If you want to access TrueNAS SCALE from a VM, you have multiple options. If your system has more than one physical interface, you can assign your VMs to a NIC other than the primary one your TrueNAS server uses. This method makes communication more flexible, but does not offer the potential speed of a bridge.
If you have only one physical interface, you must create a bridge interface for the VM to use.
So, I made the bridge and everything seems well, but unfortunately, some issues persist…
Could anybody help me again? I’ve spent a few hours repeated checking all things like access permission to the directory etc. - no solution yet
Same issue, and I am following the directions above and run into the inability to remove the IP of the current interface. All VMs are shut down, and I do not even have any applications installed, but I receive this notification.
(my interface IP) is being consumed by Applications, please use a different node IP in applications configuration.
I am wondering how to complete this with the Applications service running or how to shut down the application service to allow unbinding of the IP to create the bridge and bind the IP to said bridge from the interface.
Answer found in Truenas forums, in Apps, unsetting the pool for apps shuts down the apps service. Made changes, and reassigned pool to the original. All is good.
recently I am running TrueNAS and installed your integration to monitor it.
However it shows all values as zeros.
Do you have an idea on whats going on?
Same issue as Mosher — I can establish a connection and get some values, but many report as zero. HA 2024.2.4 and TrueNAS SCALE 23.10.2.
One thought is that I generated the API key from my secondary user (not root). That user has groups permissions for wheel, root, builtin_administrators, and builtin_users. I’ve not had time to generate the key from the built in root or admin users.
Is there a specific port that needs to be open between HA and Truenas? I get the no response error. I have HA running on a separate Vlan and only want to open the minimum number of ports needed….
