I have tried it again just now and all the entities are disabled:
I was able to add it but I cannot control it. Do I need a gateway device?
I’m having the same issue. I was able to add the device to HA but not operate it.
Hi all,
I honestly hope someone could help me with this.
I bought 2 of these cubetouch and I don’t manage to pair any of them to my phone.
I tried many many times, without success.
What am i doing wrong?
I followed the instructions (on-off-on-off-on) but it don’t enters pairing mode.
Hi! Just did it! In the SmartLife app, I clicked “+”, then I scanned the QR code in the Product Instructions. It told me to switch it ON from OFF, wait 10secs, then OFF and ON again… no light blinking, but the app recognized it. Hope this helps.
Same issue here. However I managed to control it locally with this GitHub - PlusPlus-ua/ha_tuya_ble: Home Assistant support for Tuya BLE devices
Does it show as offline on the IoT Platform for you as well?
Yes, it is offline on Tuya IoT
@00punisher So your Cubetouch II has “offline” status in Tuya IoT but you still were able to add it through the Tuya BLE integration in HA? I have two cubes with offline status and after adding credentials in Tuya BLE it will just give me “No unconfigured devices found.” Any suggestions?
I’m getting the same issue.
it used to work for me.
I think Tuya might have changed something that broke it.
Yes, that’s what I did. The BT device connected to HA found the Cubetouch.
I don’t know if it could help, but just in case: I read (don’t remember where) that you have to avoid SmartLife or Tuya app to be connected to the Cubetouch after pairing, because it supports only one BT connection.
Well, got it to work now. my bluetooth adapter wasn’t configured correctly with the HA docker image. so after giving it the correct permission and closing Smart Life app (just to be sure), Tuya BLE automatically detected the cubetouch
Please, can someone help? I can’t seem to get it to communicate with HA. It shows as offline.
I’ve doen everything by the integration guide.
I’m out of ideas how to troubleshoot this anymore.
Hi there, I have the same issue.
I entered all the details on Tuya_ble, and just gives a error “No unconfigured devices found”
I managed to pair it on the first try, but kept saying offline. So I removed the repository from HA, and now can’t get the device to show up again.
Been stuck for the whole day, hoping someone can help.
I have removed the device from Smart Life, reloaded the repository, multiple HA restarts, but no joy further on
What do you mean “giving it the correct permission”? Could you elaborate? I’m having the same “No unconfigured devices” issue and I’m suspecting this configuration might be the issue, Xiaomi BLE gives similar error.
Quick update, here is a graph of battery life for the regular non-rechargeable CR2 battery coming along the Fingerbot:
Here is a graph of the of battery life for the 880mAh rechargeable LiFePO4 battery that I ordered from Aliexpress:
Basically, the rechargeable lasted about 4.5 weeks while the non-rechargeable lasted 14.7 weeks. Both were almost on standby all the time, so you can expect 4 times more usage for the non-rechargeable. We can’t say rechargeables and non-rechargeables give you the same battery life.
Log file: [log_file.txt (github.com)]
(log_file.txt · GitHub)
File "/usr/local/lib/python3.11/site-packages/aioesphomeapi/client.py", line 658, in bluetooth_device_connect
await connect_future
TimeoutError
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 100, in _async_wrap_bluetooth_operation
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 337, in connect
await self._client.bluetooth_device_connect(
File "/usr/local/lib/python3.11/site-packages/aioesphomeapi/client.py", line 673, in bluetooth_device_connect
raise TimeoutAPIError(
aioesphomeapi.core.TimeoutAPIError: Timeout waiting for connect response while connecting to D8:1F:12:78:48:74 after 20.0s, disconnect timed out: False, after 20.0s
File "/usr/local/lib/python3.11/site-packages/bleak_retry_connector/__init__.py", line 350, in establish_connection
await client.connect(
File "/usr/src/homeassistant/homeassistant/components/bluetooth/wrappers.py", line 292, in connect
connected = await super().connect(**kwargs)
File "/usr/local/lib/python3.11/site-packages/bleak/__init__.py", line 605, in connect
return await self._backend.connect(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 102, in _async_wrap_bluetooth_operation
raise asyncio.TimeoutError(str(err)) from err
TimeoutError: Timeout waiting for connect response while connecting to D8:1F:12:78:48:74 after 20.0s, disconnect timed out: False, after 20.0s
File "/config/custom_components/tuya_ble/tuya_ble/tuya_ble.py", line 574, in _ensure_connected
client = await establish_connection(
File "/usr/local/lib/python3.11/site-packages/bleak_retry_connector/__init__.py", line 374, in establish_connection
_raise_if_needed(name, device.address, exc)
File "/usr/local/lib/python3.11/site-packages/bleak_retry_connector/__init__.py", line 314, in _raise_if_needed
raise BleakNotFoundError(msg) from exc
bleak_retry_connector.BleakNotFoundError: D8:1F:12:78:48:74 - D8:1F:12:78:48:74: Failed to connect after 6 attempt(s): Timeout waiting for connect response while connecting to D8:1F:12:78:48:74 after 20.0s, disconnect timed out: False, after 20.0s
2023-09-16 15:56:45.277 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Connecting; RSSI: -62
2023-09-16 15:56:47.240 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Connected; RSSI: -62
2023-09-16 15:56:47.243 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Connecting; RSSI: -58
2023-09-16 15:56:47.329 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Sending device info request
