I’m after some trouble-shooting pointers. Given the current Covid-19 lockdown situation I’ve decided to move from OH to HA. My Z-Wave was working fine on OH, on HA I just can’t add my switch.
Hardware:
AEON Labs ZW090 Z-Stick Gen5
Fibaro FGS-213 Switch
HA Installed on VMware ESXi 6.7 using this guide. OH was on same setup different VM.
Process:
Clean install
Supervisor > System > Hardware
Confirmed /dev/ttyACM0 device:
Configuration > Integrations > Add > Z-Wave
Used /dev/ttyACM0 and created a random key (from here)
Configuration > Devices
Lists “AEON Labs ZW090 Z-Stick Gen5 AU”
Configuration > Z-Wave > Nodes
Also lists the same stick as Node:1 Complete:
Click “Add Node Secure” in HA, and cycle S1 three times on the FGS-213.
Wait 15 seconds, click Heal Network
Nothing in OZW Log that shows anything about a remote device even communicating:
2020-04-27 22:31:35.654 Detail, Queuing (Controller) Add Device
2020-04-27 22:31:35.654 Info, Add Device
2020-04-27 22:31:35.654 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-04-27 22:31:35.654 Detail, Notification: ControllerCommand - Starting
2020-04-27 22:31:35.655 Detail,
2020-04-27 22:31:35.655 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-04-27 22:31:36.365 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x01, 0x00, 0x00, 0xb9
2020-04-27 22:31:36.366 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-04-27 22:31:36.366 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-04-27 22:31:36.366 Detail, Node001, Expected callbackId was received
2020-04-27 22:31:36.366 Detail, Node001, Expected reply was received
2020-04-27 22:31:36.366 Detail, Node001, Message transaction complete
2020-04-27 22:31:36.366 Detail, contrlr, Removing current message
2020-04-27 22:31:36.366 Detail, Notification: ControllerCommand - Waiting
2020-04-27 22:31:36.366 Info, WriteNextMsg Controller nothing to do
2020-04-27 22:32:26.151 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2020-04-27 22:32:26.151 Info, WriteNextMsg Controller nothing to do
In an attempt to rule out anything OpenHAB I’ve also factory reset both devices, and started again with a fresh HA instance, but same results, just nothing shows up and nothing in the logs. Using “Add Node” rather than Secure has the same results.
Anything obvious I’m missing here / where else should I look?
Thanks.
