Okay, so this is my first foray into trying to play a local media file to a google home speaker. the below picture is how my automation is setup so far. TTS on the speaker works fine so it’s connected and working. When i go to run actions on the automation to see if it works nothing happens. I have a Police1.mp3 in my www file. What am I doing wrong?
Have you looked at the trace of the Automation? Does it have any clue there?
I thought Google home/chromecast only playback https authenticated web accessible media files?
i figured it out. set it up as a call service to play_media and then for content id i put http://HAlocalIPadress:8123/local/Police1.mp3 and then put “music” for the content type.
I also tried it with the https://mydomain.duckdns.org/local/Police1.mp3 and it worked that way as well.
hope this helps someone
I’m still not getting this to work. I’m using the automation editor and no errors in the trace.
Success.
I used this to get an auth URL
I then added that to my HTTPS Nabu Casa link.
It needed the Content Type (set to audio/mp3) and it worked.
[Edit] seems to have stopped working. Not sure if the Auth Key has expired.
Updated my solution in the linked post.
@antimage I am not seeing the linked post.
The information I was missing was what /local was.
I have suggested this gets added to the Google Cast documentation;
To cast media stored in your Home Assistant instance, it needs to be added to the /config/www folder which translates to the /local folder. e.g. a cast location of /local/media/audio/test.mp3 is actually stored in /config/www/local/media/audio/test.mp3 . There is no need to define the host, as Home Assistant works that out for itself.
I am not certain of the last part, but it is true for me.
Yes, but I think the auth key expires. Using the /local/ folder seems to work all the time.
The NodeRed flow requests a new authkey every time it fires a media_player.play_media requests.
I have my media on a NAS which is mounted to the Home Assistant Media location. The /local/ doesn’t work in my instance. If you are okay with hosting the media in your home assistant instance your solution seems to be fine.
For anyone else having trouble with this:
To play a wave file in Node Red, used the Call Service node to an automation created like above in the screenshot @baz123 showed, but the folders are backwards for me. I could not get the file to play using a variety of other methods native to node red.
I found that via the network console suggestion by @antimage
/media/local
No need for the authentication key on the end of the url.
Big @baz123, this is an interesting solution. I’ll test this one right away. So you’ve never had a problem with the auth even after restarting the Home Assistant?
Just to check… I have to create the whole automation there? Because I wanted to use this in an automation triggered by an input boolean. Instead of Home Assistant UI I should build everything on Node Red, right? Thanks
yeah, its better to do everything in nodered. you can do half in HA and half in nodered but it just adds to frustration when debugging.
thanks a lot, total noob here, let’s try to do it then! thanks!
well, i’m missing something… everything works, except it doesn’t play. i’m trying to play it on my tv, and a 9 sec audio appears on screen but it doesn’t play. I’m missing the Make Payload, it that the reason? As I said I’m a total noob on Node Red, don’t know how to properly set Make Payload using the UI
I’ve been trying for ages to get a local media mp3 file to play when triggered. The only way I have been able to get this to work is using a short lived token that I have to generate manually every 5 hours or so. So I am thrilled that a new media player feature was added in recent updates except it does not work on my RPi 3 setup. The new “Play media” action allows me to select a Google speaker and the local media file, but it doesn’t even make the connect ding on the speaker when triggered like before when it attempts but the media itself fails to play. It’s like nothing happened. I also can never get the text to speech to work which throws an error of “Failed to call service media_player/play_media.” I don’t see this error with the new action, but I’m not sure where to look for it. I have a second action after the “Play media” to change the speaker volume which fails to execute per the log trace “This node was not executed and so no further trace information is available.” I would really like to not have to manually set this every day. It kind of seems contrary to the idea of automation.
So I recalled reading this thread some time ago, and specifically I was interested in the node red approach. I am a total noob with node red, but I tried to copy the approach shown in this thread best of my understanding. I am able to build a https URL with a short lived auth token on it, but the node red flow connects and dings but no media plays. So, I thought I would just copy/paste this URL from a Debug node into my manual automation to test it. And nothing happens when it’s triggered. It’s like the auth key is no good. Does anyone have a working node red flow that uses a local mp3 audio? If I get the URL from the media tab using the browser network tools the URL works as I would expect. Or failing this, how does one use a long lived token to do something like this? I would really like to get this to work and am so disappointed that the new play media action does not work in this case (and apparently for many other cases as well). TIA!
