Trying my first automation
Hi all,
I’ve been doing some basic things in Home Assistant, and I would like to get into a deeper knowledge of it. I love it and I want to learn all I can, but for now, I’m stucked in basic things.
My problem is that I want to create a button in the Lovelace which lets me turn on a switch (which activates an elecctrice heater) for a certain period of time (like a timer).
I’ve been searching in the community blog and there are a lot of people doing this, but in my case it does not work, and I don’t know why it is.
The post I’ve been using for my automation is the following: https://community.home-assistant.io/t/edit-yaml-through-lovelace/135386
For the moment I have this; in the config.yaml:
# Proves de temporitzador
input_boolean:
  radiador_timer_enable:
    #initial: on
    icon: mdi:timer
input_number:
  radiador_timer:
    name: On Timer (mins)
    #initial: 30
    min: 1
    max: 120
    step: 1
    mode: box
    icon: mdi:alarm
In my scripts.yaml there is this:
script:
    alias: heater timer script
    sequence:
    - delay: '00:{{ states("input_number.temp_cuina") | int }}:00'
    - service: switch.turn_off
      entity_id: switch.cuina_rad
And my automation.yaml is:
  - id: '001'
    #name: Heater Off Delay
  - alias: switch_heater_offdelay
    - platform: state
      to: 'on'
    condition:
    - condition: state
      entity_id: input_boolean.radiador_timer_enable
      state: 'on'
    - service: script.turn_off
      entity_id: script.heater timer script
    - service: script.heater timer script
#turning off timer enable cancels timer
  - id: '002'
  - alias: au_heater_cancel_tmr
    - platform: state
      to: 'off'
    #name: Heater Off Cancels Timer
  - id: '003'
  - alias: au_heater_offcancelstimer
    - platform: state
      to: 'off'
All the yaml seems correct, but when I validate the configuration in the control server, there appears the following errors:
Invalid config for [automation]: required key not provided @ data[‘action’]. Got None
required key not provided @ data[‘trigger’]. Got None. (See /config/configuration.yaml, line 13).
Invalid config for [automation]: not a valid value for dictionary value @ data[‘action’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 13).
I don’t know why is that, could someone help me?
Thanks in advance.
In all three automations you have
If you go to Developer Tools / States I think you will find the correct name is
script.heater_timer_script
From your first automation
Doesn’t make sense
Delete the line
perhaps ?
Also, none of your automations turn the script on.
I think in your first automation
Should be
- service: script.turn_on
Hi Mark,
very ambitious entrance for a newbie :wink:
I’am also willing to learn so let’s try to bring the things together.
  1. your script has no id, e.g. heater_timer could be one:
script:
  heater_timer:
    sequence:
  1. therefor your automation has an entity_id which isn’t defined. entity_id never have spaces whereas friendly name can have spaces
It’s auto generated if you create the script through the UI, otherwise it’s not required.
Hi honikos,
I think it could be much more than my level is, but if you help me, for sure we could bring things together!
  1. I tried to use the script you brought me, but now it says that there is something wrong; as jivesinger says, it could be that the id is autogenerated, and therefore, if I use the seacrh entity in the file editor I have this:
entity_id: script.script
  1. What you are saying is right! I changed the automation, so my automation now looks like this:
  - id: '001'
    - platform: state
      to: 'on'
    condition:
    - condition: state
      state: 'on'
  - id: '002'
    - platform: state
      to: 'off'
  - id: '003'
    - platform: state
      to: 'off'
This also solves what jivesinger was saying; I’ve changed all the entity_id to the code above.
But I’m having some of the errors that I was having before, here I copy the errors:
Thank both of you for your help and time!
Search in your Developer Tools for the entity_id of your template sensor. In the state-section just type in script.
You need to change
in your automations to
entity_id: script.heater_timer_script
assuming your script hasn’t changed from your first post.
As for your errors, remove the hyphen before alias.
So change from this
  - id: '002'
to this on all three of your automations
  - id: '002'
I’m not trying to be rude, but that makes absolutely no sense
Oh ! You mean like this to find the name ?
exactly
:+1:
That’s what I get, the name of it is script.script
jivesinger
It is all solved and now the configuration seems valid. I will try it when I reach home and I will inform you of the state!
jivesinger
honikos
Thank you both of you! Finally I could solve my problem, it was a lot easier that I was planning, but I don’t know if I did a good job explaining my problem…
I went to the integration documentation for the input number in the home assistant: https://www.home-assistant.io/integrations/input_number/ and I copied the last example which is:
# Example configuration.yaml entry using 'input_number' as a delay in an automation
input_number:
  minutes:
    icon: mdi:clock-start
    initial: 3
    min: 0
    max: 6
    step: 1
  seconds:
    initial: 30
    min: 0
    max: 60
    step: 10
automation:
 - alias: turn something off after x time after turning it on
     platform: state
     entity_id: switch.something
     to: 'on'
     - delay: "00:{{ states('input_number.minutes') | int }}:{{ states('input_number.seconds') | int }}"
When I changed my entity_id to the correct switch, I posted in my lovelace panel the entities like it is in the image:
And it’s working!!!
Thanks a lot for your support and I’m very sorry if I did not explained myself very well.
