esp-idf:000]: Init static rx buffer size: 1[D][esp-idf:000]:
[D][esp-idf:000]: I (2924) wifi:
[D][esp-idf:000]: Init static rx buffer num: 10
[D][esp-idf:000]:
[D][esp-idf:000]: I (2925) wifi[D][esp-idf:000]: Init dynamic rx buffer num: 32
[D][esp-idf:000]:
[D][esp-idf:000]: I (2926) wifi_init: rx ba win: 6
[D][esp-idf:000]: I (2927) wifi_init: tcpip mbox: 32
[D][esp-idf:000]: I (2928) wifi_init: udp mbox: 6
[D][esp-idf:000]: I (2928) wifi_init: tcp mbox: 6
[D][esp-idf:000]: I (2929) wifi_init: tcp tx win: 5744
[D][esp-idf:000]: I (2930) wifi_init: tcp rx win: 5744
[D][esp-idf:000]: I (2930) wifi_init: tcp mss: 1440
[D][esp-idf:000]: I (2931) wifi_init: WiFi IRAM OP enabled
[D][esp-idf:000]: I (2931) wifi_init: WiFi RX IRAM OP enabled
[C][wifi:051]: Starting WiFi…
[C][wifi:052]: Local MAC: 30:30:F9:5A:B6:B8
[D][esp-idf:000]: I (2934) phy_init: phy_version 610,2bff4c8,Jul 27 2023,20:22:14
[D][esp-idf:000]: I (2968) wifi:
[D][esp-idf:000]: mode : softAP (30:30:f9:5a:b6:b9)
[D][esp-idf:000]:
[D][esp-idf:000]: I (2970) wifi:
[D][esp-idf:000]: Total power save buffer number: 16
[D][esp-idf:000]:
[D][esp-idf:000]: I (2971) wifi:
[D][esp-idf:000]: Init max length of beacon: 752/752
[D][esp-idf:000]:
[D][esp-idf:000]: I (2972) wifi:
[D][esp-idf:000]:
[C][wifi:254]: Setting up AP…
[C][wifi:256]: AP SSID: ‘esp32-s3-box-3-5ab6b8’
[C][wifi:257]: AP Password: ‘’
[D][esp-idf:000]: I (2977) wifi:
[D][esp-idf:000]:
[C][wifi:266]: IP Address: 192.168.4.1
[D][esp-idf:000]: I (2981) wifi:
[D][esp-idf:000]: mode : sta (30:30:f9:5a:b6:b8) + softAP (30:30:f9:5a:b6:b9)
[D][esp-idf:000]: enable tsf
[D][esp-idf:000]:
[D][esp32_improv.component:240]: Setting Improv to start
[C][ota:096]: Over-The-Air Updates:
[C][ota:097]: Address: esp32-s3-box-3.local:3232
[C][ota:103]: OTA version: 2.
[C][api:025]: Setting up Home Assistant API server…
[D][wifi:459]: Starting scan…
[C][micro_wake_word:064]: Setting up microWakeWord…
[C][micro_wake_word:087]: Micro Wake Word initialized
[C][voice_assistant:028]: Setting up Voice Assistant…
[D][ring_buffer:024]: Created ring buffer with size 32768
[C][esp_adf.speaker:024]: Setting up ESP ADF Speaker…
[I][app:062]: setup() finished successfully!
[D][esp32.preferences:114]: Saving 2 preferences to flash…
[D][esp32.preferences:143]: Saving 2 preferences to flash: 2 cached, 0 written, 0 failed
[D][esp32_ble:270]: Enabling BLE…
[D][esp-idf:000]: I (3038) BLE_INIT: BT controller compile version [59725b5]
[D][esp-idf:000]: I (3039) BLE_INIT: Bluetooth MAC: 30:30:f9:5a:b6:ba
[W][component:214]: Component esp32_ble took a long time for an operation (0.22 s).
