I dont mind either way. But whats the difference/ why is it better? I thought MQTT wasnt as secure (though my experence of Tasmota) Why would it not be better to use the intergrated Zigbee?
Just to be clear, Im honestly asking. Happy to be pointed to other posts, Im surre this has been covered somewhere
I ended up having to delete and re-add from scratch all ZB devices. Took a while, but all working now.
Just know that if youāre migrating to a new co-ordinator using ZHA, remove all your devices first, then remove the ZHA intergration. Then add the tubeszb coordinator, once its up and connected, re-pair all your devices.
Also for those with the Ikea buton issue, seems like the battery drain has stopped with this coordinator (still early days though)
Hi there, when setting up a CC2652p2 following your GitHub instructions adding to HA using ZHA (Radio type ZNP) I get two coordinatorsā¦ā¦silicone Labs & Zigbee Coordinatorā¦ā¦.is this correct and which one shall I use, and what do I do with the one Iām not to use (disable)? Thanks for any help.
for the CC2652, youād pic ZNP. did you you have an existing network/ zigbee.db in your config folder? this could cause seeing 2 coordinators I believe.
Hi there, Itās now showing up only one coordinator (ZNP) which is a good start, but now for me too pair any of my devices a have to be right next to the bridge (LQI in the 100+) but as soon as I move 2-3mtrs away (same room and clear line of sight the devices LQI drops to single figures (8) and doesnāt respond (pir is still saying detected) what is the range of the aerial?
It definitely should be better than that. Iām not at home tonight, but direct message me in the morning (or early afternoon your time) and weāll get this sorted out.
Just to clarifyā¦ā¦I was running a (flashed) Sonoff ZB Bridge (located center of the house, 1st floor) with 26 devices connected (only 3 are mains). The two reasons I wanted to change was 1.Too have one more smart device connected to LAN. 2. I have 2 sensors in the kitchen (furthest from bridge on the ground floor) kept loosing connection. So itās hard to believe that itās interference when all my other battery operated end devices could connect spread out over 3 floors without any issues. Yet I canāt move further than 2mtrs away with the device responding.
Totally understand, this is now my first troubleshooting step for zigbee issues, if anything it can rule it out.
Others in this thread can attest to how they didnāt think it could be interference only to find after hours of troubleshooting an energy scan and channel change got everything working, so I am only going from what Iāve learned from experiences.
So I posted the above for both you and a general step for others.