2023-09-16 15:56:47.330 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Sending packet: #2 FUN_SENDER_DEVICE_INFO
2023-09-16 15:56:48.360 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Connected; RSSI: -58
2023-09-16 15:56:48.364 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] D8:1F:12:78:48:74: Connecting; RSSI: -54
2023-09-16 15:56:48.367 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:48.376 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:48.396 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Sending device info request
2023-09-16 15:56:48.397 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Sending packet: #2 FUN_SENDER_DEVICE_INFO
2023-09-16 15:56:50.928 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:53.168 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 3, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:56.857 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Successful login for [email protected]
2023-09-16 15:56:56.870 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:58.936 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:58.937 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:58.939 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Initializing
2023-09-16 15:56:58.940 DEBUG (MainThread) [custom_components.tuya_ble.cloud] Retrieved: uuid: xxxxxxxxxxxxxxxx, local_key: xxxxxxxxxxxxxxxx, device_id: xxxxxxxxxxxxxxxx, category: szjqr, product_id: xhf790if, device_name: CUBETOUCH II 4, product_model: CBTB3002, product_name: CUBETOUCH II
2023-09-16 15:56:58.978 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Updating
2023-09-16 16:24:02.846 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: timeout receiving response, RSSI: -58
2023-09-16 16:24:02.852 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Sending device info request failed
2023-09-16 16:24:05.974 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: timeout receiving response, RSSI: -56
2023-09-16 16:24:05.980 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Sending device info request failed
2023-09-16 16:24:08.968 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: Device unexpectedly disconnected; RSSI: -50
2023-09-16 16:24:12.239 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:25:2D: Device unexpectedly disconnected; RSSI: -53
2023-09-16 16:24:39.972 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: timeout receiving response, RSSI: -52
2023-09-16 16:24:39.977 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: Sending device info request failed
2023-09-16 16:24:42.435 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:25:2D: timeout receiving response, RSSI: -53
2023-09-16 16:24:42.441 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:25:2D: Sending device info request failed
2023-09-16 16:24:46.561 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Device unexpectedly disconnected; RSSI: -58
2023-09-16 16:24:49.974 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Device unexpectedly disconnected; RSSI: -58
2023-09-16 16:24:59.202 WARNING (SyncWorker_7) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2023-09-16 16:25:17.613 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: timeout receiving response, RSSI: -58
2023-09-16 16:25:17.619 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Sending device info request failed
2023-09-16 16:25:17.626 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] D8:1F:12:78:48:74: timeout receiving response, RSSI: -46
2023-09-16 16:25:17.630 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] D8:1F:12:78:48:74: Sending device info request failed
2023-09-16 16:25:20.206 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: timeout receiving response, RSSI: -58
2023-09-16 16:25:20.212 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:17:60: Sending device info request failed
2023-09-16 16:25:24.426 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Device unexpectedly disconnected; RSSI: -56
2023-09-16 16:25:26.066 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: Device unexpectedly disconnected; RSSI: -52
2023-09-16 16:25:55.428 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: timeout receiving response, RSSI: -56
2023-09-16 16:25:55.434 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:26:CE: Sending device info request failed
2023-09-16 16:25:56.467 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: timeout receiving response, RSSI: -52
2023-09-16 16:25:56.473 ERROR (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1C:8E: Sending device info request failed
2023-09-16 16:26:07.734 WARNING (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:25:2D: Device unexpectedly disconnected; RSSI: -49
2023-09-16 16:26:19.063 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Connected; RSSI: -58
2023-09-16 16:26:19.067 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] D8:1F:12:78:48:74: Connecting; RSSI: -46
2023-09-16 16:26:19.085 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Sending device info request
2023-09-16 16:26:19.086 DEBUG (MainThread) [custom_components.tuya_ble.tuya_ble.tuya_ble] DC:23:4F:74:1D:7D: Sending packet: #14 FUN_SENDER_DEVICE_INFO
Please, can someone help? all the entities are disabled as image.
Try reloading the Tuya BLE Integration. The entities should respond again.
A few days ago it worked (without touching anything) and today I saw that it stopped working a day ago. When it worked, I realized that my usb dongle was not working properly but the integration was working, which baffles me a lot.
I just reload the integration and I have new view, but still not working.
Any ideas?
please ingore post
Integration broken since 2024.1
Integration page removed: https://www.home-assistant.io/integrations/tuya_ble
Anyone have a solution?
