Tuya 4-Button Remote Switch (TS0044_1) Zigbee2MQTT
This Blueprint allows you define the actions to be taken when perform a single click, double click or hold on the Tuya 4-Button Remote Switch (TS0044_1). This blueprint works with Zigbee2MQTT only.
The remote can purchased here.
Zigbee2MQTT Version 2.0.x:
blueprint:
  name: Tuya Zigbee Z2M 4 button remote (MQTT Sensor)
  description: "TS0044_1 via Zigbee2MQTT Action-Sensor"
  domain: automation
  input:
    action_entity:
      name: Zigbee2MQTT Action Entity
      description: Wähle den MQTT-Sensor mit den Button-Events (z. B. sensor.tuya_remote_action)
      selector:
        entity:
          domain: sensor
          integration: mqtt
    button_1_short_press:
      name: Single Press - Button 1
      default: []
      selector: { action: {} }
    button_1_double_press:
      name: Double Press - Button 1
      default: []
    button_1_hold:
      name: Hold - Button 1
      default: []
    button_2_short_press:
      name: Single Press - Button 2
      default: []
    button_2_double_press:
      name: Double Press - Button 2
      default: []
    button_2_hold:
      name: Hold - Button 2
      default: []
    button_3_short_press:
      name: Single Press - Button 3
      default: []
    button_3_double_press:
      name: Double Press - Button 3
      default: []
    button_3_hold:
      name: Hold - Button 3
      default: []
    button_4_short_press:
      name: Single Press - Button 4
      default: []
    button_4_double_press:
      name: Double Press - Button 4
      default: []
    button_4_hold:
      name: Long Press - Button 4
      default: []
mode: queued
max_exceeded: silent
  - platform: state
    entity_id: !input action_entity
  - choose:
      - conditions: "{{ trigger.to_state.state == '1_single' }}"
        sequence: !input button_1_short_press
      - conditions: "{{ trigger.to_state.state == '1_double' }}"
        sequence: !input button_1_double_press
      - conditions: "{{ trigger.to_state.state == '1_hold' }}"
        sequence: !input button_1_hold
      - conditions: "{{ trigger.to_state.state == '2_single' }}"
        sequence: !input button_2_short_press
      - conditions: "{{ trigger.to_state.state == '2_double' }}"
        sequence: !input button_2_double_press
      - conditions: "{{ trigger.to_state.state == '2_hold' }}"
        sequence: !input button_2_hold
      - conditions: "{{ trigger.to_state.state == '3_single' }}"
        sequence: !input button_3_short_press
      - conditions: "{{ trigger.to_state.state == '3_double' }}"
        sequence: !input button_3_double_press
      - conditions: "{{ trigger.to_state.state == '3_hold' }}"
        sequence: !input button_3_hold
      - conditions: "{{ trigger.to_state.state == '4_single' }}"
        sequence: !input button_4_short_press
      - conditions: "{{ trigger.to_state.state == '4_double' }}"
        sequence: !input button_4_double_press
      - conditions: "{{ trigger.to_state.state == '4_hold' }}"
        sequence: !input button_4_hold
Zigbee2MQTT Version 1.4.x:
blueprint:
  name: Tuya Zigbee 4 button remote
  description: "Blueprint for use with Tuya Zigbee 4 button remote (TS0044_1) on Zigbee2MQTT"
  domain: automation
  input:
    switch:
      description: Tuya Zigbee 4 button remote to use
      selector:
        entity:
          domain: sensor
          integration: mqtt
      description: Action to run on button 1 single press
      default: []
      selector:
        action: null
    button_1_hold:
      description: Action to run on button 1 long press
      default: []
      selector:
        action: null
      description: Action to run on button 1 double press
      default: []
      selector:
        action: null
      description: Action to run on button 2 single press
      default: []
      selector:
        action: null
    button_2_hold:
      description: Action to run on button 2 long press
      default: []
      selector:
        action: null
      description: Action to run on button 2 double press
      default: []
      selector:
        action: null
      description: Action to run on button 3 single press
      default: []
      selector:
        action: null
    button_3_hold:
      description: Action to run on button 3 long press
      default: []
      selector:
        action: null
      description: Action to run on button 3 double press
      default: []
      selector:
        action: null
      description: Action to run on button 4 single press
      default: []
      selector:
        action: null
    button_4_hold:
      description: Action to run on button 4 long press
      default: []
      selector:
        action: null
      description: Action to run on button 4 double press
      default: []
      selector:
        action: null
mode: queued
  - platform: state
    entity_id: !input switch
condition:
  - "{{ trigger.to_state.state != '' }}"
  - variables:
      command: "{{ trigger.to_state.state }}"
  - choose:
      - conditions:
          - "{{ command == '1_single' }}"
      - conditions:
          - "{{ command == '1_double' }}"
      - conditions:
          - "{{ command == '1_hold' }}"
      - conditions:
          - "{{ command == '2_single' }}"
      - conditions:
          - "{{ command == '2_double' }}"
      - conditions:
          - "{{ command == '2_hold' }}"
      - conditions:
          - "{{ command == '3_single' }}"
      - conditions:
          - "{{ command == '3_double' }}"
      - conditions:
          - "{{ command == '3_hold' }}"
      - conditions:
          - "{{ command == '4_single' }}"
      - conditions:
          - "{{ command == '4_double' }}"
      - conditions:
          - "{{ command == '4_hold' }}"
Thanks for this blueprint! It is actually the only blueprint that has proven to work for my TS0044 4 gang switch.
