svante
(Svante Jacobsen)
December 1, 2021, 8:28am
41
Yes, the original problem (Tuya device statuses being delayed and/or lost) has been solved. There are however other problems (for me Brightness stopped working since HA core-2021.11.5) that I suggest be discussed elsewhere.
I have though since moved on from Tuya, replaced all devices with non-Tuya Zigbee ones, removed all Tuya accounts, apps and integrations and is now selling my Tuya devices.
starob
December 13, 2021, 5:13pm
42
The issue was solved but now reappeared. Anybody experiencing problems too?
I removed all of the sensors and will deactivate my tuya account today. Enough is enough…
starob
December 14, 2021, 5:25pm
44
Thanks. I realized that I only have 2 outdoor plugs that still use the Tuya firmware. I tasmotized the first of those today. There is only one more plug left to do then I’m out of Tuya too
The issue came back here on my home assistant.
Having the same issue that seems to have started yesterday.
I am using the Tuya V2 integration.
stahelp
(Peter)
December 16, 2021, 9:01pm
47
Same issue here, very slow response for my Tuya bulbs when turn on/off and delay in showing status in HA. Will start to replace the bulbs with my new Athom bulbs which come flashed with Tasmota
Same. Can turn some switches on/off via HA, while others cannot, but the status doesn’t update in HA.
Already have my USB flasher stuff, just need to find time to tasmotize.
rnodern
(AJ)
December 17, 2021, 5:01am
49
Having this issue too. On 2021.12.1.
I am also seeing this in logs:
Logger: tuya_iot
Source: /usr/local/lib/python3.9/site-packages/tuya_iot/openmq.py:161
First occurred: 15 December 2021, 19:39:47 (15 occurrences)
Last logged: 14:13:12
error while get mqtt config
Googling it suggest that step 6 on (tuya-home-assistant/platform_configuration.md at 1d7da1ee43a2ebfc9ad47eccff453828ffe529f9 · tuya/tuya-home-assistant · GitHub ) was missed. But it’s definitely configured on my IOT setup.
sconstan
(Savvas Konstantinidis)
December 17, 2021, 6:22am
50
Having similar issues as well for the past 3 days.
Lights switched on-off from dashboard but no actual change, delayed response from devices - switches, light bulbs - even some lightbulbs turning on randomly, devices appearing as unavailable.
I am associating it roughly around the time when I updated to latest HA version - Dec update.
allocater2
(Allocater2)
December 18, 2021, 11:46am
51
Yes, it’s completely broken. I now only have the cloud sensors “for fun” to laugh at how ridiculous they are. All my actual data has been switched to local sensors. Here you can see the extend of the desync: (blue is wrong cloud value, purple is correct local value)
MaxK
(Mark)
December 18, 2021, 1:31pm
52
This is appears to be a recurring problem:
opened 03:13PM - 11 Dec 21 UTC
bug
**Describe the bug**
Checking buttons in HA do not respond, respond slow, switc… hing on off, lights do not turn on or off
**Expected behavior**
When switch on or off the light respond accordenly
**Screenshots**
**Home Assistant Version**
## System Health
version | core-2021.11.5
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.9.7
os_name | Linux
os_version | 5.10.17-v8
arch | aarch64
timezone | Etc/GMT
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
Github API Calls Remaining | 5000
Installed Version | 1.18.0
Stage | running
Available Repositories | 912
Installed Repositories | 12
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 6.6
update_channel | stable
supervisor_version | supervisor-2021.12.1
docker_version | 20.10.8
disk_total | 58.0 GB
disk_used | 7.0 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Duck DNS (1.14.0), File editor (5.3.3), Let's Encrypt (4.12.0), Mosquitto broker (6.0.1), Samba share (9.5.1), Terminal & SSH (9.2.1), motionEye (0.16.0)
</details>
<details><summary>Lovelace</summary>
dashboards | 5
resources | 2
views | 21
mode | storage
</details>
Same problem as before again.
https://github.com/tuya/tuya-home-assistant/issues/704
https://github.com/tuya/tuya-home-assistant/issues/706
opened 10:49PM - 12 Dec 21 UTC
bug
Several Devices are regularly unavailable.
These devices are available in the … Tuya app.
After restarting the Tuya integration in Home Assistant, these devices are available again.
No further logging data available.
opened 09:48AM - 17 Dec 21 UTC
bug
Door sensor wifi suddenly unable to sync status to hassio ,but it can sync statu… s to tuya app.
core-2021.11.5
supervisor-2021.12.2
Debian GNU/Linux 11 (bullseye)
tuya v2 - 1.6.0
opened 03:31PM - 13 Nov 21 UTC
integration: tuya
### The problem
After I updated to the current version, I followed the guide to… setup tuya project. I was able to import all my light switches and sockets switches. But all of them failed to keep the on state when I turn on and requires double toggle to turn off. Moreover, The history or logbook would not show any of this change. I read https://github.com/home-assistant/core/issues/58899, but in my tuya project, the device status api is authorized.
