The thermostat displays the room temperature and the set temperature correctly. In Homeassistant under zha under attribute…0x0218 the temperature off is displayed correctly. Under control elements and in the tile the value 20°c is displayed only 2°c wrong. The set temperature is displayed correctly everywhere. What can I change so that the value is displayed correctly. Sorry I can not translate English only deepl.
few days ago I posted the same problem.
See ZHA - thermostat ME81AH wrong temperature
Did you find any solution for this?
Regards
