Not sure if this is the best place to ask the question… but here goes. I have a Tubes ZB coordinator and I am looking for a simple remote to use. I found these, but in the fine print it says it will only work with a Tuya Zigbee Hub?
Would appreciate some advice, and if these remotes are no good, perhaps there are other devices?
Have been experiencing some weird behavior with Zigbee. As I am new to using Zigbee and have a Tubes ZB coordinator, dont suppose there is some diagnostics I can run to try and trouble shoot what might be causing the movement sensor to disappear?
Anyone using the the CP2652 gateway having issues keeping sengled devices paired?
I have 3 bulbs and 2 lightstrips in separate locations that all become unavailable after a while. I simply cut the power and turn them back on, and they reconnect fine. I get similar issues with other devices but they are few and far between.
@code-in-progress, I believe you have sengleds and the gateway. Are you seeing similar issues?
I have the CC2652P2 Based Zigbee to Ethernet Serial Coordinator and have similar issues. I believe this is more of a Sengled issue, though. I had the same issues with SmartThings until I had my mesh perfect.
Sengled lights and strips don’t repeat. They don’t seem to play well with other lights that do act as routers.
Yeah…I bought sengled specifically because they don’t repeat. Zigbee bulbs that repeat are notorious for taking down meshes. These bulbs were stable on my Conbee2 gateway with all the same routers and endpoints so I’m curious to see if others have them working stable…or is it just something I need to troubleshoot on my mesh.
Looked through the topic and need some information.
I have a CC2652P2 Based Zigbee to Power Over Ethernet Serial Coordinator V2.
It is somewhat centerally located but I have a problem with some of my zigbee devices.
Some are very slow at detecting motion or when a door or window is opened/closed. These devices are at the further ends of my house.
Is there another device I can add that would boost the signal like Tube’s Zigbee Router/Repeater.
That would not interfere with Coordinator.
Thank you for the guidance.
I’m working through the waiting list currently as I had a stretch of time when I was out of stock of components. if you sign up there I should get to you in a week or 2. Otherwise an ikea repeater or plug work well as well (just can’t handle as many devices as what I make/sell). I’ve also had good luck with the Sengled Plugs which also have a power metering.
Alas, according to Amazon, they don’t seem to be suited for my household voltage…
But good find! I didn’t know they had released a newer model. Like their older one, this is supposed to handle a full 1800 W, and they even mention fans as specifically compatible. Still not sure if I’d try monitoring, say, a dehumidifer or washing machine on one of these (for power usage — e.g., the classic “washing machine is done!” automation), but it’s not a bad price either way!
Glad to have another plug-in repeater that is easily available.
Hey @tube0013, I’m running into an issue and have done a fair amount of research without a good answer. I’ve found that if my coordinator goes offline even for a brief time and comes back online, most of my zigbee devices reconnect automatically. Most of the time, however, at least one or two do not. I don’t consider this a big issue. What is an issue is that when I put the device in pairing mode, the coordinator can’t find it, or rather seems to find it but ZHA won’t bother to rediscover it. The only fix I’ve found for this is to wipe the coordinator completely by reflashing it, which works but seems like overkill. Would you or anyone else be able to explain why this is happening? I have 20 zigbee devices (all battery powered) at this time but do have my first main powered light on the way. Thanks in advance!
any clue as to why the device is disconnecting for briefly? might be worth trying a static IP to see if that stops. DM me here if interested in that. I’d also wait to see how thngs settle out after getting some mains powered devices. zigbee is meant to be a mesh so things should theoretically get better with routers/repeaters in the mix.
Ah my apologies, I forgot to mention that. I’m talking about short lived power outages to the house or a circuit in the house. This is a situation where the coordinator is effectively unplugged for a period of time. When the coordinator has stable power, everything is rock solid and the it has a DHCP reservation which has never proven to be a problem.