[D][esp-idf:000]: I (3260) wifi:
[D][esp-idf:000]: Set ps type: 1
[D][esp-idf:000]:
[I][app:102]: ESPHome version 2024.2.0 compiled on Feb 22 2024, 22:12:50
[I][app:104]: Project esphome.voice-assistant version 2.0
[C][logger:447]: Logger:
[C][logger:448]: Level: DEBUG
[C][logger:449]: Log Baud Rate: 115200
[C][logger:451]: Hardware UART: USB_SERIAL_JTAG
[C][spi:068]: SPI bus:
[C][spi:069]: CLK Pin: GPIO7
[C][spi:070]: SDI Pin:
[C][spi:071]: SDO Pin: GPIO6
[C][spi:076]: Using HW SPI: SPI2_HOST
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Mute’
[C][gpio.binary_sensor:016]: Pin: GPIO1
[C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Top Left Button’
[C][gpio.binary_sensor:016]: Pin: GPIO0
[D][esp32_ble_server:077]: BLE server setup successfully
[D][esp32_improv.component:077]: Creating Improv service
[C][ledc.output:164]: LEDC Output:
[C][ledc.output:165]: Pin GPIO47
[C][ledc.output:166]: LEDC Channel: 0
[C][ledc.output:167]: PWM Frequency: 1000.0 Hz
[C][ledc.output:168]: Bit depth: 14
[C][template.select:065]: Template Select ‘Wake word engine location’
[C][template.select:066]: Update Interval: 60.0s
[C][template.select:069]: Optimistic: YES
[C][template.select:070]: Initial Option: On device
[C][template.select:071]: Restore Value: YES
[C][ili9xxx:073]: ili9xxx
[C][ili9xxx:073]: Rotations: 0 °
[C][ili9xxx:073]: Dimensions: 320px x 240px
[C][ili9xxx:074]: Width Offset: 0
[C][ili9xxx:075]: Height Offset: 0
[C][ili9xxx:081]: Color mode: 16bit
[C][ili9xxx:090]: Data rate: 40MHz
[C][ili9xxx:092]: Reset Pin: GPIO48
[C][ili9xxx:093]: CS Pin: GPIO5
[C][ili9xxx:094]: DC Pin: GPIO4
[C][ili9xxx:096]: Color order: BGR
[C][ili9xxx:097]: Swap_xy: NO
[C][ili9xxx:098]: Mirror_x: YES
[C][ili9xxx:099]: Mirror_y: YES
[C][ili9xxx:104]: Update Interval: never
[C][light:103]: Light ‘LCD Backlight’
[C][light:105]: Default Transition Length: 0.2s
[C][light:106]: Gamma Correct: 2.80
[C][template.switch:068]: Template Switch ‘Mute’
[C][template.switch:091]: Restore Mode: restore defaults to OFF
[C][template.switch:057]: Optimistic: YES
[D][esp-idf:000]: W (3576) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[D][esp32_improv.component:097]: Service started!
[D][esp-idf:000]: W (3592) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[D][esp-idf:000]: W (3598) BT_BTM: data exceed max adv packet length
[D][esp-idf:000]: W (3599) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[C][psram:020]: PSRAM:
[C][psram:021]: Available: YES
[C][psram:024]: Size: 16383 KB
[D][esp-idf:000]: W (3611) BT_BTM: data exceed max adv packet length
[D][esp-idf:000]: W (3612) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[C][factory_reset.button:011]: Factory Reset Button ‘Factory reset’
[C][factory_reset.button:011]: Icon: ‘mdi:restart-alert’
[C][esp32_ble:374]: ESP32 BLE:
[C][esp32_ble:376]: MAC address: 30:30:F9:5A:B6:BA
[C][esp32_ble:377]: IO Capability: none
[C][esp32_ble_server:200]: ESP32 BLE Server:
[C][esp32_improv.component:257]: ESP32 Improv:
[C][esp32_improv.component:262]: Status Indicator: ‘NO’
[C][wifi:577]: WiFi:
[D][esp-idf:000]: W (3794) wifi:
[D][esp-idf:000]: Haven’t to connect to a suitable AP now!
