I was wondering if someone could help me with this one.
My goal is when i arm the alarm that a media player, could be google home for instance, lets you know if a sensor is open.
I already tried creating a simple automation where the trigger is the state of the alarm and the condition is then whether one sensor is open or not.
Maybe the easiest way here would be to create a group with all the sensors in it and then measure the condition on the group instead of having a looooong condition list with all sensors?
The other part is to get the TTS to let me know the name of the sensor or sensors, so I don’t have to either open the app to see which sensor it is.
One of the problems I came across was that it doesn’t look like my alarm state is changing status when trying to arm, while a sensor is open.
I use the Bwalarm (akasma74 edition), so I don’t know if that makes a difference.
Anyone having some good suggestions or maybe a working example already?
I think grouping the sensors together should work.
Now you have to find out which one is open, as you said.
To do that, you might want to take a look at: https://www.home-assistant.io/docs/configuration/templating#states-examples
Take a look at the second example there; inside of the for-loop you can query the sensor.
Example for data_template when calling tts.say:
message: >
Warning! The following windows are open:
{% for sensor in group.mysensors %}
{% if is_state('sensor', 'open') %}
sensor.name
{% endfor %}
Note: I haven’t tried this, maybe it won’t work