Can confirm it works with the old TS0044 remote.
I had to replace my old blueprint, as it strangely stopped working after an update.
This one works like a charm. Thanks!
Danke Dafür
läuft super
Hey there. I tinkered with your blueprint to make it work in zha. So far Im not able to make it do things… Im pretty new to blueprints. I made plenty of automations for the remote, but wanted to sum it all up in 1 automation, appearently thats only possible with a blue print… So, do someone know how to convert this blueprint to zha? Kind regads…
Thank you so much! It’s working fine with the TS0044
Hi.
Hold takes too long, 7 seconds.
Is it possible to change somehow?
Hey, sorry i don’t think it’s possible, because you can only use the predifined Actions
Thanks it is very great!!!
I modified it slightly to convert it for SONOFF SNZB-01
blueprint:
  name: SonOFF Mobile button
  description: "Blueprint for use with SONOFF button remote (snzb-01) on Zigbee2MQTT"
  domain: automation
  input:
    switch:
      name: SONOFF snzb-01 button remote
      description: SONOFF button remote (snzb-01)
      selector:
        entity:
          domain: sensor
          integration: mqtt
    button_short_press:
      description: Action to run on button single press
      default: []
      selector:
        action: null
    button_hold:
      name: Hold - Button
      description: Action to run on button long press
      default: []
      selector:
        action: null
    button_double_press:
      description: Action to run on button double press
      default: []
      selector:
        action: null
mode: queued
  - platform: state
condition:
  - variables:
  - choose:
      - conditions:
          - "{{ command == 'single' }}"
        sequence: !input button_short_press
      - conditions:
          - "{{ command == 'double' }}"
        sequence: !input button_double_press
      - conditions:
          - "{{ command == 'long' }}"
        sequence: !input button_hold
Heads-up: This very useful blueprint is affected by the breaking changes of Z2M 2.0, and only works with the discouraged setting of legacy_action_sensors activated.
The recommendation is to migrate to MQTT device triggers. My naive attempts at doing so failed, unfortunately.
Hi Bernhorst,
I have had a play and managed to modify to work with Z2m version 2. So far, so good for me. Although I am only just starting on my HA journey :slight_smile:
@Soulfly999 hope you don’t mind.
blueprint:
  domain: automation
  input:
    device:
      description: Tuya Remote to use.
      selector:
        device:
          filter:
            - manufacturer: Tuya
              model: Zigbee 4 button remote
          multiple: false
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    button_1_hold:
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    button_2_hold:
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    button_3_hold:
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    button_4_hold:
      default: []
      selector:
        action: {}
mode: queued
  - platform: device
    domain: mqtt
    device_id: !input device
    type: action
    subtype: 1_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 1_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 1_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 2_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 3_hold
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_single
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_double
  - platform: device
    domain: mqtt
    type: action
    subtype: 4_hold
  - choose:
      - conditions: "{{ trigger.payload == '1_single' }}"
      - conditions: "{{ trigger.payload == '1_double' }}"
      - conditions: "{{ trigger.payload == '1_hold' }}"
      - conditions: "{{ trigger.payload == '2_single' }}"
      - conditions: "{{ trigger.payload == '2_double' }}"
      - conditions: "{{ trigger.payload == '2_hold' }}"
      - conditions: "{{ trigger.payload == '3_single' }}"
      - conditions: "{{ trigger.payload == '3_double' }}"
      - conditions: "{{ trigger.payload == '3_hold' }}"
      - conditions: "{{ trigger.payload == '4_single' }}"
      - conditions: "{{ trigger.payload == '4_double' }}"
      - conditions: "{{ trigger.payload == '4_hold' }}"
If you using Z2M with version 2.x just simple activate under Settings - Home Assistant Integration - Home Assistant legacy action sensors but in future it could be happens, that the legacy options are not supported any more
I used your modified script and it works, I did have to remove the input filter on the model though. For some reason it did not work on my device.
Also very similar to the above last posted you might want to try these which should work for this device too:
Added both Bluetooth Version 1.4.x and 2.x in the first post. Thank you @Crozzer
There were some mistakes in the Version 2.x blueprint. Fixed it now
Unfortunately Version 2 is not working for me. I am able to configure the Automation and choose sensor. But it is never executed - whatever I try!
I have Zigbee2MQTT 2.6.0-1.
It doesn’t work for me either.
I can select and switch devices using the three dots.
But nothing happens via TS0044_1.
I only see that a button has been pressed via the automation.
via “Last triggered”
ms1958
