@zakharm Awesome! Glad to hear it. Yeah this is why I asked about OZWCP documentation in my original reply on this thread. Intuitively you assume you should check the USB option since the controller is USB… but I guess not.
I would love to see a demonstration of how to actually use the control panel just to do simple stuff like adding, removing, and configuring devices. I have clicked around trying to do simple things like remove a device to see if I could then add it back but couldn’t get it to work. For instance I have tried highlighting a device (a zwave dimmer switch) selecting the remove node function, and then clicking the go button and I don’t recall seeing any kind of productive response in the terminal output or on the control panel other then the go button turning yellow. I still have more experimenting to do.
Is anyone able to point me at the dockerfile for the current docker image. I would very much like to try re-compiling it for Arm as i would like to run it alongside my current HA image, without all the effort of having to install it on the bare metal?
I agree. I had no problem getting the OZWCP up and running using the new RPI AIO Installer but I can’t figure out how to use the control panel. I’ve got my Sigma UZB working and identifying some sensors but I’m not sure what all of the configurations settings do. Ironically, when I search for instructions on how to use the CP all I find is how to compile it.
I’m having problems compiling open-zwave-control-panel in Ubuntu 16.04. I had to change mktmp(…) to mkdtemp(…) since the compiler said mktmp is dangerous and told me to use either mkstmp or mkdtmp. And yes, libgnutls28-dev is installed in my server.
grayson@home-server:~/.src/open-zwave-control-panel$ make
g++ -c -Wall -Wno-unknown-pragmas -Wno-inline -Werror -Wno-format -g -DDEBUG -ggdb -O0 -I ../open-zwave//cpp/src -I ../open-zwave//cpp/src/command_classes/ -I ../open-zwave//cpp/src/value_classes/ -I ../open-zwave//cpp/src/platform/ -I ../open-zwave//cpp/src/platform/unix -I ../open-zwave//cpp/tinyxml/ -I ../libmicrohttpd/src/include -o webserver.o webserver.cpp
g++ -o ozwcp -g ozwcp.o webserver.o zwavelib.o ../open-zwave//libopenzwave.a -lgnutls /usr/local/lib/libmicrohttpd.a -pthread -ludev
/usr/local/lib/libmicrohttpd.a(connection.o): In function `do_read':
/home/grayson/.src/libmicrohttpd/src/daemon/connection.c:1501: undefined reference to `gnutls_strerror'
/usr/local/lib/libmicrohttpd.a(connection.o): In function `do_write':
/home/grayson/.src/libmicrohttpd/src/daemon/connection.c:1548: undefined reference to `gnutls_strerror'
/usr/local/lib/libmicrohttpd.a(connection.o): In function `MHD_connection_get_pollfd':
/home/grayson/.src/libmicrohttpd/src/daemon/connection.c:855: undefined reference to `gnutls_record_get_direction'
/usr/local/lib/libmicrohttpd.a(connection.o): In function `MHD_get_connection_info':
/home/grayson/.src/libmicrohttpd/src/daemon/connection.c:2401: undefined reference to `gnutls_cipher_get'
/home/grayson/.src/libmicrohttpd/src/daemon/connection.c:2406: undefined reference to `gnutls_protocol_get_version'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `parse_options_va':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1785: undefined reference to `gnutls_priority_deinit'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1786: undefined reference to `gnutls_priority_init'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1792: undefined reference to `gnutls_strerror'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `recv_tls_adapter':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:385: undefined reference to `gnutls_record_recv'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `send_tls_adapter':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:417: undefined reference to `gnutls_record_send'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_cleanup_connections':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1171: undefined reference to `gnutls_deinit'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_add_connection':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:977: undefined reference to `gnutls_init'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:978: undefined reference to `gnutls_priority_set'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:984: undefined reference to `gnutls_credentials_set'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1008: undefined reference to `gnutls_transport_set_ptr'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1010: undefined reference to `gnutls_transport_set_pull_function'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1013: undefined reference to `gnutls_transport_set_push_function'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1018: undefined reference to `gnutls_certificate_server_set_request'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_get_timeout':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1235: undefined reference to `gnutls_record_check_pending'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_stop_daemon':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2585: undefined reference to `gnutls_priority_deinit'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2587: undefined reference to `gnutls_certificate_free_credentials'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_start_daemon_va':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2439: undefined reference to `gnutls_priority_deinit'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:1979: undefined reference to `gnutls_priority_init'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_TLS_init':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:484: undefined reference to `gnutls_certificate_allocate_credentials'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_init_daemon_certificate':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:443: undefined reference to `gnutls_certificate_set_x509_trust_mem'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:461: undefined reference to `gnutls_certificate_set_x509_key_mem'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2108: undefined reference to `gnutls_priority_deinit'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_init':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2714: undefined reference to `gcry_control'
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2715: undefined reference to `gnutls_global_init'
/usr/local/lib/libmicrohttpd.a(daemon.o): In function `MHD_fini':
/home/grayson/.src/libmicrohttpd/src/daemon/daemon.c:2726: undefined reference to `gnutls_global_deinit'
/usr/local/lib/libmicrohttpd.a(connection_https.o): In function `MHD_tls_connection_handle_write':
/home/grayson/.src/libmicrohttpd/src/daemon/connection_https.c:108: undefined reference to `gnutls_handshake'
/usr/local/lib/libmicrohttpd.a(connection_https.o): In function `MHD_tls_connection_handle_read':
/home/grayson/.src/libmicrohttpd/src/daemon/connection_https.c:62: undefined reference to `gnutls_handshake'
/usr/local/lib/libmicrohttpd.a(connection_https.o): In function `MHD_tls_connection_handle_idle':
/home/grayson/.src/libmicrohttpd/src/daemon/connection_https.c:167: undefined reference to `gnutls_record_check_pending'
/home/grayson/.src/libmicrohttpd/src/daemon/connection_https.c:164: undefined reference to `gnutls_bye'
collect2: error: ld returned 1 exit status
Makefile:71: recipe for target 'ozwcp' failed
make: *** [ozwcp] Error 1
after finally getting ozwcp to compile, I had the same problem as those above, namely, the HID error. Turns out that the Aeon Gen5, while USB, should not use the “USB” checkbox. Thanks to those above who helped solve this!! Finally able to get it working!
if u installing on pi, there are some lines in ur Makefile you need to change (/open-zwave-control-panel/Makefile)
the Make file is made for Mac, so you need to uncomment the linux build part and comment out the mac build part
If anybody else is running open-zwave-control-panel on a Raspberry Pi (or other Debian-based OS), and uses Ansible to manage it, you might find this Ansible role useful:
It’s mostly just copying the instructions that aceat64 posted up above, with some extra goodies, such as running as a non-root user, and systemd integration (which will automatically shut down the home assistant service to run ozwcp, if it’s been set up with https://github.com/mechaxl/ansible-homeassistant).
Check it out and feel free to star it on Github if you find it useful at all. Thanks!
I need help with ozwcp on ubuntu. I think i did the setup correct, the make test was running “ok” on all tests. But how the hell do i start ozwcp?
On web i found sometime people starting it with sudo ./ozwcp -p 8888, but on my machine i only get command not found. Maybe i miss something, hopefully someone here can help me get it running.
@SnapETom something tells me if he can build ozwcp, he should know how to run the binary probably something else
FWIW for anyone reading this, you do not need to run it as root/sudo … and if you don’t specify the port, it will automatically pick one (8090 I think by default).
The ability to run it as a user other than root depends on that user being in the dialout group, or the Zwave device having permissions for anyone to read/write (ie. “chmod 666 /dev/ttyACM0”)
Thanks, sorry if I missed some of this stuff. I am just getting confused by posts with inacurate information mixed with posts with more current accurate data. Newbie but starting to get it, haha
How do I Stop HASS first. When I installed AIO it is running but the service isn’t installed. So I don’t follow how it is set up. The stop command results in the following.
I think it has something to do with HASS running in the virtual environment by default with AIO install but I haven’t figured out how it is controlled.