Core Version
core-2021.11.3
### What version of Home Assistant Core has the issue?
core-2021.11.3
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Supervised
### Integration causing the issue
Tuya
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/tuya
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
no error
### Additional information
_No response_
opened 09:24PM - 14 Nov 21 UTC
closed 04:06AM - 11 Dec 21 UTC
needs-more-information
integration: tuya
stale
### The problem
Switch is not on. Smart Life shows that the switch is not on.… But Homeassistant shows that the switch is on. I have this problem on all tuya switches.
![image](https://user-images.githubusercontent.com/6769445/141698763-dfae5149-dd9a-44db-98c0-3f9a43405dd1.png)
![image](https://user-images.githubusercontent.com/6769445/141699159-f2ae9eb0-9659-4b9c-ba5e-b1031e877513.png)
On Local Tuya everything worked well.
2021.11.3
never
Home Assistant OS
Tuya
```yaml
Configuration over Integration Page
```txt
Nothing
opened 05:28AM - 18 Nov 21 UTC
stale
### The problem
i have a couple op WiFi switches to controle lights.
With the bleuprint sincronise i coupled them.
When i switch the non connected switch to turn on the lights, i outen have Delaware, up to about 20 sec.
kind regards
Erik
Last
Same
Home Assistant Core
Tuya
_No response_
_No response_
_No response_
_No response_
opened 07:00AM - 18 Nov 21 UTC
closed 11:48AM - 29 Nov 21 UTC
integration: tuya
### The problem
Most of the switches managed by this integration have the statu… s not in sync. Example. They are ON on HA but they are not really on.
Home Assistant 2021.11.4
Home Assistant 2021.11.1
Home Assistant Container
Tuya
https://www.home-assistant.io/integrations/tuya/
_No response_
_No response_
_No response_
opened 04:19PM - 18 Nov 21 UTC
closed 11:51AM - 29 Nov 21 UTC
### The problem
A day or two ago my few Tuya devices (4-5 dimmers) started ac… ting up. They mostly react to commands from HA (on/off/brightness) but the Lovlace rockers/buttons do not follow - turning on a light will flip the rocker, then it will return to off and most of the time (not always) it will return to on after some 30 seconds. Sometimes the rockers will never detect actual light status and thereby go “stuck” with no way of turning on or off a light that is already in the other state. Brightness sometimes work and sometimes not at all.
Operating directly on the dimmers work perfectly as do using the Tuya dedicated app.
I was on core-2021.10.5 and tried to remedy the problem late last night by upgrading to core-2021.11.4 and OS 6.6 but the behaviour was exactly the same.
My take is that there is something wrong with the Tuya cloud/API side of things.
Video (I press the ‘Guest room’ rocker at the bottom ONCE): [Video Link on Vimeo](https://vimeo.com/647234864)
Post on community.home-assistant.io: [Link](https://community.home-assistant.io/t/tuya-devices-are-slow-to-react-no-changes-to-ha/357906)
core-2021.11.4
core-2021.10.5 (but started failing suddenly some 1-2 days ago)
Home Assistant OS
Tuya (new)
_No response_
_No response_
```txt
Found nothing.
_No response_
opened 07:49PM - 14 Dec 21 UTC
integration: tuya
### The problem
Receiving this error in the Core log:
[2021-12-14 07:02:53,2… 21] [tuya-openmq] error while get mqtt config
2021-12-14 07:02:53 ERROR (Thread-9) [tuya_iot] error while get mqtt config
Note: All Tuya devices are working correctly.
core-2021.12.1
core-2021.12.0
Home Assistant OS
Tuya
```yaml
N/A
```txt
[2021-12-14 07:02:53,221] [tuya-openmq] error while get mqtt config
Just noticed this happening after upgrading to 2021.12.1. I do not know if the upgrade caused the problem (I did not revert to 2021.12.0 and I do not plan to since everything is working ok). This has occurred ~ 3 time in a 24 hour period. All Tuya devices are working as expected.
hedbert
(Ed Nelson)
December 20, 2021, 6:08pm
53
Adding my name to this list of people impacted. As I read through this and other threads, it could be a simple workaround by being able to schedule the Tuya Integration to reload. But from what I read there is not an option to create an automation to reload a whole integration, single or multiple entities yes but not the whole integration.
hedbert
(Ed Nelson)
December 20, 2021, 6:38pm
54
So, based on this
bug
core-2021.11.5
tuya v2 - 1.6.0
I created an automation set to reload 1 device that WILL reload the whole integration. I will monitor this over the next few days.
kiekerjan18
(Remko Zieltjens)
January 19, 2022, 7:01pm
55
I had similar issues, yesterday in the Tuya platform (iot.tuya.com ) I’ve added a different server to my project. Since then it seems my issues are resolved.
Hi, I have a theory. In my opinion, there is no slowdown due to neither from Tuya nor from Home Assistant. The sensor only sends data to Tuya’s servers when its status changes(so as to save battery and avoid sending the same data multiple times) or more than a certain amount of time passes since the last sending(ex: 1h). I could notice this with a couple of tuya wifi sensors I have at home. The temperature/humidity sensor sends data inconsistently, while the smart socket(with energy meter) data is updated at the same time on both the app and HA.