Here is a log entry:
Logger: homeassistant.core
Source: components/cast/media_player.py:658
First occurred: 10:19:41 PM (9 occurrences)
Last logged: 10:39:50 PM
Error executing service: <ServiceCall media_player.play_media (c:33080fedff4293e11e6e3ce5f5f047f8): device_id=['a5d0a56a34474fa4d3ad1b911caa1e50'], entity_id=['media_player.living_room_speaker'], extra=, media_type=music, media_id=https://fakeplaceholder.duckdns.org/media/local/white_noise.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI4ZTkzMzc1MjMzYzE0NzE0YWViOGE3OTAxMDVjZGE1MCIsInBhdGgiOiJodHRwczovL215Y3JvZnRob2xtZXMuZHVja2Rucy5vcmcvbWVkaWEvbG9jYWwvd2hpdGVfbm9pc2UubXAzIiwiaWF0IjoxNjQ3MTQ5MzU2LCJleHAiOjE2NDcxNDk2NTZ9.mhQW2T6sQiJ8PZrDTyZXmeEo5HesSfpPyWNjXuv-GMc>
Error executing service: <ServiceCall media_player.play_media (c:ea52a6863e4f731ee31843e3bb69b07d): device_id=['a5d0a56a34474fa4d3ad1b911caa1e50'], extra=, media_type=music, media_id=https://fakeplaceholder.duckdns.org/media/local/white_noise.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI4ZTkzMzc1MjMzYzE0NzE0YWViOGE3OTAxMDVjZGE1MCIsInBhdGgiOiJodHRwczovL215Y3JvZnRob2xtZXMuZHVja2Rucy5vcmcvbWVkaWEvbG9jYWwvd2hpdGVfbm9pc2UubXAzIiwiaWF0IjoxNjQ3MTQ5MzU2LCJleHAiOjE2NDcxNDk2NTZ9.mhQW2T6sQiJ8PZrDTyZXmeEo5HesSfpPyWNjXuv-GMc>
Error executing service: <ServiceCall media_player.play_media (c:a181f15bb32291c8f5b1864defeff6f2): device_id=['a5d0a56a34474fa4d3ad1b911caa1e50'], extra=, media_type=music, media_id=https://fakeplaceholder.duckdns.org/media/local/white_noise.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI4ZTkzMzc1MjMzYzE0NzE0YWViOGE3OTAxMDVjZGE1MCIsInBhdGgiOiJodHRwczovL215Y3JvZnRob2xtZXMuZHVja2Rucy5vcmcvbWVkaWEvbG9jYWwvd2hpdGVfbm9pc2UubXAzIiwiaWF0IjoxNjQ3MTQ5MzU2LCJleHAiOjE2NDcxNDk2NTZ9.mhQW2T6sQiJ8PZrDTyZXmeEo5HesSfpPyWNjXuv-GMc>
Error executing service: <ServiceCall media_player.play_media (c:74d81e3403eaec85808c7a95c29d9d14): device_id=['a5d0a56a34474fa4d3ad1b911caa1e50'], entity_id=['media_player.living_room_speaker'], extra=, media_type=music, media_id=https://fakeplaceholder.duckdns.org/media/local/white_noise.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI4ZTkzMzc1MjMzYzE0NzE0YWViOGE3OTAxMDVjZGE1MCIsInBhdGgiOiJodHRwczovL215Y3JvZnRob2xtZXMuZHVja2Rucy5vcmcvbWVkaWEvbG9jYWwvd2hpdGVfbm9pc2UubXAzIiwiaWF0IjoxNjQ3MTQ5NTg0LCJleHAiOjE2NDcxNDk4ODR9.qxruLTZ8MCJCwtzE_mWB7WW-KJc3tyWeTNYZRbMrUj4>
Error executing service: <ServiceCall media_player.play_media (c:f98e8e585606ef3add19da81c4515544): device_id=['a5d0a56a34474fa4d3ad1b911caa1e50'], extra=, media_type=music, media_id=https://fakeplaceholder.duckdns.org/media/local/white_noise.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI4ZTkzMzc1MjMzYzE0NzE0YWViOGE3OTAxMDVjZGE1MCIsInBhdGgiOiJodHRwczovL215Y3JvZnRob2xtZXMuZHVja2Rucy5vcmcvbWVkaWEvbG9jYWwvd2hpdGVfbm9pc2UubXAzIiwiaWF0IjoxNjQ3MTQ5ODc1LCJleHAiOjE2NDcxNTAxNzV9.FbDbJw24es9cVWGzwP6B9ZJKwAGcIdEQ8FO_vjwZz2I>
File "/usr/src/homeassistant/homeassistant/core.py", line 1654, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1673, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 668, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 949, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 705, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 658, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/pychromecast/quick_play.py", line 77, in quick_play
controller.quick_play(**data)
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py", line 665, in quick_play
self.play_media(media_id, media_type, **kwargs)
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py", line 566, in play_media
raise PyChromecastError()
pychromecast.error.PyChromecastError
Exact same thing here. And I can’t get it to play. It’s so frustrating!
I use this method for play media
- put media file in media folder
- call service : play media
media_content_id: http://your_HA_IP_Address:8123/media/local/File.mp3
media_content_type: audio/mp3
Hope this help
