I’m hoping this is the right place to post this. I recently purchased the USB-only CC2652 coordinator and set it up. I migrated from a USB HubZ controller and everything seemed ok at first. A few hours later, several devices stopped reporting and my first attempt was to restart HomeAssistant. During reboot, the ZHA integration failed to load.
I restored from backup and restored my HubZ backup as well and got everything back online. I just attempted to migrate again and I’m running into the same issue. Reloading the controller from Integrations worked fine, but actually restarting HA once again broke the integration.
The logs below make me think it is still trying to use the HubZ for ZHA, but I’m not entirely sure. Any help or guidance would be appreciated.
Error setting up entry HubZ Smart Home Controller - /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_312001E0-if01-port0, s/n: 312001E0 - Silicon Labs - 10C4:8A2A for zha
7:40:41 AM – (ERROR) components/zha/core/gateway.py
Couldn’t start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 1 of 3)
7:40:41 AM – (WARNING) Zigbee Home Automation - message first occurred at 7:40:12 AM and shows up 3 times
[0x83DD:3:0x0006]: ‘async_initialize’ stage failed: ‘NoneType’ object has no attribute ‘request_callback_rsp’
7:40:01 AM – (WARNING) Zigbee Home Automation - message first occurred at 7:39:55 AM and shows up 81 times
[547089218288] ‘NoneType’ object has no attribute ‘request_callback_rsp’
7:39:58 AM – (ERROR) Home Assistant WebSocket API
Discarding _save_attribute event
7:39:54 AM – (WARNING) components/zha/core/channels/base.py - message first occurred at 7:39:52 AM and shows up 13 times
Update: Removing the ZHA integration and rebooting the RPi notifies me that a new device was found. I am shown two options for ZHA, one with the TubeZB and one with the HUBZ. Restoring the backup to the TubeZB Coordinator brings back all my devices and seems to be fine after restarting HA, but since I removed the old ZHA first, they’d all need to be renamed and placed in rooms, etc…
I can use this as a last resort, but I’d much prefer the migration and keeping all my devices intact. For now, I’ve restored from a backup.
