I have the same issue here. It was my first ZigBee device and my first coordinator, it took me many hours to figure out that the problem was that it was not been recognized. Mainly because here: https://zigbee.blakadder.com/Earda_EDM-1ZAA-EU.html it says that it is compatible with ZHA, Tasmota and ZigBee2MQTT.
I’ve got the same device but it’s a other ID: TZE200_dfxkcots.
It is integrate to ZHA but with no entity and no script available.
Someone could help ?
It was detected in Phoscon… However not as a dimmer but as a light / on / off switch. I also got the occasional LED flicker which it does not make sense as I have the neutral wire…
The dimmer is quite nice how do we make it work?
I am using it with a Tuya integration. I really don’t like it but is the only working solution I have found, I bought a cheap Tuya gateway, configured it and configured the tuya integration in Home Assistant. This are the only devices (I have four) in the Tuya system and I can get along with it. It is not nice but operational.
I’d like to get this working in zha. I switched to phoscon to include but a lot of my other devices seem to have issues in phoscon. I find ZHA to be a lot more stable. How can we go about getting this included in ZHA?
_TZE200_9i9dt8is is still not working, but the same dimmer _TZE200_dfxkcots is recognized with adnotation of used quirks.
I have switched to Zigbee2Mqtt and all is working fine. ZHA is still far behind unfortunatelly…
I’m struggling with this TS0601 dimmer and Zigbee2MQTT (edge) - I’m still getting all these datapoint errors - is there a solution or do I also have to add a Tuya hub and a 2nd zigbee network?
