🧯 TTS Script Blueprint for All 11 HA Core TTS Flavors
Updated as per [MickW69’s suggestion by adding an action sensor before and after the TTS statement.
Use this for volume change or a siren or playing a media file or stacking all 3 in the same action sensor. OR just ignore them and don’t use them at all.
Existing blueprints will work without changes if you want to update to the new version.
Please Click the :orange_heart: at the end of the Top Post if you find this Useful
New Version today.
I did this a couple of days ago but released it today because of the problems with 2033.5.0 and 2022.5.1 releases not allowing Blueprint Imports.
  • 2022-05-05: Updated for 2022.5.0 HA. Changed Choose to if / then statement.
Updated the ‘other blueprints’ links.
November 30, 2022 > Update. Added ZHA Cube Controller version to library.
December 11, 2022 > Update. Added Device Tracker Blueprint to the list.
  • 2022-12-12: Add Update Method Note, minor code change.
    • Name of Blueprint may have changed meaing you have to re-download with a new link.
    • If name changed, it is similar. Variables have not changed.
2024-01-26 added new blueprint
:fire_extinguisher: Zigbee2MQTT Aqara Magic Cube T1-Pro CTP-R01 Xiaomi Lumi cagl02
This Blueprint gives you literally hundreds of actions available on the new Magic Cube.
New Version:
:bookmark_tabs: Changelog
  • 2023-03-01: Add Author Tag. Bump HA required Version to 2023-3-0