[D][esp-idf:000]:
[W][wifi_esp32:890]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:409]: Local MAC: 30:30:F9:5A:B6:B8
[D][esp-idf:000]: W (3796) wifi:
[D][esp-idf:000]:
[W][wifi_esp32:900]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:414]: SSID: [redacted]
[C][wifi:415]: IP Address: 0.0.0.0
[C][wifi:417]: BSSID: [redacted]
[C][wifi:418]: Hostname: ‘esp32-s3-box-3-5ab6b8’
[D][esp-idf:000]: W (3800) wifi:
[D][esp-idf
[W][wifi_esp32:911]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:420]: Signal strength: 0 dB ▂▄▆█
[C][wifi:424]: Channel: 4
[C][wifi:425]: Subnet: 255.255.255.0
[C][wifi:426]: Gateway: 192.168.4.1
[C][wifi:427]: DNS1: 0.0.0.0
[C][wifi:428]: DNS2: 0.0.0.0
[C][mdns:115]: mDNS:
[C][mdns:116]: Hostname: esp32-s3-box-3-5ab6b8
[C][api:139]: API Server:
[C][api:140]: Address: esp32-s3-box-3.local:6053
[C][api:144]: Using noise encryption: NO
[C][improv_serial:032]: Improv Serial:
[C][micro_wake_word:057]: microWakeWord:
[C][micro_wake_word:058]: Wake Word: okay nabu
[C][micro_wake_word:059]: Probability cutoff: 0.500
[C][micro_wake_word:060]: Sliding window size: 10
John
Hi John
As far as I can see from logs it looks ok but your esp is in AP mode not in station mode connected at an AP ! Can you share your esphome sketch please ?
Sorry I don’t understand. What is an esphome sketch please?
Copy the YAML code for your device from ESPhome and paste it in a code block here.
Select the pasted YAML code and press the Preformatted text </> button above.
esphome:
friendly_name: My Test Device
I don’t understand that either, I’m afraid. As far as I can ascertain there is no YAML code. Please explain.
I am following the instructions at: ESP32-S3-BOX voice assistant - Home Assistant
I click ‘Connect’ and when it has finished it is supposed to ask for Wifi info but doesn’t!
Thanks,
John
Connect USB to PC then to ESP32-S3-BOX3.
Press the blue connect button.
Select the port on which box3 is connected and enter the connection.
Select install
After the installation is complete, press next and if the wifi setting option does not appear, disconnect the USB from the PC.
Reconnect to PC.
Repeat the first steps
Do not choose to install but start the console and then back.
It should show wifi settings.
If not then repeat these last steps
pepe59
Sigh!
Thank you soooo much.
Why it doesn’t work properly initially I’ll leave to others but why isn’t this ‘work around’ public knowledge?
Again; thank you.
John
hi
I am facing the same issue and followed the proposed steps
disconnect the
- USB from the PC.
- Reconnect to PC.
- Repeat the first steps
- Do not choose to install but start the console and then back.
- It should show wifi settings.
- If not then repeat these last steps
about 10 times, but no success. do you have any advice?
I continued the loop, and at about the 17th time it worked eventually.
@pepe59 Thanks for the advice🙏
This needs added to Troubleshooting the ESP32-S3-BOX-3 - Home Assistant (home-assistant.io)
I just got my device today and ran into the same issue. Luckily i only had to unplug and reconnect once before the connect to wifi option showed up.
How is yours working? Mine is pretty rough at recognizing the wake word.
I haven’t really done much with it so far but yeah it doesn’t always recognise the wake word for me either.
hello I have the same problem it does not switch to wifi I tried your method but it works no need for help thank you
same problem here. I can add it to ESP Home but it fails to configure/offer the configuration while using the Install voice assistant. Any suggestion? I’m at loss - tried all possible combinations, computes, browser
maybe a version problem I don’t know I saw a video on YouTube which is very promising I send messages too bad he doesn’t respond
Hi for what have problems like me I have found a solution:
Pressing on reset is released the front to connect to esphome is wifi will appear for me to work but I do not understand me but of his
I’m at the 20th time now. No luck, so no dice.
