Tutorial for fastest possible knx integration into home assistant
Hi
I figured out a way to transfer knx addresses into home assistant relatively quickly. It’s not exactly pretty, but it works. I made a tutorial which also servers as a quick and dirty beginners guide for HA.
Just to get all you KNX folks into home assistant! :slight_smile:
Hi there - very cool tutorial, well done!
I have a different question - I would like to organize the YAML files around an object in KNX, kind of in a similiar way or manner like I organize the group addresses in KNX around certain subjects.
For instance, let’s say I have a water pump that I can switch on/off and via the KNX actuator I also measure the power consumption and maybe the temperature of the water.
in KNX I would do the group addresses like this:
1/0/0 - SWITCH Pump Cold Water (switch)
1/0/1 - STATUS Pump Cold Water (state)
1/0/2 - POWER Pump Cold Water (power)
1/0/3 - TEMPERATURE Cold Water (temperature)
And then maybe I have a simple Light Switch with an integrated presence sensor:
2/0/0 - SWITCH Lights Office (switch)
2/0/1 - STATUS Lights Office (state)
2/0/2 - PRESENCE Office (state)
As you can see from above, in the KNX Group Address environment I can “mix” various types of objects such as switch, state, power, temperature in adjacent group addresses.
When I create the YAML file in Home Assistant, I would like to do the same thing:
KNX:
#START EVERYTHING AROUND PUMPS
  switch:
    -name: "Switch Pump Cold Water"
     address: "1/0/0"
     state_address: "1/0/1"
    -name: "Power Consumption Pump Cold Water"
     state_address: "1/0/2"
     type power
    -name: "Temperature Cold Water"
     state_address: "1/0/3"
     type: temperature
#END EVERYTHING AROUND PUMPS
#START EVERYTHING AROUND OFFICE
  switch:
    -name: "Switch Office Lights"
     address: "2/0/0"
     state_address: "2/0/1"
  binary_sensor:
     -name: "Presence Office"
     state_address: "2/0/2"
#END EVERYTHING AROUND LIGHTS
The issue is that Home Assistant accepts the YAML files when checking it under Developer tools/Check configuration, but somehow the KNX objects are not created correctly within the Devices/Entities.
I checked the Debug File and found the following errors (ignore the file name that are not corresponding to the above sample which is for illustration purpose only):
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "switch". Check lines 4 and 40
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "switch". Check lines 40 and 50
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "sensor". Check lines 17 and 59
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "switch". Check lines 50 and 115
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "switch". Check lines 115 and 121
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "sensor". Check lines 59 and 133
2023-06-02 18:00:17.111 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/inc_knx.yaml contains duplicate key "binary_sensor". Check lines 129 and 145
In a nutshell, home assistant KNX integration does not like to have switches, sensors, binary sensors etc defined more than once.
My question is if that is correct which means I must just re-organize my YAML file(s).
A bit annoying, as it is logically so much nicer to organize objects around its purpose, and not around its technical abilities.
Has anyone had a similiar problem, and maybe found a work-around?
Martin
I suppose I could have figure this out myself - but the PACKAGES concept helped a lot…
Hello.
this is a great tutorial, However i need your help with knx to home assistant. is there a n option to contact you directly ?
Hi Martin,
Were you able to find a solution for this ?
Karthik
@kartmys yes the packages concept helps.
See example below:
in configuration.yaml I have:
homeassistant:
  # KNX integration via packages
  packages: !include_dir_merge_named inc_packages/
then I have a directory inc_packages with lots of inc_*.yaml files:
and in each of them I can re-use switches, sensors etc for instance:
#included file from ../configurations.yaml
pack_pool:
  knx:
    switch:
      #pumps
      - name: "G150 Pool Pump"
        address: "2/3/0"
        state_address: "2/3/2"
      - name: "G151 Pool Chlorinator"
        address: "2/3/4"
        state_address: "2/3/6"
      #Watt Consumption
        state_address: "2/3/3"
        type: power
        state_address: "2/3/7"
        type: power
      - name: "G150 Pool Temperature"
        state_address: "2/5/23"
        type: temperature
  binary_sensor:
    - platform: threshold
      #G151 Pool Chlorinator Status: when chlorinator uses more than 40 watt then its properly running--> set status to on
      name: G151 Pool Chlorinator Status
      entity_id: sensor.g151_pool_chlorinator
      upper: 40
      hysteresis: 2
      device_class: running
Keep in mind that you have to have a unique package definition, in this case in the file inc_pool.yaml I use “pack_pool:” as the definition. I have plenty of include files all around various subjects to organize my yaml files better.
If you need more help around packages use this link to the documentation:
Best,
Martin
Since it took me a while to find an answer to this question and my google search led me here, i wanted to add the probably newest option to achieve this.
The integration meanwhile supports the import of your ETS project file. After adding the integration, you will find a new menu point in the vertical menu on the left. After clicking on this, a file selector for importing your ETS project file appears. Importing your project adds all group adresses including their names into your knx integration and allows you to create home assistant devices directly via the UI, without the need of editing yaml files manually.
