My camera was working (for over a year), but after the latest ESPHome update 1.19, I decided to update the devices.
Now I see the following in the logs:
Any ideas? I actually updated a different camera (MStack) that worked just fine. The TTGO display and motion sensor seem to be working fine, it’s just the camera that is now failing.
Are you folks using the display on these TTGO cameras?
What I have figured out: There was an error during compiling, talking about something with …spi , so I removed in the yaml file all the lines with SPI and everything related to the display, now it works again even without arduino version 1.0.2 (with that the cameras were quite unstable and needed a reset more than once per day)
I encountered the same problem and was forced to bring my old RPi3 installation back online and upload version compiled with ESPHome version 1.15.0b4. This was quite a hassle, so please let me know if you find a solution where these cameras can be upgraded with latest ESPHome versions.
For me the same problem. I just upgraded all of my esphome devices and only the TTGO camera gave the setup fail result. The rest works fine. Any new thoughts on this subject?
Hi Tunnis,
This is the exact configuration I have. It worked for me until the last update of ESPHome. It’s only the camera which is not working, the rest is up & running.
Can you recall which version of ESPHome you had problems with and whether the problem occurred with that specific version after an upgrade? Was the problem description identical to what we’ve experienced or different?
The reason I’m asking for specifics is that I not longer have a simple way to restore the units with an older version of ESPHome.
Hi. I cannot recall the last version, I presume 1 or even more versions ago. I happen to have the original bin file with which I made the ttgo cam work. This is a kind of reset of the device to an older version. I will try that in a couple of days. For now there does not seem to be a solution for the problem (yet)?
I had to remove the arduino version I mentioned in post #2 with the September ESP Home update. All is working with the original config (first post). The only other thing with my config is I did disable the logger.
Do I understand you correctly that it now works for you again since the september update and that the only difference relative to your original code is that you disabled the logger?
That is correct. Prior to that I had to set the arduino version lower, but the problem returned with the Sep update. Removing the arduino version and commenting out logger has fixed it for me.
The config below works for me (the names and passwords have been changed):
